Every time the Plugin reloads - all smartphones are "home"
Smartphone presence detection.
EagleDTW
Post by EagleDTW »
Hi Travis,
Love this plugin. Every time the Plugin reloads - all smartphones are seen as at "home". I'm wondering if there is a way to change this feature, or if I could grab the pid of the running instance and compare and set a timer for after xx number of minutes to have it actuate triggers instead of immediately after a reload and no presence truly detected.
Any thoughts on how this could be easily accomplished?
Thank you,
Daniel
Re: Every time the Plugin reloads - all smartphones are "hom
You can try the Fingscan plugin
It also uses fing info. Gives up/down/expired status for Ip devices
Return to “Smartphone Radar”
