Adapters Plugin [archive]
Open source plugin that allows you to create devices which translate/transform values from other devices (Fahrenheit to Celsius for instance).
DaveL17
Re: Adapters Plugin
Post by DaveL17 »
Hmmm. My version doesn't have a zero option.
Screen Shot 2021-04-27 at 6.10.00 AM copy.png (39.67 KiB) Viewed 7914 times
Off to see if my version is out of date...
My Plugins and Scripts
Re: Adapters Plugin
Oh, my bad. I thought that field was implemented differently. Never mind.
jalves
Re: Adapters Plugin - Issue Removing Decimal
Post by jalves »
ckeyes888 wrote:Tried the settings you mentioned but am still getting the decimal.
Missed something? Still returns 43.1
Carl
Are you sure you're using the correct variable in your control page? When you use this plug-in you make a new variable.
Jeff
ckeyes888
Re: Adapters Plugin
Post by ckeyes888 »
Yes, I’m using the correct variable. I see a prior post stating there isn’t a 0 option for the decimal.
I assume that’s the issue?
Carl
DaveL17
Re: Adapters Plugin
Post by DaveL17 »
Selecting the '1' option should yield zero decimal places.
When you create the new Adapters device, you should display the Device State - [Adapters Device you just created] - Sensor Value.
ckeyes888
Re: Adapters Plugin
Post by ckeyes888 »
Those exact settings show 1 decimal place. e.g. 42.3
Carl
DaveL17
Re: Adapters Plugin
Post by DaveL17 »
I have to wonder if there's a bug in the version you have. Did you download it from the Plugin Store or from GitHub? There's always a chance that there was a bug that I fixed on my own, but I don't recall that. I haven't done anything like that in a long time.
ckeyes888
Re: Adapters Plugin
Post by ckeyes888 »
I downloaded from the plugin store. Indigo shows it as ver. 1.0.2
Odd that the download version in the plugin store says1.0.1.
Carl
shapa
Re: Adapters Plugin
Post by shapa »
Any plans to update to the latest Indigo?
howartp
Re: Adapters Plugin
Post by howartp »
Yes, Dave is leading on a Py3 version.
Shouldn’t be too long before it’s ready from what I’ve seen.
DaveL17
Re: Adapters Plugin
Post by DaveL17 »
The updated plugin is with beta testers now. There haven't been any reports of serious trouble and an "official" release should be out soon. Once things settle down a bit with the Python 3 transition, I'll begin working on some suggested enhancements.
Locked
Return to “Adapters”
