Hubitat Plugin Beta
cesarvog
Re: Hubitat Plugin Beta
Post by cesarvog »
MQTT filtered section:
app:652022-01-23 12:39:25.876 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:39:25.817 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:38:50.186 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:38:50.119 pm debugMQTT: Received a dim event from dimmer-escritorio level 0 is macpro
app:652022-01-23 12:35:55.993 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:35:55.934 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:35:31.093 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:35:31.019 pm debugMQTT: Received a dim event from dimmer-escritorio level 0 is macpro
app:652022-01-23 12:34:57.841 pm infoMQTT: ================== Startup complete ==================
app:652022-01-23 12:34:57.660 pm infoMQTT: Unsubscribing HA events
app:652022-01-23 12:34:57.654 pm infoMQTT:     Imported [1] homie sensor devices of [1] discovered
app:652022-01-23 12:34:57.649 pm infoMQTT:     Imported [1] homie dim devices of [1] discovered
app:652022-01-23 12:34:57.643 pm infoMQTT:     [5]  Total Hubitat endpoints enabled on MQTT
app:652022-01-23 12:34:57.641 pm infoMQTT:     [4]  Total Hubitat devices are enabled on MQTT
app:652022-01-23 12:34:57.615 pm infoMQTT: ==================================================
app:652022-01-23 12:34:57.407 pm infoMQTT: Created Child device with label hub
app:652022-01-23 12:34:57.310 pm warnMQTT: Creating type sensor as  + (default) RM Connector Variable named MQTT:hub hub
app:652022-01-23 12:34:57.308 pm warnMQTT: Got a sensor of type default
app:652022-01-23 12:34:57.306 pm infoMQTT: [homie] Device enabled: homie hub : sensor default
app:652022-01-23 12:34:57.195 pm infoMQTT: [homie] Device enabled: homie dimmer-escritorio : dim default
app:652022-01-23 12:34:57.036 pm infoMQTT: Skipping HA stateStream MQTT discovery
app:652022-01-23 12:34:57.034 pm infoMQTT: Starting HA Discovery
app:652022-01-23 12:34:56.869 pm infoMQTT: ======= homie Discovery has completed in 1 secs =======
app:652022-01-23 12:34:56.771 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:34:56.678 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:34:56.290 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:34:56.201 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:34:56.136 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:34:56.071 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:34:56.026 pm infoMQTT: Initialize exit
app:652022-01-23 12:34:55.955 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:34:55.901 pm infoMQTT: Adding homie name subscription topics
app:652022-01-23 12:34:55.880 pm infoMQTT: Adding homie property and node subscription topics for macpro
app:652022-01-23 12:34:55.864 pm infoMQTT: Adding homie onoff & dim events subscription topics
app:652022-01-23 12:34:55.848 pm infoMQTT: Subscribing to 2 individual device topics
app:652022-01-23 12:34:55.837 pm infoMQTT: Starting homie Discovery
app:652022-01-23 12:34:55.753 pm infoMQTT: HE device publishing to MQTT has completed in 0 secs
app:652022-01-23 12:34:55.090 pm infoMQTT: Extended colorlight Escritorio 8 [cMode] > [color-mode] publish topics BLOCKED
app:652022-01-23 12:34:55.084 pm debugMQTT: Got a colour synch Extended colorlight Escritorio 8 cMode CT
app:652022-01-23 12:34:55.079 pm warnMQTT: State was null so didn't update MQTT for homie/hubitatc7/extended-colorlight-escritorio-8
app:652022-01-23 12:34:55.059 pm warnMQTT: State had a null value for Extended colorlight Escritorio 8 colorName
app:652022-01-23 12:34:55.057 pm debugMQTT: Got a colour synch Extended colorlight Escritorio 8 colorName null
app:652022-01-23 12:34:54.986 pm debugMQTT: Got a colour synch Extended colorlight Escritorio 8 colorTemperature 6536
app:652022-01-23 12:34:54.979 pm warnMQTT: State was null so didn't update MQTT for homie/hubitatc7/extended-colorlight-escritorio-8
app:652022-01-23 12:34:54.957 pm warnMQTT: State had a null value for Extended colorlight Escritorio 8 colorName
app:652022-01-23 12:34:54.955 pm debugMQTT: Got a colour synch Extended colorlight Escritorio 8 colorName null
app:652022-01-23 12:34:54.873 pm debugMQTT: Got a colour synch Extended colorlight Escritorio 8 hsv [8, null, 65]
app:652022-01-23 12:34:54.861 pm infoMQTT: Resynch MQTT device states and HA discovery topics
app:652022-01-23 12:34:54.790 pm infoMQTT: Starting HE device publishing to MQTT for 4 HE devices with 9 attributes
app:652022-01-23 12:34:54.769 pm debugMQTT: Capability [Refresh][Switch] not required for device [Fibaro Smart Implant Switch Out 1]
app:652022-01-23 12:34:54.765 pm debugMQTT: Events subscribe to Fibaro Smart Implant Switch Out 1 switch switched
app:652022-01-23 12:34:54.764 pm debugMQTT: Fibaro Smart Implant Switch Out 1: Need to subscribe to events from Switch  switch using switched
app:652022-01-23 12:34:54.729 pm debugMQTT: Capability [Actuator][Switch] not required for device [Fibaro Smart Implant Switch Out 1]
app:652022-01-23 12:34:54.727 pm debugMQTT: Capability [Refresh][Switch] not required for device [Fibaro Smart Implant Switch Out 2]
app:652022-01-23 12:34:54.723 pm debugMQTT: Events subscribe to Fibaro Smart Implant Switch Out 2 switch switched
app:652022-01-23 12:34:54.721 pm debugMQTT: Fibaro Smart Implant Switch Out 2: Need to subscribe to events from Switch  switch using switched
app:652022-01-23 12:34:54.683 pm debugMQTT: Capability [Actuator][Switch] not required for device [Fibaro Smart Implant Switch Out 2]
app:652022-01-23 12:34:54.674 pm debugMQTT: Capability [Switch][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.672 pm debugMQTT: Capability [Light][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.671 pm debugMQTT: Capability [SwitchLevel][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.668 pm debugMQTT: Capability [ChangeLevel][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.666 pm debugMQTT: Capability [ColorControl][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.664 pm debugMQTT: Capability [ColorMode][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.660 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 colorName colourDevices
app:652022-01-23 12:34:54.659 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorTemperature  colorName using colourDevices
