So I feel like I've tried any number of combination of entries into the Shims device, but just haven't found the right combination yet..
Back at the main MQTT device, I've tried any number of combinations of Topics Subscriptions, but read your earlier post about only the uppermost topic can be subscribed to which will make all of the underlying topics available, so my lone topic is "easytouch2-4/#"
For the Trigger, I am matching on the following topics: "easytouch2-4", "state", "temps", "waterSensor1", although I"m guessing all I really need is the very first one, as any changes from EasyTouch will fire the trigger.
The original post here doesn't have any 'nesting' so that has thrown me off completely. I look at all the nested topics available, and see them kind of like Directories.... and assume I need to define the proper "directory" in the Unique ID Location in the Shims device, but again, haven't stumbled on the right one yet. I'm also assuming that both the Unique ID Location and the State Value Location should be the same
type (but have tried different combinations of both...) And while I've tried changing the Value Location from Payload to Topic and back again, I'm not sure what should go int he Payload Key field. Just looking at the prompts in that field, I've tired a few different combinations of defining the "directory" that the field I want to access is in, but again, haven't found the right combination. And as I've made the many changes, I've manually fired off the trigger just to be sure I'm in between MQTT updates...
As always, I more than appreciate your help and assistance.
