Failed connection with Glow IHD/CAD
colinpartridge
I think I have followed the installation instructions for this plugin and the MQTT connector but I can't get to the connected state, showing disconnected 1. What is odd is that by using all the same connection settings I am able to subscribe to the correct topics using MQTT Explorer. Any thoughts on what I might be missing.
Colin
Colin
Re: Failed connection with Glow IHD/CAD
Colin,
I took a look at my working config vs the documentation and it does match, and as you say the connection settings are working. I just upgraded the MQTT connector just in case that made a difference, as I wasn't running the latest version.
This part just worked for me, have you tried turning on debugging in the MQTT connector ?
Neil
Neil
- FlyingDiver
Try this version: https://github.com/FlyingDiver/Indigo-M ... tag/0.4.10colinpartridge wrote:I think I have followed the installation instructions for this plugin and the MQTT connector but I can't get to the connected state, showing disconnected 1. What is odd is that by using all the same connection settings I am able to subscribe to the correct topics using MQTT Explorer. Any thoughts on what I might be missing.
Colin
I haven't pushed it to the Plugin Store yet.
colinpartridge
Hi Joe, I've just installed the new version without anymore success. If I turn on debugging and start the device i get the following:
But I also get a whole load of messages relating to other devices as well, and I don't know if this is normal. eg
This occurs when I turn on Marantz AV receiver..
Any pointers to what I have done wrong?
Colin
MQTT Connector GlowCAD: Starting Device
MQTT Connector Debug GlowCAD: Device is current version: 0
MQTT Connector Debug GlowCAD: Broker __init__ address = glowmqtt.energyhive.com, port = 8883, protocol = 4, transport = tcpCode: Select all
MQTT Connector Debug Marantz Dining Room: deviceUpdated: doExcludes = False, listedDevice = False
MQTT Connector Debug Marantz Dining Room: deviceUpdated: id = 1335276115, devList = published_devices : (list)
Colin
- FlyingDiver
That log just means the "Marantz Dining Room" device is updating multiple times. I don't know what that device actually is, so I can't say why it's doing that. But it's not anything wrong, specifically.
If you're actually getting an error, it's somewhere else in the log.
colinpartridge
...and relax.. Bit embarrased but the reason it wasn't working was a space after the username. Onwards!
Cheers
Colin
Cheers
Colin
- FlyingDiver
In the Connector plugin device login field? I should probably do a strip on those to get rid of leading and trailing spaces.colinpartridge wrote:...and relax.. Bit embarrased but the reason it wasn't working was a space after the username. Onwards!
colinpartridge
Hi Joe, yes I had cut and pasted my username into the login field, along with a space. Not the first time I've done that..FlyingDiver wrote:In the Connector plugin device login field? I should probably do a strip on those to get rid of leading and trailing spaces.colinpartridge wrote:...and relax.. Bit embarrased but the reason it wasn't working was a space after the username. Onwards!
Colin
colinpartridge
After the euphoria of getting the MQTT part going I now turned to the Historical data from the data. After setting up the GlowCAD plugin with my Bright Credentials and adding a daily Consumption device I don't get the "resource Type" field being populated, so I presume that I'm not getting connected to the API correctly , debug message isneilk wrote:Let me know how you get on, and if you want to see any more capability in the plugin. Be interested in your feedback.
Started plugin "GlowmarktCAD 0.0.13"
GlowmarktCAD Debug Starting device: GlowCAD
GlowmarktCAD Debug Starting device: new device 1
GlowmarktCAD Debug No update for new device 1
GlowmarktCAD Debug Updating device
GlowmarktCAD Debug Time remaining on token is 6 days, 21:35:58.035997
GlowmarktCAD Error exception in deviceStartComm(new device 1): 'key not found in dict'
GlowmarktCAD Debug Starting concurrent thread
Any thoughts?
BTW Thanks for putting the work into this plugin. I was reluctant to install a smart meter thinking that I would lose the ability to monitor energy usage as I wanted. But with this plugin and FlyingDivers MQTT work I felt more confident in doing it. Also Top marks for the Glowmarkt support, very impressed..
Colin`
Colin,
It looks like you are authenticated ok as it has picked up the token, and I validate the credentials in the plugin config screen so if you were able to successfully close it you should be connected to the API OK. A couple of questions :-
- Do you have a gas smart meter as well as electric (I have both so cannot test with just an electricity meter)
- Any other errors if you restart the plugin, or when you configure the consumption device
I will dig into the code as it has been a while, I may need to get a version for you with some specific logging if I cannot figure it out.
Apologies for this, it has only had a small number of users up until now.
Neil
Neil
colinpartridge
Absolutely no need to apologise. I have both Electric and Gas smart meters, here's the debug messages when I reload the plug-in. New device 1 is the daily consumption device I'm trying to set-up.
GlowmarktCAD Debug Time remaining on token is 6 days, 18:18:43.955717
Thanks - I now remember how this works. I think you already have debugging enabled, but if you do, and then you open and save the plugin configuration you should see something like this in the log
The error comes from the fact that the resource type is not being populated in the device configuration, which shouldn't happen. If you can try that (I am most interested in what follows the "Getting Resources" line.
