Osram Lightify
Re: Osram Lightify
Awesome! Thanks for sharing!
- jay (support)
- Site Admin
- Contact:
Re: Osram Lightify
Hey Nathan, we added a bunch of the Lightify devices to the Devices list - do you have a list of the ones that work with the Hue Hub as well? Where there's overlap we can mark the device as working with both your Hue plugin and with the Lightify plugin (will help users find the right solutions for their scenarios).
Re: Osram Lightify
Hey Jay.
Yep. I’ll get you an updated list later this evening. Thanks.
Re: Osram Lightify
Here's the latest list of Osram Lightify devices supported by the Hue Lights plugin via the Hue bridge.
- Osram Lightify A60 Tunable White bulb (color temp. only)
- Osram Lightify A60 RGBW bulb (extended color bulb)
- Osram Lightify Flex RGBW light strip (extended color light)
- Osram PAR-16 50W equivalent Tunable White bulb (color temp. only)
- Osram Gardenpole Mini RGBW light (extended color light)
- Osram PAR-16 GU10 Lightify light (extended color light)
- Osram On/Off Plug
- jay (support)
- Site Admin
- Contact:
Re: Osram Lightify
Great, thanks. I'll get those on the list in all the right places.nsheldon wrote:Here's the latest list of Osram Lightify devices supported by the Hue Lights plugin via the Hue bridge.
- Osram On/Off Plug
Re: Osram Lightify
Curious on Sylvania Lightify device compatibility with the Hue Hub (and hence Hue Indigo Plugin). Should some/all of the US Lightify bulbs be compatible with Hue Hub? I'm trying to migrate my stuff over from the Lightify Hub (Lightify Cloud is decomissioning next year and many functionalities will be lost).
My Lightify Hub and US Bulbs have been updated to the latest firmware versions. However, the Hue Mobile app doesn't seem to allow me to add these to the Hue Hub/setup. Any tips greatly appreciated
I automate because I am lazy
- My Plugins: viewforum.php?f=309
Re: Osram Lightify
Sorry. I don't have any first hand experience with any of the Lightify stuff. But if you're able to get your lights paired with the Hue bridge successfully and you find that the Hue Lights plugin doesn't support them in any of the device models, you can let me know the model ID (as shown in the Hue app) and whether it supports color and/or color temperature or just dimming, and I can add support to the plugin.
Re: Osram Lightify
Does the Hue plugin also support the OSRAM Smart + LED, ZigBee GU5.3-reflector?
I can see in the indigo log the following:
u'2021-03-17T21:17:51'}, u'uniqueid': u'7c:b0:3e:aa:0a:05:2a:ae-03', u'capabilities': {u'control': {u'ct': {u'max': 370, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 333}, u'manufacturername': u'OSRAM', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'MR16 TW OSRAM'}, u'27': {u'swversion': u'1.76.6', u'name': u'Computer 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-01-07T13:40:58'}, u'productid': u'Philips-LTG002-3-GU10CTv2', u'uniqueid': u'00:17:88:01:08:c6:bc:de-0b', u'capabilities': {u'control': {u'mindimlevel': 200, u'maxlumen': 350, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 73, u'ct': 303}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FC7A0E81', u'co
Thanks in advance.
Thanks in advance.
Re: Osram Lightify
Hi Nick.
Thanks for the report. I'll add support for that light in the next patch release.
Re: Osram Lightify
Version 1.7.47 Posted
- Added support for the Hue Single color table light.
- Added support for a new Hue Dimmer Switch.
- Added support for the Osram Smart + LED GU5.3 reflector.
- Added support for 2m and 5m Hue Outdoor Lightstrips.
- Added support for the Hue Amarant Wall Washer light.
- Added support for the Hue white candle dimmable bulb.
