Recent changes include:
- v 0.5.14 - On | Off Processing Enhancement. Handle alternate MQTT Message format for on | off. Hat tip @CliveS for reporting / testing help.
- v 0.5.12 - Temperature Sensor Bug Fix
- v 0.5.11 - Support Humidity for a Motion Sensor device
- v 0.5.9 - Enable Humidity and Illuminance as Primary Devices
Further extend Humidity change in version 0.5.8 to enable Humidity to be a Primary device. Enable this also for Illuminance.
Clarification on ungrouped secondary device deletion required message - v 0.5.8 - Fix Humidity as primary Device additional state
- v 0.5.7 - New Set White Level / Temperature Action
Add new action 'Set White Level / Temperature' to enable independent control of a device's White Level and White Temperature.
Fix a bug introduced in 0.5.6 that rendered Tasmota plugs inoperable via the plugin.
