Hue Lights discussion
Re: Hue Lights discussion
.. i looked into effect. you mean the selection in a device action ?
That is currently hard wired with only 2 options: none and Color loop. The hue tag is colorloop
I have not found any place on the bridge where the effect options are stored, so that they can be read and used and set
looking at the info of a light strip device which is currently running the color loop it still says "effect": "none",
  "state": {
    "alert": "select",
    "bri": 127,
    "colormode": "xy",
    "ct": 500,
    "effect": "none",
    "hue": 286,
    "mode": "homeautomation",
    "on": true,
    "reachable": true,
    "sat": 253,
    "xy": [
      0.6803,
      0.3165
to proceed I need the exact name of the effect i can send to a lamp.
I will add, just to try it:
Candle as candle
Fireplace as fireplace
with that spelling for the time being
[edit]
I tried candle and fireplace, but those commands got rejected
13 12:40:22 data to be send:{"effect": "colorloop"}
13 12:40:22 URL: http://192.168.1.201/api/xx-LQvAw49oNxYy9/lights/6/state
13 12:40:22 Got response - [{"success":{"/lights/6/state/effect":"colorloop"}}]
13 12:40:22 Sent Hue Lights  "Hue_light_2_6_Office light strip " set effect to "colorloop"
13 12:40:30 data to be send:{"effect": "fireplace"}
13 12:40:30 URL: http://192.168.1.201/api/xx-LQvAw49oNxYy9/lights/6/state
13 12:40:30 Got response - [{"error":{"type":7,"address":"/lights/6/state","description":"invalid value, fireplace, for parameter, effect"}}]
13 12:40:30 Sent Hue Lights  "Hue_light_2_6_Office light strip " set effect to "fireplace"
13 12:40:41 data to be send:{"effect": "candle"}
13 12:40:41 URL: http://192.168.1.201/api/xx-LQvAw49oNxYy9/lights/6/state
13 12:40:41 Got response - [{"error":{"type":7,"address":"/lights/6/state","description":"invalid value, candle, for parameter, effect"}}]
13 12:40:41 Sent Hue Lights  "Hue_light_2_6_Office light strip " set effect to "candle"
v1.10.18 released
https://github.com/IndigoDomotics/Hue-L ... ag/1.10.18
added option to enter effect manually besides preset colorloop in effect action
In case of failure the logfile will show:
Hue Lights Error set effect failure: - [{"error":{"type":7,"address":"/lights/6/state","description":"invalid value, fireplace, for parameter, effect"}}]
jroach
Post by jroach »
Karl, Thanks.
I'm on 1.8.7. Didn't realize that the plug-in store was behind. Thanks and I'll download the latest version now.
Joe
jroach
Post by jroach »
Same error. Could this be a "scene" vs an "Effect" and would that make a difference?
The command is effect:name
And the announcement states fireplace is an effect. So I guess it is effect
May be one needs to update the bridge and lamps.
jroach
Post by jroach »
it works for my lamps from the Hue app.
jroach wrote:it works for my lamps from the Hue app.
I really don’t know what to do.
I have not found a reference to the required command.
How exactly does it work. What do you do on your phone. -screen shots please -
v 1.10.19 released:
https://github.com/IndigoDomotics/Hue-L ... ag/1.10.19
* bug fix: Plugin object has no attribute 'getbaseHTTP' .. should be baseHTTPAddress
* bug fix: global name 'hubnumber' is not defined .. should be hubNumber
that effects on off actions
jroach
Post by jroach »
Karl,
Open up Hue app.
Click on group that contains my Hue Go
Click on Hue Go within that group
Click on the 'three star" icon
Click on Candle or Fireplace
Screen shots attached
jroach
Post by jroach »
Karl, sorry, images in reverse order.
Version 1.10.20 @ 2022-04-16 posted:
* added dev name to logfile output
old >> Set hue device to ..<<
now >> Set hue device:"devName" to ...<
https://github.com/IndigoDomotics/Hue-L ... ag/1.10.20
gillekes
Post by gillekes »
Hello,
I've been using the plugin for many years without problems. Thank you very much for this great plugin and the continuous development.
I was checking logs yesterday and there is a repeating error.
2022-04-23 10:27:47.934 Hue Lights Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2022-04-23 10:27:58.154 Hue Lights Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 337, in runConcurrentThread
AttributeError: 'DimmerDevice' object has no attribute 'pluginpros'
Any idea what to do?
Thanks Gilles
Which version are you using?
Is the latest
MarcoGT
Post by MarcoGT »
I got an error today with the last version:
Hue Lights Error Error in plugin execution ExecuteAction:
File "plugin.py", line 10334, in recallScene
File "plugin.py", line 8683, in doScene
KeyError: (False,)
I am out of town until May 10
Will check then.
Locked
Return to “Archives”
