Does this plugin work anymore?
gmusser
Post by gmusser »
I just installed Nest smoke detectors and was hoping to interface them to Indigo, but I’m unable to get the plugin to work—it fails when attempting to obtain an authorization key. I’m running Indigo 7.5.
ckeyes888
Re: Does this plugin work anymore?
Post by ckeyes888 »
Still working fine for me..albeit I haven’t added any new devices in years.
Carl
vtmikel
Post by vtmikel »
A warning to others - I added a NEST Thermostat to my house the other day, and it is not appearing in the plugin. I looked at the JSON received by the plugin, and it's not included. Homebridge (separate install on my network) is able to see it. Perhaps the newer models do not work with the older API.
My new NEST Protects are adding correctly.
I did some digging and Homebridge NEST plugin uses a different API than the dated Indigo plugin, that's my only guess at this time.
Ramias
Post by Ramias »
Are you using a Google account for Nest or a legacy Nest account? (I've not migrated accounts yet).
gmusser
Post by gmusser »
It’s a Google login to Nest, which is a separate app from Google Home, let alone other Google products.
vtmikel
Post by vtmikel »
Using a legacy Nest Account.
Return to “NEST Home”