app:652022-01-23 12:34:54.640 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 colorTemperature colourDevices
app:652022-01-23 12:34:54.638 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorTemperature  colorTemperature using colourDevices
app:652022-01-23 12:34:54.610 pm debugMQTT: Capability [Refresh][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.608 pm debugMQTT: Capability [Actuator][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.605 pm debugMQTT: Capability [Switch][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.604 pm debugMQTT: Capability [Light][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.602 pm debugMQTT: Capability [SwitchLevel][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.600 pm debugMQTT: Capability [ChangeLevel][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.595 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 RGB colourDevices
app:652022-01-23 12:34:54.593 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorControl  RGB using colourDevices
app:652022-01-23 12:34:54.574 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 colorName colourDevices
app:652022-01-23 12:34:54.572 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorControl  colorName using colourDevices
app:652022-01-23 12:34:54.539 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 color colourDevices
app:652022-01-23 12:34:54.538 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorControl  color using colourDevices
app:652022-01-23 12:34:54.527 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 saturation colourDevices
app:652022-01-23 12:34:54.526 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorControl  saturation using colourDevices
app:652022-01-23 12:34:54.495 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 hue colourDevices
app:652022-01-23 12:34:54.493 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorControl  hue using colourDevices
app:652022-01-23 12:34:54.455 pm debugMQTT: Capability [ColorMode][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.453 pm debugMQTT: Capability [ColorTemperature][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.452 pm debugMQTT: Capability [Refresh][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.450 pm debugMQTT: Capability [Actuator][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:34:54.441 pm debugMQTT: deviceSubscribes
app:652022-01-23 12:34:53.642 pm debugMQTT: Initializing...
app:652022-01-23 12:34:53.641 pm warnMQTT: The published homie topic tree has been simplified in content and is no longer homie3 compliant
app:652022-01-23 12:34:43.612 pm infoMQTT: MQTT has reconnected, restarting APP
app:652022-01-23 12:34:43.599 pm infoMQTT: MQTT reports status of Connect
app:652022-01-23 12:34:42.061 pm infoMQTT: Waiting for MQTT connection: false
app:652022-01-23 12:34:41.956 pm infoMQTT: initialising with App count 0
app:652022-01-23 12:34:41.919 pm infoMQTT: Hubitat hub name is : hubitatc7
app:652022-01-23 12:34:41.909 pm infoMQTT: MQTT Client driver present
app:652022-01-23 12:34:41.874 pm infoMQTT: MQTT Updated
app:652022-01-23 12:33:58.101 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:33:58.043 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:33:53.650 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:33:53.577 pm debugMQTT: Received a dim event from dimmer-escritorio level 0 is macpro
app:652022-01-23 12:33:45.459 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:33:45.401 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:33:42.366 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:33:42.287 pm debugMQTT: Received a dim event from dimmer-escritorio level 0 is macpro
app:652022-01-23 12:31:17.148 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:31:17.089 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:30:49.094 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:30:49.019 pm debugMQTT: Received a dim event from dimmer-escritorio level 0 is macpro
app:652022-01-23 12:30:34.605 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:30:34.538 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:28:02.624 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:28:02.554 pm debugMQTT: Received a dim event from dimmer-escritorio level 0 is macpro
app:652022-01-23 12:27:59.958 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:27:59.896 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:27:11.791 pm debugMQTT: Got dimmer-escritorio [2] [switch, level]
app:652022-01-23 12:27:11.707 pm debugMQTT: Received a dim event from dimmer-escritorio level 0 is macpro
app:652022-01-23 12:26:51.510 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:26:51.398 pm debugMQTT: Got dimmer-escritorio [2] [switch, level]
app:652022-01-23 12:22:19.519 pm infoMQTT: ================== Startup complete ==================
app:652022-01-23 12:22:19.341 pm infoMQTT: Unsubscribing HA events
app:652022-01-23 12:22:19.333 pm infoMQTT:     Imported [0] homie sensor devices of [1] discovered
app:652022-01-23 12:22:19.328 pm infoMQTT:     Imported [1] homie dim devices of [1] discovered
app:652022-01-23 12:22:19.321 pm infoMQTT:     [5]  Total Hubitat endpoints enabled on MQTT
app:652022-01-23 12:22:19.319 pm infoMQTT:     [4]  Total Hubitat devices are enabled on MQTT
app:652022-01-23 12:22:19.285 pm infoMQTT: ==================================================
app:652022-01-23 12:22:18.962 pm infoMQTT: [homie] Device enabled: homie dimmer-escritorio : dim default
app:652022-01-23 12:22:18.700 pm infoMQTT: Skipping HA stateStream MQTT discovery
app:652022-01-23 12:22:18.699 pm infoMQTT: Starting HA Discovery
app:652022-01-23 12:22:18.518 pm infoMQTT: ======= homie Discovery has completed in 1 secs =======
app:652022-01-23 12:22:18.432 pm debugMQTT: Received a dim event from dimmer-escritorio level 0 is macpro
app:652022-01-23 12:22:18.347 pm debugMQTT: Received a dim event from dimmer-escritorio level 0 is macpro
app:652022-01-23 12:22:17.903 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:22:17.839 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:22:17.746 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:22:17.650 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:22:17.556 pm infoMQTT: Initialize exit
app:652022-01-23 12:22:17.522 pm debugMQTT: Received a dim event from dimmer-escritorio level 0 is macpro
