Glenn,
just published version7.123.423 that show show INPUT in status instead of INPUT_X.
Also device edit save needed some fixing.
==> you need to edit and save the devices
Thanks Karl
Installed - edit/save - status updating correctly..
D
1.
Thanks for the POE tip - great ideal as have a number of POE-micro-usb converters and plenty of Cat Cable.
Will get on and do now, despite the rain
2.
Mainly use the ADS1x15 sensors via
https://store.ncd.io/product/ads1115-16 ... ni-module/
More expensive, but plug and play with sensors from ali-express like this
https://www.aliexpress.com/item/3274949 ... 4c4d6XjVjX
Dropped to bottom of tank, calibrate reading and get live tank level updates to resolution of about 0.2 cm
So far the main water tank one has been running well for a few years, added another one recently to a 2nd tank.
(well actually to septic, tank to check level and alarm if over level...._
Thanks again
Glenn
1.
2.
Thanks again
Glenn
All good - user error!
Thanks again
Glenn
Thanks again
Glenn
just in case you missed that.. with the demise of wireless RFXcom pool temperature devices, here the first real alternative I found:
iBS03TP is a water tight temp sensor that has also an external temp sensor,
You could either place it outside the pool and let the probe hang into the pool, or put the device onto a pice of wood or anything that swims and let the external sensor hanging into the water.
It is a bluetooth sensor. It broadcasts updates every 30 secs. Similar to the ruuvitag sensor.
Fully supported by piBeacon. Temperature = temp in the sensor, ambient -= temp in the probe, battery level is calculated from the battery Voltage (0=2900mV, 100=3150mV+) You can get it from https://www.beaconzone.co.uk/sensor/iBS03TP or from alibaba : https://ingics.en.alibaba.com/product/6 ... probe.html
The battery should last for several month (web sites claim 2.5Y) it is a larger CR2450
and yes our pool is at 26C = 80F w/o heater .. one of the few the advantages of living in Dallas
And some picture how to do a floating pool temperature sensor with the iBS03TP w 2 Styrofoam plates glued together. The top part has the sensor cut out, the probe cable runs through the bottom part. As it is 2 meter long it is curled up so the at the señor is ~ 20cm under water..
And you should dip the metal end of the probe into "liquid tape" to make it not touch the chlorinated water directly
And the device as a whole is IP67: "it has been tested to work for at least 30 minutes while under 15cm to 1m of water. "
ps and you can set the sensor indicator to green/grey/red depending on temperature. set it in device edit( and when ever indigo offers more colors like blue for cold it will be added too)
Hi Karlkw123 wrote:just in case you missed that.. with the demise of wireless RFXcom pool temperature devices, here the first real alternative I found:
That actually looks really handie - always keen to find backup for pool temp monitoring. I have a deck surrounding one side of pool, including where leaf bucket is - so really easy to hide under deck and drop lead in.
Current using a rpi and a tmp102 sensor - I wired it, and then encased the whole sensor thing in epoxy resin. The clear stuff, part a, part B. That sits in leaf bucket running to rpi. So far now I think 2 years later still going strong. Tempted to upgrade to mcp9808 sensor (I think that is the right one) to get slightly better resolution..
Prior had a number of Pre-bought ‘waterproof’ sensors - they all failed after 6 months or so. Waterproof and constantly submerged in salt/chlorine probably quite different. But the epoxy sensor - so far so good!
Now to see if can find your one on AliExpress.... should be there if on alibaba...
Glenn
3 years of beacon etc testing
- Screen Shot 2020-10-06 at 10.57.40.png (495.75 KiB) Viewed 7092 times
- Screen Shot 2020-10-06 at 10.57.59.png (355.22 KiB) Viewed 7092 times
Hi Karl,
i have this error message in the log, can you please tell me where it comes from?
Where do I have to configure and what?
Second, I'm trying to reset the CO2 sensor, it's hanging in "HIGH".
I've tried to do one of the "manage sensor devices", but it's still on "HIGH".
How can I bring to back to "LOW"?
Loading plugin "piBeacon 7.128.460"
Starting plugin "piBeacon 7.128.460" (pid 68378)
piBeacon initializing ...
piBeacon path To files: =================
piBeacon indigo /Library/Application Support/Perceptive Automation/
piBeacon installFolder /Library/Application Support/Perceptive Automation/Indigo 7.4/
piBeacon plugin.py /Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/
piBeacon Plugin params /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.piBeacon/
piBeacon Warning !!!!INFO ONLY!!!! logger enabled for WARNING !!!!INFO ONLY!!!!
piBeacon Error !!!!INFO ONLY!!!! logger enabled for ERROR !!!!INFO ONLY!!!!
piBeacon Critical Error !!!!INFO ONLY!!!! logger enabled for CRITICAL !!!!INFO ONLY!!!!
piBeacon check /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.piBeacon/plugin.log <<<< for detailed logging
piBeacon Plugin short Name piBeacon
piBeacon my PID 68378
piBeacon set params for indigo V 7.4
Started plugin "piBeacon 7.128.460"
piBeacon myLogSet setting parameters -- logFileActive= standard; logFile= ; debug plugin:[] RPI#:-1
piBeacon testing if variable enableTimeTracking_piBeacon is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
piBeacon --V 7.128.460 initializing --
piBeacon Error Line 10431 has error=global name 'pIU' is not defined
piBeacon .. initialized, starting loop
Indigo Cocoa client disconnected
10.10.2020, 21:47:16
- Bildschirmfoto 2020-10-10 um 21.53.23.png (34.62 KiB) Viewed 7051 times
- Bildschirmfoto 2020-10-10 um 21.51.21.png (55.4 KiB) Viewed 7051 times
1. it should be piU, will post a fix later today
2. GPIO high .. I just tried mine, that works, could you post the device edit screen.. remember you need to first set each section, then confirm ... before you go to the next
should be fixed in v ..461
Thanks Karl,kw123 wrote:Line 10431 has error=global name 'pIU' is not defined
See screenshot of the "edit settings" of the sensor.
I have to say, that the sensor worked, one day with an update (can't remember when), the device was set to HIGH (the CO2 level wasn't critical) and since then it is staying on HIGH.
Can't reset it.
Yassi
- Bildschirmfoto 2020-10-11 um 09.33.21.png (84.93 KiB) Viewed 7049 times
You need to click on confirm then the next part is visible. There you set high low
Confirmed.kw123 wrote:You need to click on confirm then the next part is visible. There you set high low
Now, in which field(s)?
- Bildschirmfoto 2020-10-11 um 15.47.24.png (178.92 KiB) Viewed 7011 times
Pull up resistor or down or off
Is high low off
Is high low off
Nothing happens. Clicked on "Confirm"kw123 wrote:Pull up resistor or down or off
Is high low off
The state is also old. Since then it stays on HIGH.
- Bildschirmfoto 2020-10-11 um 16.06.00.png (19.01 KiB) Viewed 7000 times
- Bildschirmfoto 2020-10-11 um 16.04.24.png (72.57 KiB) Viewed 7002 times
