I recently purchased both a v1 and v2 Ring Keypad to see if we could integrate them more closely with Indigo. First and foremost, the v2 keypad won't work reliably with Indigo because it seems to only support S2 Z-Wave security which Indigo doesn't yet support (it's a HUGE undertaking, which even other open source solutions have yet to do, but it is on our to do list for some future version).
I was fully intending to add direct support for the v1 keypad; unfortunately, now it seems to be unavailable (I guess I got lucky in getting one of the last ones), so it seems inappropriate to spend any significant time on it given that you can't easily buy one. In lieu of official support, I've put together this tutorial on how you can use the v1 keypad with Indigo's match raw packet event type.
How the v1 Keypad works
The v1 keypad works by sending packets to Indigo at various times when buttons are pressed. When you press a number key, it adds that key to a list. The keypad will continue to add numeric key presses to this list until one of several things happens:
- You stop pressing buttons and the timeout of 5 seconds (user adjustable via a config param) is up without pressing anything else.
- You press one of the non-numeric keys (Away, Disarm, Home,
, and X).
- You press 8 numeric keys.
Each of these scenarios are cases you can catch using the Match Raw Packet event type in Indigo, allowing you complete flexibility in setting up your own codes to trigger any action(s) Indigo can perform. Neat, huh?
Z-Wave Packet Description
The complex part of this solution is how to construct the match bytes for use in the Match Raw Packet event type. Let's look at an example, then explain what each bytes are important and how to match those. If you press:
1-2-3-4-5-6-✔️Code: Select all
Z-Wave Debug RCVD nonceFetch: node 027
Z-Wave Debug SENT nonceReport: 01 11 00 13 1B 0A 98 80 26 92 6C E5 4D B3 68 2C 25 F5 A3
Z-Wave Debug RCVD nonceReport: 01 05 00 13 F5 00 1C (node ACK)
Z-Wave Debug . . nonceReport: requeuing 1 unsolicited packets
Z-Wave Debug RCVD encryptedPacket: 00 6F 01 01 02 00 00 (decrypted)
Z-Wave Debug RCVD requestReply1: 01 0C 00 04 00 1B 06 6F 01 01 02 00 00 FF (hex)
Z-Wave Debug SENT nonceReport: 01 11 00 13 1B 0A 98 80 26 92 6C E5 4D B3 68 2C 25 F6 A0
Z-Wave Debug RCVD nonceReport: 01 05 00 13 F6 00 1F (node ACK)
Z-Wave Debug RCVD encryptedPacket: 00 6F 01 02 02 02 06 31 32 33 34 35 36 (decrypted)
Z-Wave Debug RCVD requestReply1: 01 12 00 04 00 1B 0C 6F 01 02 02 02 06 31 32 33 34 35 36 FF (hex)
01 12 00 04 00 1B 0C 6F 01 02 02 02 06 31 32 33 34 35 36 FFCode: Select all
31 32 33 34 35 36Here is a summary of the full byte string and what's important:
- bytes 1-9: will always be: 01 ? 00 04 00 1B ? 6F 01 (the second and seventh bytes seem to vary, but it's not relevant to our matching logic)
- byte 10: sequence or something (also not relevant to our matching logic)
- byte 11: always: 02
- byte 12: 01=Timeout, 02=
(Checkmark), 03=Disarm, 05=Away, 06=Home, 19=X(Cancel)
- byte 13: count of bytes directly following - corresponding to the number of numeric keys pressed
- byte 14-22: (list of digits pressed up to
30=0, 39=9 - last byte: always FF
0x01 ? 0x00 0x04 0x00 0x1B ? 0x6F 0x01 ? 0x02 0x02 0x06 0x31 0x32 0x33 0x34 0x35 0x36 0xFFHere's another example. If I press:
1-0-9-7Code: Select all
Z-Wave Debug SENT nonceReport: 01 11 00 13 1B 0A 98 80 54 C8 3A 75 9A 36 2A D5 25 FE AF
Z-Wave Debug RCVD nonceReport: 01 05 00 13 FE 00 17 (node ACK)
Z-Wave Debug SENT nonceReport: 01 11 00 13 1B 0A 98 80 17 75 D1 6B 29 8C 7D 3B 25 FF 15
Z-Wave Debug RCVD nonceReport: 01 05 00 13 FF 00 16 (node ACK)
Z-Wave Debug RCVD encryptedPacket: 00 6F 01 02 02 01 04 31 30 39 37 (decrypted)
Z-Wave Debug RCVD requestReply1: 01 10 00 04 00 1B 0A 6F 01 02 02 01 04 31 30 39 37 FF (hex)
T 4 1 0 9 7Code: Select all
0x01 ? 0x00 0x04 0x00 0x1B ? 0x6F 0x01 ? 0x02 0x01 0x04 0x34 0x30 0x39 0x37 0xFFCode: Select all
0x01 ? 0x00 0x04 0x00 0x1B ? 0x6F 0x01 ? 0x02 ? 0x04 0x34 0x30 0x39 0x37 0xFFIf you just want to catch any of the non-numeric keys (Away, Disarm, Home,
0x01 ? 0x00 0x04 0x00 0x1B ? 0x6F 0x01 ? 0x02 0x06 0x00 0xFFThat's it! You can now catch codes and keypresses from your keypad to fire Indigo Events. Use this in conjunction with the Homegrown Security System wiki article to build your own alarm system in Indigo.
