pyatv install error... (see red font below)
farberm
Post by farberm »
I am getting the follwing install error when I use pip3 install pyatv (see red font below) appreciate any/all help
Last login: Mon Aug 2 08:46:32 on ttys008
MARKs-Mac-Pro:~ markfarber$ pip3 install pyatv
Collecting pyatv
Using cached https://files.pythonhosted.org/packages ... ne-any.whl
Collecting cryptography>=2.6 (from pyatv)
Using cached https://files.pythonhosted.org/packages ... 4.7.tar.gz
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing wheel metadata ... done
Collecting protobuf<4,>=3.14.0 (from pyatv)
Collecting zeroconf>=0.28.2 (from pyatv)
Collecting bitarray>=2.1.2 (from pyatv)
Using cached https://files.pythonhosted.org/packages ... 2.4.tar.gz
Collecting aiohttp<5,>=3.1.0 (from pyatv)
Using cached https://files.pythonhosted.org/packages ... st0.tar.gz
Collecting netifaces>=0.10.0 (from pyatv)
Using cached https://files.pythonhosted.org/packages ... 1.0.tar.gz
Collecting miniaudio>=1.44 (from pyatv)
Using cached https://files.pythonhosted.org/packages ... .44.tar.gz
ERROR: Command errored out with exit status 1:
command: /Applications/Xcode.app/Contents/Developer/usr/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/private/var/folders/sc/kgn9mx915qn712qtzy8mpjzc0000gn/T/pip-install-t8ud5mnc/miniaudio/setup.py'"'"'; __file__='"'"'/private/var/folders/sc/kgn9mx915qn712qtzy8mpjzc0000gn/T/pip-install-t8ud5mnc/miniaudio/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base pip-egg-info
cwd: /private/var/folders/sc/kgn9mx915qn712qtzy8mpjzc0000gn/T/pip-install-t8ud5mnc/miniaudio/
Complete output (161 lines):
ld: warning: ignoring file /usr/local/Cellar/libffi/3.3_3/lib/libffi.dylib, building for macOS-arm64 but attempting to link with file built for macOS-x86_64
ld: warning: dylib (/usr/local/Cellar/libffi/3.3_3/lib/libffi.dylib) was built for newer macOS version (11.0) than being linked (10.14.6)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/distutils/core.py", line 148, in setup
dist.run_commands()
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/command/bdist_egg.py", line 172, in run
cmd = self.call_command('install_lib', warn_dir=0)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/command/bdist_egg.py", line 158, in call_command
self.run_command(cmdname)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/command/install_lib.py", line 15, in run
self.byte_compile(outfiles)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/distutils/command/install_lib.py", line 132, in byte_compile
byte_compile(files, optimize=0,
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/distutils/util.py", line 466, in byte_compile
compile(file, cfile, dfile)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/py_compile.py", line 157, in compile
os.makedirs(dirname)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/os.py", line 213, in makedirs
makedirs(head, exist_ok=exist_ok)
[Previous line repeated 2 more times]
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/os.py", line 223, in makedirs
mkdir(name, mode)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/sandbox.py", line 310, in wrap
path = self._remap_input(name, path, *args, **kw)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/sandbox.py", line 452, in _remap_input
self._violation(operation, os.path.realpath(path), *args, **kw)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/sandbox.py", line 407, in _violation
raise SandboxViolation(operation, args, kw)
setuptools.sandbox.SandboxViolation: SandboxViolation: mkdir('/Users/markfarber/Library/Caches/com.apple.python/private/var/folders/sc/kgn9mx915qn712qtzy8mpjzc0000gn/T/easy_install-uk7tdn0j', 511) {}
The package setup script has attempted to modify files on your system
that are not within the EasyInstall build area, and has been aborted.
This package cannot be safely installed by EasyInstall, and may not
support alternate installation locations even if you run its setup
script by hand. Please inform the package's author and the EasyInstall
maintainers to find out if a fix or workaround is available.
During handling of the above exception, another exception occurred:
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/sandbox.py", line 154, in save_modules
yield saved
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/sandbox.py", line 195, in setup_context
yield
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/sandbox.py", line 250, in run_setup
_execfile(setup_script, ns)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/sandbox.py", line 45, in _execfile
exec(code, globals, locals)
File "/var/folders/sc/kgn9mx915qn712qtzy8mpjzc0000gn/T/easy_install-uk7tdn0j/cffi-1.14.6/setup.py", line 175, in <module>
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/__init__.py", line 145, in setup
return distutils.core.setup(**attrs)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/distutils/core.py", line 163, in setup
raise SystemExit("error: " + str(msg))
SystemExit: error: SandboxViolation: mkdir('/Users/markfarber/Library/Caches/com.apple.python/private/var/folders/sc/kgn9mx915qn712qtzy8mpjzc0000gn/T/easy_install-uk7tdn0j', 511) {}
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/command/easy_install.py", line 1144, in run_setup
run_setup(setup_script, args)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/sandbox.py", line 253, in run_setup
raise
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/contextlib.py", line 131, in __exit__
self.gen.throw(type, value, traceback)
yield
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/sandbox.py", line 166, in save_modules
saved_exc.resume()
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/sandbox.py", line 141, in resume
six.reraise(type, exc, self._tb)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/_vendor/six.py", line 685, in reraise
raise value.with_traceback(tb)
yield saved
yield
File "<string>", line 1, in <module>
File "/private/var/folders/sc/kgn9mx915qn712qtzy8mpjzc0000gn/T/pip-install-t8ud5mnc/miniaudio/setup.py", line 20, in <module>
setup(
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/__init__.py", line 144, in setup
_install_setup_requires(attrs)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/__init__.py", line 139, in _install_setup_requires
dist.fetch_build_eggs(dist.setup_requires)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/dist.py", line 716, in fetch_build_eggs
resolved_dists = pkg_resources.working_set.resolve(
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/pkg_resources/__init__.py", line 780, in resolve
dist = best[req.key] = env.best_match(
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/pkg_resources/__init__.py", line 1065, in best_match
return self.obtain(req, installer)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/pkg_resources/__init__.py", line 1077, in obtain
return installer(requirement)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/dist.py", line 786, in fetch_build_egg
return cmd.easy_install(req)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/command/easy_install.py", line 679, in easy_install
return self.install_item(spec, dist.location, tmpdir, deps)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/command/easy_install.py", line 705, in install_item
dists = self.install_eggs(spec, download, tmpdir)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/command/easy_install.py", line 890, in install_eggs
return self.build_and_install(setup_script, setup_base)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/command/easy_install.py", line 1158, in build_and_install
self.run_setup(setup_script, setup_base, args)
File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/site-packages/setuptools/command/easy_install.py", line 1146, in run_setup
raise DistutilsError("Setup script exited with %s" % (v.args[0],))
distutils.errors.DistutilsError: Setup script exited with error: SandboxViolation: mkdir('/Users/markfarber/Library/Caches/com.apple.python/private/var/folders/sc/kgn9mx915qn712qtzy8mpjzc0000gn/T/easy_install-uk7tdn0j', 511) {}
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
WARNING: You are using pip version 19.2.3, however version 21.2.2 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
Re: pyatv install error... (see red font below)
Try
sudo pip3 …..
With …. The app you want to install
You then need to enter your system passwd
Return to “AppleTV Plugin”