You can obscure the token info and email addresses (I just noticed I hadn't and edited it)
Neil
GlowmarktCAD Debug <Response [200]>
GlowmarktCAD Debug {u'userGroups': [], u'isTempAuth': False, u'name': u'neil k', u'token': u'eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCxxxxxxxxxxxxxxxxxxTYxNTMyNTcwOH0.TTFqBPggCNNs8u67zaOodAWg0a9dAkh56u6oe2v1jmk', u'valid': True, u'exp': 1615325708, u'functionalGroupAccounts': [], u'accountId': u'5124xxxxxxxxxxxxxxxx5-2ad60cfb3c99'}
GlowmarktCAD Debug eyJhbGciOiJIUzI1NiIsInR5cCI6Ikpxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx2MTQ3MjA5MDgsImV4cCI6MTYxNTMyNTcwOH0.TTFqBPggCNNs8u67zaOodAWg0a9dAkh56u6oe2v1jmk
GlowmarktCAD Debug Token is eyJhbGciOiJIUzI1NiIsInR5xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxDgsImV4cCI6MTYxNTMyNTcwOH0.TTFqBPggCNNs8u67zaOodAWg0a9dAkh56u6oe2v1jmk
GlowmarktCAD Debug Expiry is 1615325708
GlowmarktCAD Debug Time remaining on token is 6 days, 22:59:59.591232
GlowmarktCAD Debug Getting Resources
GlowmarktCAD Debug gas.consumption
GlowmarktCAD Debug 53094110-6acd-48ed-ac75-ce7f071d4228
GlowmarktCAD Debug gas.consumption.cost
GlowmarktCAD Debug b8e6dd9d-47fc-4a90-8caf-3fe7b0670b86
GlowmarktCAD Debug electricity.consumption
GlowmarktCAD Debug 30b5fb84-ed2b-4df4-a8a4-0fc003996b81
GlowmarktCAD Debug electricity.consumption.cost
GlowmarktCAD Debug 49123e45-6597-46f5-a9b7-246384d425dbYou can obscure the token info and email addresses (I just noticed I hadn't and edited it)
Neil
colinpartridge
Following your instruction here's what I get when opening and saving plugin config..
Hope this helps
Colin
GlowmarktCAD Debug {u'userGroups': [], u'isTempAuth': False, u'name': u'Colin Partridge', u'token': u'eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJ0b2tlbkhhc2giOiI5YjRiNDRlNTJmNjllZjRjYTFjYTc2ODI0ZjNiN2NkOTM3ZGQ5MGU2ZGQzNTZhYzA3YjA0NDZlMDI2ZGVkMzA1Mjg4NzE1ZDNkZmFhODVlZDBhMzg5MzQ5MmJjMmQyN2YiLCJpYXQiOjE2MTQxxxxxxxxxxxxxxxxxx', u'valid': True, u'exp': 1615332008, u'functionalGroupAccounts': [], u'accountId': u'7e3f8c34-8091-41cd-xxxxxxxxxxxxc'}
GlowmarktCAD Debug eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJ0b2tlbkhhc2giOiI5YjRiNDRlNTJmNjllZjRjYTFjYTc2ODI0ZjNiN2NkOTM3ZGQ5MGU2ZGQzNTZhYzA3YjA0NDZlMDI2ZGVkMzA1Mjg4NzE1ZDNkZmFhODVlZDBhMzg5MzQ5MmJjMmQyN2YiLCJpYXQiOjE2MTQ3MjcyMDgsImV4cCI6MTYxNxxxxxxxxxxxxxxx2tcSuPmOdmTfdpqT7Avyq2H0jagQOM7ig
GlowmarktCAD Debug Token is eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJ0b2tlbkhhc2giOiI5YjRiNDRlNTJmNjllZjRjYTFjYTc2ODI0ZjNiN2NkOTM3ZGQ5MGU2ZGQzNTZhYzA3YjA0NDZlMDI2ZGVkMzA1Mjg4NzE1ZDNkZmFhODVlZDBhMzg5MzQ5MmJjMmQyN2YiLCJpYXQiOjE2MTQ3MjcyMDgsImV4cCI6MTYxNxxxxxxxxxxxxxxxx2tcSuPmOdmTfdpqT7Avyq2H0jagQOM7ig
GlowmarktCAD Debug Expiry is 1615332008
GlowmarktCAD Debug Time remaining on token is 6 days, 22:59:59.438495
GlowmarktCAD Debug 711d38b6-2eec-4b0f-90ba-73d4cedac788
GlowmarktCAD Debug 2a14bf9f-fa4b-47f4-b8b8-41051b93491f
GlowmarktCAD Debug 5ab57d58-0f0b-4cd5-9046-e98838a2b52b
GlowmarktCAD Debug 0a8dc568-2779-4940-9f57-3cabe27b664d
GlowmarktCAD Debug 1d55506e-bff6-4b1b-9aeb-1bf5afaf8574
GlowmarktCAD Debug b80fdf51-ce1e-4aa4-841e-cf29214c04b0
GlowmarktCAD Debug 6a8757fb-7e3e-414a-bbc1-04765ad9a5ed
GlowmarktCAD Debug d5fd145d-e7ed-4a2c-9956-fd6af4a5603a
Colin
colinpartridge
Morning Neil
Looking at the log I sent last night and the fact that its showing twice the number of resources that you were expecting it occurred to me that I have two CAD devices, one supplied by Bulb and one by Glowmarkt, both of which are hooked up to my bright App.