app:652022-01-23 12:22:17.486 pm infoMQTT: Adding homie name subscription topics
app:652022-01-23 12:22:17.448 pm infoMQTT: Adding homie property and node subscription topics for macpro
app:652022-01-23 12:22:17.440 pm infoMQTT: Adding homie onoff & dim events subscription topics
app:652022-01-23 12:22:17.433 pm infoMQTT: Starting homie Discovery
app:652022-01-23 12:22:17.422 pm infoMQTT: Subscribing to 2 individual device topics
app:652022-01-23 12:22:17.341 pm infoMQTT: HE device publishing to MQTT has completed in 1 secs
app:652022-01-23 12:22:16.622 pm infoMQTT: Extended colorlight Escritorio 8 [cMode] > [color-mode] publish topics BLOCKED
app:652022-01-23 12:22:16.613 pm debugMQTT: Got a colour synch Extended colorlight Escritorio 8 cMode CT
app:652022-01-23 12:22:16.607 pm warnMQTT: State was null so didn't update MQTT for homie/hubitatc7/extended-colorlight-escritorio-8
app:652022-01-23 12:22:16.586 pm warnMQTT: State had a null value for Extended colorlight Escritorio 8 colorName
app:652022-01-23 12:22:16.585 pm debugMQTT: Got a colour synch Extended colorlight Escritorio 8 colorName null
app:652022-01-23 12:22:16.504 pm debugMQTT: Got a colour synch Extended colorlight Escritorio 8 colorTemperature 6536
app:652022-01-23 12:22:16.495 pm warnMQTT: State was null so didn't update MQTT for homie/hubitatc7/extended-colorlight-escritorio-8
app:652022-01-23 12:22:16.475 pm warnMQTT: State had a null value for Extended colorlight Escritorio 8 colorName
app:652022-01-23 12:22:16.473 pm debugMQTT: Got a colour synch Extended colorlight Escritorio 8 colorName null
app:652022-01-23 12:22:16.337 pm debugMQTT: Got a colour synch Extended colorlight Escritorio 8 hsv [8, null, 65]
app:652022-01-23 12:22:16.324 pm infoMQTT: Resynch MQTT device states and HA discovery topics
app:652022-01-23 12:22:16.247 pm infoMQTT: Starting HE device publishing to MQTT for 4 HE devices with 9 attributes
app:652022-01-23 12:22:16.222 pm debugMQTT: Capability [Refresh][Switch] not required for device [Fibaro Smart Implant Switch Out 1]
app:652022-01-23 12:22:16.218 pm debugMQTT: Events subscribe to Fibaro Smart Implant Switch Out 1 switch switched
app:652022-01-23 12:22:16.216 pm debugMQTT: Fibaro Smart Implant Switch Out 1: Need to subscribe to events from Switch  switch using switched
app:652022-01-23 12:22:16.178 pm debugMQTT: Capability [Actuator][Switch] not required for device [Fibaro Smart Implant Switch Out 1]
app:652022-01-23 12:22:16.176 pm debugMQTT: Capability [Refresh][Switch] not required for device [Fibaro Smart Implant Switch Out 2]
app:652022-01-23 12:22:16.172 pm debugMQTT: Events subscribe to Fibaro Smart Implant Switch Out 2 switch switched
app:652022-01-23 12:22:16.170 pm debugMQTT: Fibaro Smart Implant Switch Out 2: Need to subscribe to events from Switch  switch using switched
app:652022-01-23 12:22:16.139 pm debugMQTT: Capability [Actuator][Switch] not required for device [Fibaro Smart Implant Switch Out 2]
app:652022-01-23 12:22:16.121 pm debugMQTT: Capability [Switch][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:16.119 pm debugMQTT: Capability [Light][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:16.117 pm debugMQTT: Capability [SwitchLevel][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:16.114 pm debugMQTT: Capability [ChangeLevel][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:16.113 pm debugMQTT: Capability [ColorControl][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:16.110 pm debugMQTT: Capability [ColorMode][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:16.105 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 colorName colourDevices
app:652022-01-23 12:22:16.104 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorTemperature  colorName using colourDevices
app:652022-01-23 12:22:16.087 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 colorTemperature colourDevices
app:652022-01-23 12:22:16.085 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorTemperature  colorTemperature using colourDevices
app:652022-01-23 12:22:16.053 pm debugMQTT: Capability [Refresh][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:16.051 pm debugMQTT: Capability [Actuator][ColorTemperature] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:16.048 pm debugMQTT: Capability [Switch][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:16.046 pm debugMQTT: Capability [Light][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:16.045 pm debugMQTT: Capability [SwitchLevel][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:16.043 pm debugMQTT: Capability [ChangeLevel][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:16.037 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 RGB colourDevices
app:652022-01-23 12:22:16.035 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorControl  RGB using colourDevices
app:652022-01-23 12:22:16.021 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 colorName colourDevices
app:652022-01-23 12:22:16.019 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorControl  colorName using colourDevices
app:652022-01-23 12:22:15.985 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 color colourDevices
app:652022-01-23 12:22:15.984 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorControl  color using colourDevices
app:652022-01-23 12:22:15.973 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 saturation colourDevices
app:652022-01-23 12:22:15.972 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorControl  saturation using colourDevices
app:652022-01-23 12:22:15.955 pm debugMQTT: Events subscribe to Extended colorlight Escritorio 8 hue colourDevices
app:652022-01-23 12:22:15.953 pm debugMQTT: Extended colorlight Escritorio 8: Need to subscribe to events from ColorControl  hue using colourDevices
app:652022-01-23 12:22:15.911 pm debugMQTT: Capability [ColorMode][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:15.909 pm debugMQTT: Capability [ColorTemperature][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:15.907 pm debugMQTT: Capability [Refresh][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:15.906 pm debugMQTT: Capability [Actuator][ColorControl] not required for device [Extended colorlight Escritorio 8]
app:652022-01-23 12:22:15.891 pm debugMQTT: deviceSubscribes
app:652022-01-23 12:22:15.008 pm debugMQTT: Initializing...
