Ikea Trådfri bulb E26 WW 806lm
Mattias
Post by Mattias »
I bought a few Trådfri bulb E26 WW 806lm, and they work in the philips hue app, but does not show up in the plugin.
I have a few Hue devices that works perfect in the plugin. is this Ikea light added to the plugin,? If not, can I add it somehow?
(i don't have any other Ikea lights added, so I'm not sure how they should show up)
I copy/pasted the log, if it helps.
Hue Lights Debug Starting parseAllHueSensorsData.
Hue Lights Debug Starting updateSensorsList.
Hue Lights Debug Starting updateLightsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.85/api/UDFyfZnXQ4u4jeR ... LWu/lights
Hue Lights Debug Got response {u'3': {u'swversion': u'1.50.2_r30933', u'name': u'Trebenslampa', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T18:04:09'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:02:e9:f6:aa-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8410, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4574, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'B8000037', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'floorshade'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'2': {u'swversion': u'1.50.2_r30933', u'name': u'Hue entre vanster', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T18:04:13'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:70:da:00-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'B8000037', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'walllantern'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'4': {u'swversion': u'1.50.2_r30933', u'name': u'Vestibul1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T18:04:17'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:02:e9:af:d5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'B8000037', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'7': {u'swversion': u'1.50.2_r30933', u'name': u'Matbordet', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T18:04:27'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:70:d4:09-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'B8000037', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'pendantround'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'6': {u'swversion': u'1.50.2_r30933', u'name': u'Hue entre hoger', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T18:04:30'}, u'productid': u'Philips-LTW015-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:b1:0f:f8-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'72630961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'walllantern'}, u'type': u'Color temperature light', u'modelid': u'LTW015'}, u'9': {u'swversion': u'2.1.022', u'name': u'DimIkea1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-09-11T00:18:29'}, u'uniqueid': u'14:b4:57:ff:fe:41:a3:47-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Dimmable light', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'TRADFRI bulb E26 WW 806lm'}, u'8': {u'swversion': u'1.50.2_r30933', u'name': u'Vestibul2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T18:04:22'}, u'productid': u'Philips-LTW015-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:d0:be:f2-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'72630961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Color temperature light', u'modelid': u'LTW015'}}
Hue Lights Debug Loaded lights list - {u'3': {u'swversion': u'1.50.2_r30933', u'name': u'Trebenslampa', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T18:04:09'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:02:e9:f6:aa-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8410, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4574, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'B8000037', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'floorshade'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'2': {u'swversion': u'1.50.2_r30933', u'name': u'Hue entre vanster', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T18:04:13'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:70:da:00-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'B8000037', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'walllantern'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'4': {u'swversion': u'1.50.2_r30933', u'name': u'Vestibul1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T18:04:17'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:02:e9:af:d5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'B8000037', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'7': {u'swversion': u'1.50.2_r30933', u'name': u'Matbordet', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T18:04:27'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:70:d4:09-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'B8000037', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'pendantround'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'6': {u'swversion': u'1.50.2_r30933', u'name': u'Hue entre hoger', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T18:04:30'}, u'productid': u'Philips-LTW015-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:b1:0f:f8-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'72630961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'walllantern'}, u'type': u'Color temperature light', u'modelid': u'LTW015'}, u'9': {u'swversion': u'2.1.022', u'name': u'DimIkea1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-09-11T00:18:29'}, u'uniqueid': u'14:b4:57:ff:fe:41:a3:47-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Dimmable light', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'TRADFRI bulb E26 WW 806lm'}, u'8': {u'swversion': u'1.50.2_r30933', u'name': u'Vestibul2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-10T18:04:22'}, u'productid': u'Philips-LTW015-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:d0:be:f2-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'72630961', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Color temperature light', u'modelid': u'LTW015'}}
Hue Lights Debug Starting parseAllHueLightsData.
Hue Lights Debug parseAllHueLightsData: There are 7 lights on the Hue bridge and 9 Indigo devices controlling Hue devices.
Hue Lights Debug Starting updateGroupsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.85/api/UDFyfZnXQ4u4jeR ... LWu/groups
Hue Lights Debug Got response {u'1': {u'name': u'Matbord', u'lights': [u'7'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Entre', u'lights': [u'9', u'6', u'2'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Groventre', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Front door'}, u'5': {u'name': u'Solrum', u'lights': [u'3'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8410, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4574, 0.41], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'4': {u'name': u'Vestibul', u'lights': [u'8', u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}}
Hue Lights Debug Loaded groups list - {u'1': {u'name': u'Matbord', u'lights': [u'7'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Entre', u'lights': [u'9', u'6', u'2'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Groventre', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Front door'}, u'5': {u'name': u'Solrum', u'lights': [u'3'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8410, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4574, 0.41], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'4': {u'name': u'Vestibul', u'lights': [u'8', u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}}
Hue Lights Debug Starting parseAllHueGroupsData.
Trigger wemos
Hue Lights Debug
nsheldon
Re: Ikea Trådfri bulb E26 WW 806lm
Post by nsheldon »
Thanks for the report and the debug logs. Those were exactly what I needed. I'll add support in the next release, due any day now.
nsheldon
Post by nsheldon »
Version 1.7.35 Posted
  • Added support for the Quotra-Vision RGB + warm/cool white light strip.
  • Added support for version 4 of the Hue LightStrips Plus.
  • Added support for the Innr SP 224 on/off plug.
  • Added support for the IKEA TRADFRI E26 WW 806lm dimmable light.
Mattias
Post by Mattias »
I just tested it, and it works. Incredible fast response from you! Thanks.
nsheldon
Post by nsheldon »
Excellent! Glad it’s working.
Locked
Return to “Archives”
