AppleTV Plugin: discussion
changes in V 0.1.2@ 2021-03-26
1. first version -- his is an alpha version
will scan for apple tv devices every xx minutes
will read play status of ided apple tv devices ever xx secs
Configure in config:
- path to python3
- time for scan and read sequences
In device edit the IP number can be over written
In menu a manual scan for new devices can be initated
=== you need to install
1. install x-code
xcode-select —install
2. install python3 (do not use home-brew) if you don't have it on your mac
go to https://www.python.org/downloads/release/python-392/
and download the 64 bit installer and install (all point and click)
3.and download /install pyatv
pip3 install pyatv
download at: https://www.indigodomo.com/pluginstore/248/
new function additions to be added:
1. send commands to apple tv
A) simple pause/ play
B) play certain music / video
C) add cursor movement
2. streamline code
this is build on top of
PYATV. It is maintained by postlund
see: https://github.com/postlund/pyatv
- path to python3
1. install x-code
pip3 install pyatv
2. streamline code
Re: AppleTV Plugin: discussion
Awesome, thanks for another plugin Karl. Will check it out very soon!
Londonmark
Tried it out yesterday. Worked perfectly. Many thanks Karl - great work.
Then - completely unrelated - my internal hard drive failed this morning. Five year old iMac with a fusion drive. It’s now with Apple to be fixed but I have no Indigo server (I know, I know). I walk into dark rooms and they stay dark. Siri doesn’t do anything. Alexa is lost. It’s very disconcerting. /grumble over.
Hopefully in a week or so I’ll be able to play some more with this plugin.
This how the apocalypse looks like !!
Working great here Karl!
Thanks a million for all your great Plugins!
Korey
Korey
- durosity
Very cool plugin! Out of interest would it be plausible to expand this to be able to control/read status of HomePods?
I don’t have one.
Don’t know what opsys runs in it and if there is an http interface.
- FlyingDiver
jkeenan@Kraken ~ % which python3
/usr/bin/python3
appleTV path To python3 /usr/local/bin/python3
appleTV check for new devices every 1440 minutes
appleTV Warning /usr/local/bin/python3 is not present on this mac, see logfile on how to install python3
Check plugin/menu/help
- FlyingDiver
And trying to bring up the plugin config dialog gives me:
Error (client) timeout waiting for plugin response from com.karlwachs.appleTV for request UiGetValues1
Error (client) timeout waiting for plugin response from com.karlwachs.appleTV for request CallPluginFunc
Error (client) runConfigDialog() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
please check v 1.0.10
plugin went to sleep in startup when python3 path is wrong - when still in startup indigo does not allow to start config
now it will wait in runConcurrentThread() until a valid path is entered in config for python3
- FlyingDiver
Well, I can set the Python path now, but I can't get the plugin to do anything else useful.
Can you switch on debug
Then manually scan for new Apple TV devices ( plugin/ menu .. )
Check the plugin.log file.
- FlyingDiver
Now getting:
appleTV Error in Line 927 has error=u'192.168.111.160'
appleTV Error ip:192.168.111.160 data:{u'192.168.111.160': {u'name': u'Great Room', u'AIRPLAYPort': 7000, u'MAC': u'40:CB:C0:C1:7F:4A', u'deep_sleep': False, u'model': u'4K tvOS 14.5', u'identifier': u'B4DCA433-FDBF-44ED-A301-7275CBC378AC', u'MRPPort': 49154}}
Can you restart the Apple TV ?
They sometimes hang.