app:652022-01-23 12:22:15.006 pm warnMQTT: The published homie topic tree has been simplified in content and is no longer homie3 compliant
app:652022-01-23 12:22:04.971 pm infoMQTT: MQTT has reconnected, restarting APP
app:652022-01-23 12:22:04.960 pm infoMQTT: MQTT reports status of Connect
app:652022-01-23 12:22:03.393 pm infoMQTT: Waiting for MQTT connection: false
app:652022-01-23 12:22:03.277 pm infoMQTT: initialising with App count 0
app:652022-01-23 12:22:03.237 pm infoMQTT: Hubitat hub name is : hubitatc7
app:652022-01-23 12:22:03.223 pm infoMQTT: MQTT Client driver present
app:652022-01-23 12:22:03.194 pm infoMQTT: MQTT Updated
app:652022-01-23 12:21:06.415 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:21:06.343 pm debugMQTT: Received a dim event from dimmer-escritorio level 0 is macpro
app:652022-01-23 12:20:18.675 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:20:18.617 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:20:13.927 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:20:13.856 pm debugMQTT: Received a dim event from dimmer-escritorio level 0 is macpro
app:652022-01-23 12:20:00.440 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:20:00.382 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:19:56.288 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:19:56.216 pm debugMQTT: Received a dim event from dimmer-escritorio level 0 is macpro
app:652022-01-23 12:19:48.910 pm debugMQTT: Received a dim event from dimmer-escritorio level 80 is macpro
app:652022-01-23 12:19:48.845 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
app:652022-01-23 12:16:32.187 pm debugMQTT: Got dimmer-escritorio [2] [level, switch]
MQTT Child filtered section:
dev:1292022-01-23 12:47:00.019 pm debugMQTT> Tx: heartbeat [37]   complete
dev:1292022-01-23 12:46:40.018 pm debugMQTT> Tx: heartbeat [36]   complete
dev:1292022-01-23 12:46:20.019 pm debugMQTT> Tx: heartbeat [35]   complete
dev:1292022-01-23 12:46:00.019 pm debugMQTT> Tx: heartbeat [34]   complete
dev:1292022-01-23 12:45:40.019 pm debugMQTT> Tx: heartbeat [33]   complete
dev:1292022-01-23 12:45:20.040 pm debugMQTT> Tx: heartbeat [32]   complete
dev:1292022-01-23 12:45:00.018 pm debugMQTT> Tx: heartbeat [31]   complete
dev:1292022-01-23 12:44:40.018 pm debugMQTT> Tx: heartbeat [30]   complete
dev:1292022-01-23 12:44:20.018 pm debugMQTT> Tx: heartbeat [29]   complete
dev:1292022-01-23 12:44:00.018 pm debugMQTT> Tx: heartbeat [28]   complete
dev:1292022-01-23 12:43:40.018 pm debugMQTT> Tx: heartbeat [27]   complete
dev:1292022-01-23 12:43:20.019 pm debugMQTT> Tx: heartbeat [26]   complete
dev:1292022-01-23 12:43:00.024 pm debugMQTT> Tx: heartbeat [25]   complete
dev:1292022-01-23 12:42:40.019 pm debugMQTT> Tx: heartbeat [24]   complete
dev:1292022-01-23 12:42:20.020 pm debugMQTT> Tx: heartbeat [23]   complete
dev:1292022-01-23 12:42:00.019 pm debugMQTT> Tx: heartbeat [22]   complete
dev:1292022-01-23 12:41:40.018 pm debugMQTT> Tx: heartbeat [21]   complete
dev:1292022-01-23 12:41:20.027 pm debugMQTT> Tx: heartbeat [20]   complete
dev:1292022-01-23 12:41:00.031 pm debugMQTT> Tx: heartbeat [19]   complete
dev:1292022-01-23 12:40:40.019 pm debugMQTT> Tx: heartbeat [18]   complete
dev:1292022-01-23 12:40:20.019 pm debugMQTT> Tx: heartbeat [17]   complete
dev:1292022-01-23 12:40:00.019 pm debugMQTT> Tx: heartbeat [16]   complete
dev:1292022-01-23 12:39:40.019 pm debugMQTT> Tx: heartbeat [15]   complete
dev:1292022-01-23 12:39:20.019 pm debugMQTT> Tx: heartbeat [14]   complete
dev:1292022-01-23 12:39:00.020 pm debugMQTT> Tx: heartbeat [13]   complete
dev:1292022-01-23 12:38:40.021 pm debugMQTT> Tx: heartbeat [12]   complete
dev:1292022-01-23 12:38:20.019 pm debugMQTT> Tx: heartbeat [11]   complete
dev:1292022-01-23 12:38:00.023 pm debugMQTT> Tx: heartbeat [10]   complete
dev:1292022-01-23 12:37:40.019 pm debugMQTT> Tx: heartbeat [9]   complete
dev:1292022-01-23 12:37:20.019 pm debugMQTT> Tx: heartbeat [8]   complete
dev:1292022-01-23 12:37:00.019 pm debugMQTT> Tx: heartbeat [7]   complete
dev:1292022-01-23 12:36:40.019 pm debugMQTT> Tx: heartbeat [6]   complete
dev:1292022-01-23 12:36:20.019 pm debugMQTT> Tx: heartbeat [5]   complete
dev:1292022-01-23 12:36:00.019 pm debugMQTT> Tx: heartbeat [4]   complete
dev:1292022-01-23 12:35:40.023 pm debugMQTT> Tx: heartbeat [3]   complete
dev:1292022-01-23 12:35:20.019 pm debugMQTT> Tx: heartbeat [2]   complete
dev:1292022-01-23 12:35:00.022 pm debugMQTT> Tx: heartbeat [1]   complete
dev:1292022-01-23 12:34:57.832 pm infoMQTT> MQTT unsubscribing from: null/cover/+/current_position
