New Plugin - Flair Smart Vents
- FlyingDiver
Re: New Plugin - Flair Smart Vents
https://github.com/FlyingDiver/Indigo-F ... /tag/0.0.5
Now supports creating puck devices for use as temperature and humidity sensors.
Please report any issues before I release on the plugin store.
Got this error after upgrading to 0.0.5
I also received the following error after adding a Puck...
Not sure if I need to remove all my previous Flair devices and start over. Please let me know.
Jul 18, 2021 at 11:29:43 AM
Disabling plugin "Flair 0.0.5"
Stopping plugin "Flair 0.0.5" (pid 53196)
Stopped plugin "Flair 0.0.5"
Enabling plugin "Flair 0.0.5"
Starting plugin "Flair 0.0.5" (pid 53206)
Started plugin "Flair 0.0.5"
Flair Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 219, in runConcurrentThread
KeyError: u'4e213f6d-b326-5816-b038-f8867e8e6287'
Flair Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
File "plugin.py", line 208, in runConcurrentThread
NameError: global name 'TEMPERATURE_SCALE_PLUGIN_PREF' is not defined
Flair Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)- FlyingDiver
Delete any HVAC devices you created.
1) I removed all Flair devices and disabled the plugin.
2) Reinstalled 0.05. as I had moved back to 0.0.4
3) Added my Flair Account - Went Green
4) Added a puck and got the following error...
5) Went to add a vent and only 1 of 14 were visible to add. The other 13 were not visible in drop down connection.
6) Going to remove Flair devices again and then completely remove the plugin from OS directory so I can reinstall that way.
Jul 18, 2021 at 11:50:01 AM
Reloading plugin "Flair 0.0.5"
Stopping plugin "Flair 0.0.5" (pid 53704)
Starting plugin "Flair 0.0.5" (pid 53811)
Flair Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)6) Going to remove Flair devices again and then completely remove the plugin from OS directory so I can reinstall that way.
- FlyingDiver
Hmmm. Very strange. Works on my system with one puck and one vent.
- FlyingDiver
Oh, wait. Open the plugin config dialog and set your preferred temperature scale. I just made a change to set a default scale.
I had previously done that. Temperature was set to Fahrenheit.
- FlyingDiver
Upgraded to 0.0.6
1) Removed Devices
2) Upgraded plugin
3) Added Flair account
4) Added Puck - No Errors
5) Puck Returned temperature in F
6) Went to add the vents, only one vent is showing up in drop down picker (see screen shot)
1) Removed Devices
2) Upgraded plugin
- Screen Shot 2021-07-18 at 12.12.15 PM.png (47.4 KiB) Viewed 3993 times
Corresponding Debug Log...The plugin gets the list of vents from Flair, but appears the drop down picker is only presenting a single value.
Flair new device: Starting FlairPuck Device 241640286
Flair Debug new device: Fetching /api/structures/24628/thermostats
Flair Debug new device: Fetched 1 thermostats records
Flair Debug new device: Fetching /api/structures/24628/rooms
Flair Debug new device: Fetched 7 rooms records
Flair Debug new device: Fetching /api/structures/24628/pucks
Flair Debug new device: Fetched 2 pucks records
Flair Debug new device: Fetching /api/structures/24628/hvac-units
Flair Debug new device: Fetched 0 hvac-units records
Flair Debug new device: Fetching /api/structures/24628/vents
Flair Debug new device: Fetching /api/vents/56bcc551-8296-5ede-90cf-c08f3eb63146/current-reading
Flair Debug new device: Fetching /api/vents/f52a17ba-4e65-5df7-18b0-707d57cd98e0/current-reading
Flair Debug new device: Fetching /api/vents/9f7acab8-319f-5ae3-4ec7-93acfb39551b/current-reading
Flair Debug new device: Fetching /api/vents/4e213f6d-b326-5816-b038-f8867e8e6287/current-reading
Flair Debug new device: Fetching /api/vents/38d289ff-3ba4-5f1c-618e-4a80a8949741/current-reading
Flair Debug new device: Fetching /api/vents/26720a40-c5c4-536d-2fb5-ebd34df1522c/current-reading
Flair Debug new device: Fetching /api/vents/6823a71c-9eb8-5b6d-f1b1-d0c7530fa384/current-reading
Flair Debug new device: Fetching /api/vents/e74c3f84-003e-5117-ec38-95634f17abec/current-reading
Flair Debug new device: Fetching /api/vents/01340ffd-8409-5aea-1532-f84226741604/current-reading
Flair Debug new device: Fetching /api/vents/358e9861-6b09-5164-e18a-26fd2ec41505/current-reading
Flair Debug new device: Fetching /api/vents/3693484e-763b-5166-af63-ed4ecdb7003d/current-reading
Flair Debug new device: Fetching /api/vents/bd8887e8-4638-5e3e-75e6-d0bbf3974030/current-reading
Flair Debug new device: Fetching /api/vents/a2406f42-9487-542b-94ba-29fbfc1e543a/current-reading
Flair Debug new device: Fetched 1 vent records
- FlyingDiver
Put the debug log and the data dump (menu command) in this GitHub issue: https://github.com/FlyingDiver/Indigo-Flair/issues/2
Followup there.
Followup there.
Full Debug log and screen shot uploaded to git issue.
- FlyingDiver
Plugin has been discontinued.
