Low Priority Feature Request - Color Temperature
Hi Jon, In the latest release of the LIFX bulb firmware, it supports color temperature down to 1550K. The plugin currently supports color temperature down to 2500K. If you find yourself working in that part of the code, it would be nice to select below 2500K, but don't make a special effort. I really appreciate all of your work on this plugin!
Re: Low Priority Feature Request - Color Temperature
Download the latest version (V6.1.6) from the Indigo Plugin store.
On the restart the discovery process will list the LIFX lamps and show LIFX Product Id number and model.
If you let me know those details for the lamp in question and also the firmware level shown in the Indigo Devices UI and then I will investigate for you.
NB: You may need to right-click on the device listing headers and tick firmware if it isn't already shown.
OK, that's weird, All my bulbs are showing up as LIFX+ (BR30), even though they are a mix of LIFX+ (BR30), LIFX+ (A19), and LIFX A19. I checked the LIFX app and it's showing the same..... Seems like a LIFX issue... Let me investigate and get back. They all show a firmware of 2.80
Hey Jon,
Fixed all of my LIFX issues through LIFX tech support..... back to my original question, and your request for info. My question was that the latest version of LIFX firmware allowed the color temperature to be set below 2500, but the plugin does not seem to support color temperature under 2500. Again, this is a low priority request. Device firmware details within attachment,
Thanks, Ron
Stopped plugin "LIFX 6.1.6"
Starting plugin "LIFX 6.1.6" (pid 86429)
LIFX
============================================== Initialising LIFX Controller Plugin ===============================================
Plugin Name: LIFX
Plugin Version: 6.1.6
Plugin ID: com.autologplugin.indigoplugin.lifxcontroller
Indigo Version: 2021.1.1
Indigo License: ActiveSubscription
Indigo API Version: 2.5
Python Version: 2.7.16 (default, Aug 30 2021, 14:43:11) [GCC Apple LLVM 12.0.5 (clang-1205.0.19.59.6) [+internal-os, ptrauth-isa=deploy
Mac OS Version: 11.6
LIFX Logging to Indigo Event Log at the 'Info' level
LIFX Logging to LIFX Plugin Log at the 'Info' level
Started plugin "LIFX 6.1.6"
LIFX Initialising to poll at 60.0 second intervals
LIFX 'LIFX Controller' giving Discovery an opportunity to complete . . .
LIFX LIFX device discovery starting (this can take up to 60 seconds) . . .
LIFX . . . 'LIFX Controller' initialization now completed.
LIFX Starting 'Backyard Spotlight 1' . . .
LIFX . . . Started 'LIFX LIFX BR30 Night Vision' device: 'Backyard Spotlight 1'.
LIFX Starting 'Backyard Spotlight 2' . . .
LIFX . . . Started 'LIFX LIFX BR30 Night Vision' device: 'Backyard Spotlight 2'.
LIFX Starting 'Buffet Cabinet' . . .
LIFX . . . Started 'LIFX LIFX Z' device: 'Buffet Cabinet'.
LIFX Starting 'Deck Door Bulb' . . .
LIFX . . . Started 'LIFX LIFX A19 Night Vision' device: 'Deck Door Bulb'.
LIFX Starting 'Driveway Spotlight1' . . .
LIFX . . . Started 'LIFX LIFX BR30 Night Vision' device: 'Driveway Spotlight1'.
LIFX Starting 'Driveway Spotlight2' . . .
LIFX . . . Started 'LIFX LIFX BR30 Night Vision' device: 'Driveway Spotlight2'.
LIFX Starting 'Family Room Lamp' . . .
LIFX . . . Started 'LIFX LIFX A19' device: 'Family Room Lamp'.
LIFX Starting 'Family Room Table Lamp' . . .
LIFX . . . Started 'LIFX LIFX A19' device: 'Family Room Table Lamp'.
LIFX Starting 'Front Door Light 1' . . .
LIFX . . . Started 'LIFX LIFX A19 Night Vision' device: 'Front Door Light 1'.
LIFX Starting 'Front Door Light 2' . . .
LIFX . . . Started 'LIFX LIFX A19 Night Vision' device: 'Front Door Light 2'.
LIFX Starting 'Kitchen Cabinet Lights' . . .
LIFX . . . Started 'LIFX LIFX Z' device: 'Kitchen Cabinet Lights'.
LIFX Starting 'Kitchen Table Lamp 1' . . .
LIFX . . . Started 'LIFX LIFX A19 Night Vision' device: 'Kitchen Table Lamp 1'.
LIFX Starting 'Kitchen Table Lamp 2' . . .
LIFX . . . Started 'LIFX LIFX A19 Night Vision' device: 'Kitchen Table Lamp 2'.
LIFX Starting 'Living Room Lamp' . . .
LIFX . . . Started 'LIFX LIFX A19' device: 'Living Room Lamp'.
LIFX Starting 'Lower Bedroom Lamp' . . .
LIFX . . . Started 'LIFX LIFX A19' device: 'Lower Bedroom Lamp'.
LIFX Starting 'Lower Level Foyer Lamp' . . .
LIFX . . . Started 'LIFX LIFX A19' device: 'Lower Level Foyer Lamp'.
LIFX Starting 'Pool Spotlight Bulb' . . .
LIFX . . . Started 'LIFX LIFX A19 Night Vision' device: 'Pool Spotlight Bulb'.
LIFX Starting 'Sitting Room Lamp' . . .
LIFX Warning Having trouble accessing LIFX device 'Sitting Room Lamp' with MAC address 'd0:73:d5:6b:bd:e2' at IP address '192.168.1.130 . . .
LIFX Warning . . . Trying again to access 'Sitting Room Lamp' . . .
LIFX . . . Successfully recovered access to LIFX device 'Sitting Room Lamp' with MAC address 'd0:73:d5:6b:bd:e2' at IP address '192.168.1.130
LIFX . . . Started 'LIFX LIFX Mini White' device: 'Sitting Room Lamp'.
LIFX Starting 'Upstairs Nightlight' . . .
LIFX . . . Started 'LIFX LIFX A19' device: 'Upstairs Nightlight'.
Thanks, Ron
LIFX
Plugin Name: LIFX
- LIFX.png (394.29 KiB) Viewed 2501 times
I am in the process of looking at this one at the moment. I will post when I have an update for you.7rdr7 wrote:... My question was that the latest version of LIFX firmware allowed the color temperature to be set below 2500, but the plugin does not seem to support color temperature under 2500. ...