dev:1292022-01-23 12:34:57.816 pm infoMQTT> MQTT unsubscribing from: null/cover/+/state
dev:1292022-01-23 12:34:57.799 pm infoMQTT> MQTT unsubscribing from: null/person/+/state
dev:1292022-01-23 12:34:57.782 pm infoMQTT> MQTT unsubscribing from: null/input_boolean/+/state
dev:1292022-01-23 12:34:57.765 pm infoMQTT> MQTT unsubscribing from: null/group/+/state
dev:1292022-01-23 12:34:57.748 pm infoMQTT> MQTT unsubscribing from: null/binary_sensor/+/state
dev:1292022-01-23 12:34:57.731 pm infoMQTT> MQTT unsubscribing from: null/sensor/+/state
dev:1292022-01-23 12:34:57.707 pm infoMQTT> MQTT unsubscribing from: null/light/+/brightness
dev:1292022-01-23 12:34:57.690 pm infoMQTT> MQTT unsubscribing from: null/light/+/state
dev:1292022-01-23 12:34:57.670 pm infoMQTT> MQTT unsubscribing from: null/switch/+/state
dev:1292022-01-23 12:34:57.572 pm infoMQTT> ======== Regardless asking Startup Summary to run ============
dev:1292022-01-23 12:34:57.571 pm infoMQTT> ========  Regardless HA Discovery has completed   =============
dev:1292022-01-23 12:34:57.564 pm infoMQTT> ============   HA Discovery has completed   =============
dev:1292022-01-23 12:34:57.532 pm debugMQTT> --4--   - mS
dev:1292022-01-23 12:34:57.444 pm debugMQTT> Registering homie device hub of type sensor
dev:1292022-01-23 12:34:57.199 pm debugMQTT> Registering homie device dimmer-escritorio of type light
dev:1292022-01-23 12:34:57.045 pm infoMQTT> MQTT subscribing to: homie/hubitatc7/$fw/version
dev:1292022-01-23 12:34:57.013 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/onoff
dev:1292022-01-23 12:34:56.986 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/dim
dev:1292022-01-23 12:34:56.968 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/dim/$format
dev:1292022-01-23 12:34:56.949 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/$type
dev:1292022-01-23 12:34:56.930 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/$properties
dev:1292022-01-23 12:34:56.911 pm infoMQTT> MQTT unsubscribing from: homie/macpro/$nodes
dev:1292022-01-23 12:34:56.894 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/+/$unit
dev:1292022-01-23 12:34:56.878 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/$name
dev:1292022-01-23 12:34:56.818 pm infoMQTT> ====== Regardless still asking HA Discovery to start  ========
dev:1292022-01-23 12:34:56.334 pm infoMQTT> ============= 2 homie entries for device macpro =============
dev:1292022-01-23 12:34:56.025 pm infoMQTT> MQTT subscribing to: homie/macpro/+/+/$unit
dev:1292022-01-23 12:34:55.991 pm infoMQTT> MQTT subscribing to: homie/macpro/+/$type
dev:1292022-01-23 12:34:55.982 pm infoMQTT> MQTT subscribing to: homie/macpro/+/dim/$format
dev:1292022-01-23 12:34:55.947 pm infoMQTT> MQTT subscribing to: homie/hubitatc7/$fw/name
dev:1292022-01-23 12:34:55.946 pm infoMQTT> MQTT subscribing to: homie/macpro/+/$properties
dev:1292022-01-23 12:34:55.932 pm infoMQTT> MQTT subscribing to: homie/macpro/+/dim
dev:1292022-01-23 12:34:55.912 pm infoMQTT> MQTT subscribing to: homie/macpro/+/$name
dev:1292022-01-23 12:34:55.890 pm infoMQTT> MQTT subscribing to: homie/macpro/$nodes
dev:1292022-01-23 12:34:55.880 pm infoMQTT> MQTT subscribing to: homie/macpro/+/onoff
dev:1292022-01-23 12:34:55.875 pm infoMQTT> MQTT subscribing to: homie/macpro/dimmer-escritorio/onoff
dev:1292022-01-23 12:34:55.858 pm infoMQTT> MQTT subscribing to: homie/macpro/dimmer-escritorio/dim
dev:1292022-01-23 12:34:54.850 pm infoMQTT> MQTT subscribing to: homie/hubitatc7/+/+/+/set
dev:1292022-01-23 12:34:54.833 pm infoMQTT> MQTT subscribing to: homie/hubitatc7/+/+/set
dev:1292022-01-23 12:34:54.798 pm infoMQTT> homie discovery is for device: macpro
dev:1292022-01-23 12:34:54.027 pm warnMQTT> ## Restarted ##
dev:1292022-01-23 12:34:54.026 pm infoMQTT> Log level set to 1
dev:1292022-01-23 12:34:53.708 pm infoMQTT> MQTT unsubscribing from: homie/hubitatc7/$fw/version
dev:1292022-01-23 12:34:53.691 pm infoMQTT> MQTT unsubscribing from: homie/hubitatc7/$fw/client
dev:1292022-01-23 12:34:53.677 pm infoMQTT> MQTT unsubscribing from: homie/hubitatc7/$fw/name
dev:1292022-01-23 12:34:43.567 pm infoMQTT> MQTT subscribing to: homie/hubitatc7/$implementation/heartbeat
dev:1292022-01-23 12:34:43.565 pm infoMQTT> Connected to MQTT broker tcp://192.168.1.194
dev:1292022-01-23 12:34:42.555 pm infoMQTT> Broker: Status: Connection succeeded
dev:1292022-01-23 12:34:42.233 pm infoMQTT> Connecting as Hubitat_hubitatc7 to MQTT broker null
dev:1292022-01-23 12:34:42.232 pm infoMQTT> MQTT> client beta 3d hubitatc7
dev:1292022-01-23 12:34:42.230 pm debugMQTT> Initialise MQTT
dev:1292022-01-23 12:34:42.194 pm debugMQTT> Tx: heartbeat [0]   complete
dev:1292022-01-23 12:34:42.178 pm infoMQTT> Resetting MQTT connection
dev:1292022-01-23 12:34:42.177 pm infoMQTT> Disconnected MQTT
dev:1292022-01-23 12:34:40.030 pm debugMQTT> Tx: heartbeat [38]   complete
dev:1292022-01-23 12:34:20.019 pm debugMQTT> Tx: heartbeat [37]   complete
dev:1292022-01-23 12:34:00.021 pm debugMQTT> Tx: heartbeat [36]   complete
dev:1292022-01-23 12:33:40.018 pm debugMQTT> Tx: heartbeat [35]   complete
dev:1292022-01-23 12:33:20.019 pm debugMQTT> Tx: heartbeat [34]   complete
dev:1292022-01-23 12:33:00.025 pm debugMQTT> Tx: heartbeat [33]   complete
dev:1292022-01-23 12:32:40.019 pm debugMQTT> Tx: heartbeat [32]   complete
dev:1292022-01-23 12:32:20.019 pm debugMQTT> Tx: heartbeat [31]   complete
dev:1292022-01-23 12:32:00.018 pm debugMQTT> Tx: heartbeat [30]   complete
dev:1292022-01-23 12:31:40.019 pm debugMQTT> Tx: heartbeat [29]   complete
dev:1292022-01-23 12:31:20.019 pm debugMQTT> Tx: heartbeat [28]   complete
dev:1292022-01-23 12:31:00.019 pm debugMQTT> Tx: heartbeat [27]   complete
dev:1292022-01-23 12:30:40.019 pm debugMQTT> Tx: heartbeat [26]   complete
dev:1292022-01-23 12:30:20.019 pm debugMQTT> Tx: heartbeat [25]   complete
dev:1292022-01-23 12:30:00.067 pm debugMQTT> Tx: heartbeat [24]   complete
dev:1292022-01-23 12:29:40.019 pm debugMQTT> Tx: heartbeat [23]   complete
dev:1292022-01-23 12:29:20.019 pm debugMQTT> Tx: heartbeat [22]   complete
dev:1292022-01-23 12:29:00.019 pm debugMQTT> Tx: heartbeat [21]   complete
dev:1292022-01-23 12:28:40.019 pm debugMQTT> Tx: heartbeat [20]   complete
dev:1292022-01-23 12:28:20.019 pm debugMQTT> Tx: heartbeat [19]   complete
dev:1292022-01-23 12:28:00.019 pm debugMQTT> Tx: heartbeat [18]   complete
dev:1292022-01-23 12:27:40.019 pm debugMQTT> Tx: heartbeat [17]   complete
dev:1292022-01-23 12:27:20.018 pm debugMQTT> Tx: heartbeat [16]   complete
dev:1292022-01-23 12:27:00.019 pm debugMQTT> Tx: heartbeat [15]   complete
dev:1292022-01-23 12:26:40.020 pm debugMQTT> Tx: heartbeat [14]   complete
dev:1292022-01-23 12:26:20.020 pm debugMQTT> Tx: heartbeat [13]   complete
dev:1292022-01-23 12:26:00.018 pm debugMQTT> Tx: heartbeat [12]   complete
dev:1292022-01-23 12:25:40.019 pm debugMQTT> Tx: heartbeat [11]   complete
dev:1292022-01-23 12:25:20.019 pm debugMQTT> Tx: heartbeat [10]   complete
dev:1292022-01-23 12:25:00.019 pm debugMQTT> Tx: heartbeat [9]   complete
dev:1292022-01-23 12:24:40.018 pm debugMQTT> Tx: heartbeat [8]   complete
dev:1292022-01-23 12:24:20.019 pm debugMQTT> Tx: heartbeat [7]   complete
dev:1292022-01-23 12:24:00.019 pm debugMQTT> Tx: heartbeat [6]   complete
dev:1292022-01-23 12:23:40.018 pm debugMQTT> Tx: heartbeat [5]   complete
dev:1292022-01-23 12:23:20.019 pm debugMQTT> Tx: heartbeat [4]   complete
dev:1292022-01-23 12:23:00.024 pm debugMQTT> Tx: heartbeat [3]   complete
dev:1292022-01-23 12:22:40.028 pm debugMQTT> Tx: heartbeat [2]   complete
dev:1292022-01-23 12:22:20.020 pm debugMQTT> Tx: heartbeat [1]   complete
dev:1292022-01-23 12:22:19.509 pm infoMQTT> MQTT unsubscribing from: null/cover/+/current_position
dev:1292022-01-23 12:22:19.492 pm infoMQTT> MQTT unsubscribing from: null/cover/+/state
dev:1292022-01-23 12:22:19.474 pm infoMQTT> MQTT unsubscribing from: null/person/+/state
dev:1292022-01-23 12:22:19.457 pm infoMQTT> MQTT unsubscribing from: null/input_boolean/+/state
dev:1292022-01-23 12:22:19.439 pm infoMQTT> MQTT unsubscribing from: null/group/+/state
dev:1292022-01-23 12:22:19.422 pm infoMQTT> MQTT unsubscribing from: null/binary_sensor/+/state
dev:1292022-01-23 12:22:19.404 pm infoMQTT> MQTT unsubscribing from: null/sensor/+/state
dev:1292022-01-23 12:22:19.387 pm infoMQTT> MQTT unsubscribing from: null/light/+/brightness
dev:1292022-01-23 12:22:19.371 pm infoMQTT> MQTT unsubscribing from: null/light/+/state
dev:1292022-01-23 12:22:19.351 pm infoMQTT> MQTT unsubscribing from: null/switch/+/state
dev:1292022-01-23 12:22:19.244 pm infoMQTT> ======== Regardless asking Startup Summary to run ============
dev:1292022-01-23 12:22:19.243 pm infoMQTT> ========  Regardless HA Discovery has completed   =============
dev:1292022-01-23 12:22:19.240 pm infoMQTT> ============   HA Discovery has completed   =============
dev:1292022-01-23 12:22:19.205 pm debugMQTT> --4--   - mS
dev:1292022-01-23 12:22:19.095 pm debugMQTT> Registering homie device hub of type sensor
dev:1292022-01-23 12:22:18.967 pm debugMQTT> Registering homie device dimmer-escritorio of type light
dev:1292022-01-23 12:22:18.710 pm infoMQTT> MQTT subscribing to: homie/hubitatc7/$fw/version
dev:1292022-01-23 12:22:18.678 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/onoff
dev:1292022-01-23 12:22:18.647 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/dim
dev:1292022-01-23 12:22:18.620 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/dim/$format
dev:1292022-01-23 12:22:18.597 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/$type
dev:1292022-01-23 12:22:18.580 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/$properties
dev:1292022-01-23 12:22:18.562 pm infoMQTT> MQTT unsubscribing from: homie/macpro/$nodes
dev:1292022-01-23 12:22:18.545 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/+/$unit
dev:1292022-01-23 12:22:18.528 pm infoMQTT> MQTT unsubscribing from: homie/macpro/+/$name
dev:1292022-01-23 12:22:18.480 pm infoMQTT> ====== Regardless still asking HA Discovery to start  ========
dev:1292022-01-23 12:22:17.950 pm infoMQTT> ============= 2 homie entries for device macpro =============
dev:1292022-01-23 12:22:17.666 pm infoMQTT> MQTT subscribing to: homie/macpro/+/+/$unit
dev:1292022-01-23 12:22:17.644 pm infoMQTT> MQTT subscribing to: homie/macpro/+/$type
dev:1292022-01-23 12:22:17.583 pm infoMQTT> MQTT subscribing to: homie/macpro/+/dim/$format
dev:1292022-01-23 12:22:17.578 pm infoMQTT> MQTT subscribing to: homie/macpro/+/$properties
dev:1292022-01-23 12:22:17.561 pm infoMQTT> MQTT subscribing to: homie/hubitatc7/$fw/name
dev:1292022-01-23 12:22:17.556 pm infoMQTT> MQTT subscribing to: homie/macpro/+/dim
dev:1292022-01-23 12:22:17.499 pm infoMQTT> MQTT subscribing to: homie/macpro/+/$name
dev:1292022-01-23 12:22:17.464 pm infoMQTT> MQTT subscribing to: homie/macpro/$nodes
dev:1292022-01-23 12:22:17.464 pm infoMQTT> MQTT subscribing to: homie/macpro/dimmer-escritorio/onoff
dev:1292022-01-23 12:22:17.459 pm infoMQTT> MQTT subscribing to: homie/macpro/+/onoff
dev:1292022-01-23 12:22:17.436 pm infoMQTT> MQTT subscribing to: homie/macpro/dimmer-escritorio/dim
dev:1292022-01-23 12:22:16.313 pm infoMQTT> MQTT subscribing to: homie/hubitatc7/+/+/+/set
dev:1292022-01-23 12:22:16.295 pm infoMQTT> MQTT subscribing to: homie/hubitatc7/+/+/set
dev:1292022-01-23 12:22:16.255 pm infoMQTT> homie discovery is for device: macpro
dev:1292022-01-23 12:22:15.425 pm warnMQTT> ## Restarted ##
dev:1292022-01-23 12:22:15.424 pm infoMQTT> Log level set to 1
dev:1292022-01-23 12:22:15.080 pm infoMQTT> MQTT unsubscribing from: homie/hubitatc7/$fw/version
dev:1292022-01-23 12:22:15.062 pm infoMQTT> MQTT unsubscribing from: homie/hubitatc7/$fw/client
dev:1292022-01-23 12:22:15.045 pm infoMQTT> MQTT unsubscribing from: homie/hubitatc7/$fw/name
dev:1292022-01-23 12:22:04.923 pm infoMQTT> MQTT subscribing to: homie/hubitatc7/$implementation/heartbeat
dev:1292022-01-23 12:22:04.922 pm infoMQTT> Connected to MQTT broker tcp://192.168.1.194
dev:1292022-01-23 12:22:03.910 pm infoMQTT> Broker: Status: Connection succeeded
dev:1292022-01-23 12:22:03.588 pm infoMQTT> Connecting as Hubitat_hubitatc7 to MQTT broker null
dev:1292022-01-23 12:22:03.587 pm infoMQTT> MQTT> client beta 3d hubitatc7
dev:1292022-01-23 12:22:03.585 pm debugMQTT> Initialise MQTT
dev:1292022-01-23 12:22:03.527 pm debugMQTT> Tx: heartbeat [0]   complete
dev:1292022-01-23 12:22:03.510 pm infoMQTT> Resetting MQTT connection
dev:1292022-01-23 12:22:03.509 pm infoMQTT> Disconnected MQTT
dev:1292022-01-23 12:22:00.019 pm debugMQTT> Tx: heartbeat [50]   complete
dev:1292022-01-23 12:21:40.020 pm debugMQTT> Tx: heartbeat [49]   complete
dev:1292022-01-23 12:21:20.020 pm debugMQTT> Tx: heartbeat [48]   complete
dev:1292022-01-23 12:21:00.019 pm debugMQTT> Tx: heartbeat [47]   complete
dev:1292022-01-23 12:20:40.019 pm debugMQTT> Tx: heartbeat [46]   complete
dev:1292022-01-23 12:20:20.020 pm debugMQTT> Tx: heartbeat [45]   complete
dev:1292022-01-23 12:20:00.019 pm debugMQTT> Tx: heartbeat [44]   complete
dev:1292022-01-23 12:19:40.019 pm debugMQTT> Tx: heartbeat [43]   complete
dev:1292022-01-23 12:19:20.020 pm debugMQTT> Tx: heartbeat [42]   complete
dev:1292022-01-23 12:19:00.018 pm debugMQTT> Tx: heartbeat [41]   complete
dev:1292022-01-23 12:18:40.020 pm debugMQTT> Tx: heartbeat [40]   complete
dev:1292022-01-23 12:18:20.020 pm debugMQTT> Tx: heartbeat [39]   complete
dev:1292022-01-23 12:18:00.019 pm debugMQTT> Tx: heartbeat [38]   complete
dev:1292022-01-23 12:17:40.025 pm debugMQTT> Tx: heartbeat [37]   complete
dev:1292022-01-23 12:17:20.020 pm debugMQTT> Tx: heartbeat [36]   complete
dev:1292022-01-23 12:17:00.020 pm debugMQTT> Tx: heartbeat [35]   complete
dev:1292022-01-23 12:16:40.019 pm debugMQTT> Tx: heartbeat [34]   complete
autolog
Post by autolog »
Thanks for the log which I will now review.
If you click on the MQTT: Child device driver label at the top of the Logs screen, it will filter on just that and hide the rest of the log entries ;)
cesarvog
Post by cesarvog »
Correct, I decided to send you both the MQTT filtered and MQTT Child Device filtered for the sake of completeness.
autolog
Post by autolog »
Am I correct in saying that you setup the macpro node yourself in MQTT explorer just to test this out.
If so, did you setup the macpro/hub node or was that done by HE?
cesarvog
Post by cesarvog »
Yes, you are correct.
I did setup the macpro/hub myself, as from the hundreds of my tries, a few involved using the complete Homie 3.0.0 schema. It's of no use for my intended purposes, but I just left it there in case I change my mind.
autolog
Post by autolog »
What is odd, I can see you are getting a subscription for your device:
whereas my device isn't being subscribed to for some reason. :?
cesarvog
Post by cesarvog »
Here is my MQTT App config, in case something is different from yours:
DISCLAIMER: I HATE the way this forum software deals with attachments. I can NEVER get it right the first time. Sorry if that adds to the confusion.
THIRD (did I mention I HATE this forum attachment thing???) screen grab shows something that made me almost loose the rest of my (very little) remaining hair Yesterday. It's strange because it refers to the HE > other system side of things, but I could not have Indigo > HE Discovery working until I unselected all devices from there.
Additionally, if you are manually defining your Virtual Devices from OUTSIDE of the xAPPO/MQTT App, i've read from the more then 800 posts in both MQTT App beta threads that you should not, as automatic discovery won't pickup if the owner of the devices is not MQTT Child Device.
Screen Shot 2022-01-23 at 14.46.02.png (44.06 KiB) Viewed 2969 times
Screen Shot 2022-01-23 at 14.49.21.png (91.95 KiB) Viewed 2969 times
Screen Shot 2022-01-23 at 14.49.39.png (76.11 KiB) Viewed 2969 times
Screen Shot 2022-01-23 at 14.50.10.png (94.22 KiB) Viewed 2969 times
Screen Shot 2022-01-23 at 14.46.32.png (80.33 KiB) Viewed 2969 times
autolog
Post by autolog »
Thanks for the screen shots. I think mine is very similar.
I have now run out of time to work on this today. I will take another look at it tomorrow and do a double check. :)
cesarvog
Post by cesarvog »
No problem, just review my last post again tomorrow, as I had to make some edits to it, because this forum software sucks when it comes to attachments placement and sometimes repeats images. (second image was never meant to appear as it's the same as first. Could not remove it myself...
Also, Please do not get yourself confused by the "dimmer-escritorio" and "Extended Colour Light Escritorio 8" as the names may imply they are the same thing,
They are not, dimmer-escritorio is the one I'm trying to IMPORT from Indigo into HE. (still only working if I set on/off/brightness from Indigo and it reflects in the virtual device in HE, not the other way around). Sent message to Kevin in the Hubitat Forum but he seems to be MIA for the last couple of months...
Second is a different Hue bulb I'm EXPORTING from HE to Indigo. (fully working both ways).
Best regards and thanks again for coming to my rescue.
EDIT: If you are adding the topics manually to Mosquitto, do not forget to set QOS=1 and RETAIN = True.
cesarvog wrote: But not everything is roses yet: Even though the xAPPO/MQTT App and Driver now catch the Indigo MQTT published device, it still cannot control it, that is, I cannot turn the discovered dimmer on/off, nor set it's brightnessLevel from the HE side be reflected on Indigo. The other way around it works as expected, meaning that I can turn on/off, set the brightnessLevel from Indigo and it correctly shows on the Virtual Device properties pages as well as on HE Dashboard.
It's probably something I need to change in the topic structure, but I don't intend to loose my Sunday on it, as Yesterday was a real marathon trying to make this thing work.
Unless you've set up triggers in Indigo to act on those specific topics, and execute the corresponding commands, it's not going to work. There's nothing automatic about that on the Indigo/MQTT side. And I didn't see anything in the other thread about handling incoming commands at all, just sending out updates to HE.
autolog
Post by autolog »
When I can get HE to recognise the definitions in HE then I will add a new feature to the plugin to export selected devices to HE for discovery.
The plugin will then monitor those selected devices and publish state updates to HE.
I have posted a message to @kevin on the HE forum as I see you have been chatting with him Cesar.
I feel hopefull that we will now be able to get this sorted out. :)
cesarvog
Post by cesarvog »
Many thanks, Jon. The value of the Indigo Plugin API and the many dedicated Plugin author as yourself can never be over estimated. You guys rock!
cesarvog
Post by cesarvog »
I made several changes Joe recommended in order to make it easier to publish native Indigo devices into Mosquitto, and am happy with the results. Not only it's much easier to publish initial data for each device by using Action Groups, it also makes updating changed values with triggers much simpler.
The above mentioned changes allowed me to send a message to Kevin, the author of the Hubitat Elevation MQTT App/Driver documenting my findings on trying to integrate his App/Driver with data from my proof of concept, which uses data published via Joe's MQTT Connector Plugin.
It has become much clearer now and I think he must be able to find eventual bugs in his App/Driver with ease.
Once his App/Driver are (hopefully) fixed. I hope we can keep interacting, as you find the best way to update your excellent Indigo Hubitat Bridge Plugin, with enhancements brought out by our back and forth messages here.
Best regards,
Cesar
autolog
Post by autolog »
Good news. :D
I am sure we will get this sorted. With your hard work investigating the messages that need to be published, it will be a sound basis for me to develop enhancements to the plugin for you and others to use.
Thanks for your efforts. :)
siclark
Post by siclark »
Is this to get indigo devices showing in HE to use their dashboards?
Return to “Hubitat”
