UniFi WiFi AP: download
Re: uniFi WiFi AP: download
v 7.30.241
should hopefully fix the "debugLeve" error
the line # in the error messages threw me off, that was actually not the line where the error occurred
Also added more logging in case the login does not work.
It will show you the curl command that does not work - w full userid and password ip# etc ..
posted v7.30.244
changed options in config to better explain the options for std vs UDM vs UDM pro
no functional changes, only text in config
also elevated the UDM-non pro writeup ( by evansgo) to "announcement", to make it more visible
posted v7.30.246
for UDM/UDMpro/std controller type
To ease the confusion, in plugin config a button (set parameters) was added that should cover 90% of the config changes between
std / UDM / UDM pro settings will be set to the default settings for these controller types ie:
unifiCloudKeyMode
unifiCloudKeyPort
unifiApiLoginPath
unifiApiWebPage
ControllerBackupPath
UDM on off
You still can change any parameter to your liking
no functionality changes
unifiCloudKeyMode
unifiCloudKeyPort
unifiApiLoginPath
unifiApiWebPage
UDM on off
- Screen Shot 2020-05-24 at 22.49.16.png (18.66 KiB) Viewed 12885 times
posted v 7.30.247
fixed port # in "set parameters" button from 8433 to 8443
and some typos fixed
no change in functionality
7.31.262 now finally creates a gateway device for UDM(pro)
I should also show 3 temperature values
It took some help from UDM pro users and a lot of ping pong debugging.
Thanks to Wouter, Kyle and Gareth
ps
error was:
if xx["ip"] .. through an error as "ip" was not in xx
but the exception had a if len(e) < 5: ignore, so it did not show any error message
Added that as a plugin reload sometime throws an error "none", which is not an error.
In order to suppress that, I added len(e)..but len("ip") is < 5..
should be >> if unicode(e) =="none": ignore <<
ps
error was:
changes in V 7.32.270 @ 2019-07-23
1. requesting AP info from UDM only not UDM-pro
2. added support for info for multiple vlans in AP
3. added nClients as dev state for switches, == sum of clients connected exluding upstream
4. added check if gateway is connected to a port, (name nmust have gatew or udm in its string) Case does NOT matter
the it added "Gw" to the port_xx dev state
5. added client list for GHZ channel on AP. these are the hostnames given by the AP, not the indigo device names
6. fixed LED .. commands, was switched to PUT, should be GET for regular gateways, not for UDM
7. added option to count clients on downlink ports and AP ports in switch client totals (nClients)
changes in V 7.33.275 @ 2019-08-12
1. added dev/states for gateway device:
wan2 (==up/down), MACwan2 = mac # of wan2
use dev/states wan2 =="up" and wan=="down" to trigger wan failover
use dev/states wan =="up" and wan2=="down" to trigger wan failover end
=== this currently only works for standard security gateway NOT for UDM/UDM-pro
need "mca-dump" output from the UDM system when in normal state and when in failover, to set it up
changes in V 7.33.283 @ 2019-08-14
support of wan2 failover, load balancing ... device states in indigo-unifi gateway device
thanks go to Mark for patiently testing this feature
wan2 = up/down if 2. wan port is active
wan2Latency = same as for wan
wan2Upload= same as for wan
wan2Gateways= same as for wan
wan2Nameservers= same as for wan
wan2PublicIP= ip number of wan2 if wactive
wanSetup = "wan1 only" if normal single wan active
"failover" if wan2 active and wan 1 down
"load balancing" if both wan1 and wa2 are active
"wan down" if both wan connections are down
this is tested with std UniFi gateways, should also work for UDM-pro but not for UDM as it does not have a second wan port
in case of failover the state values for publicIP nameservers and gateways can be set to == the wan2 value or not change
if you would like to keep eg publicIP as your defined public ip number. if set to copy the wan2 values will be used to overwrite the wan xxx values.
changes in V 7.33.285 @ 2019-10-05
fixed all "{}".format(dev.name.encode("utf8")) to u"{}".format(dev.name)
should fix errors with umlauts in device names
Just got a UniFi Access Point Flex HD, works w the plugin as a std AP, no problems so far. Setup in config like any other AP.
They really look nice and can be put in straight sight
https://unifi-flexhd.ui.com
changes in V 7.33.290 @ 2019-10-21
1. added config optiuon to set folder name for unifi variables
up to now: it used the folder where other variables where
now you need to set it in config.. default is UNIFI
changes in V 7.33.303 @ 2019-12-23
1. prompt for expect ssh to unifi devices is now fully auto detect
no need to enter in config
2. removed options for log messages mca-dump commands in config, no need to chnage anything.
3. cleaned up some logging formats
4. changed number to float for dev states temperature in prep for indigo 7.5
4. cfixed issue w reset of AP-log message listener killing the DB dict listener
this version should be used after you upgrade your unifi gear to the dec 2020 release, several unix prompts have changed
the indigo plugin store does currently not download the new version from githuib.. here the link:https://github.com/kw123/unifi/releases/tag/v7.33.303
and thanks to Brian for testing
and Merry Christmas, Chanukah, .. to everyone
changes in V 7.34.308 @ 2021-01-20
1. added support for new unifi op system for controller os v 6.x ++
eg UDMpro has unifi ops sys, but also genx cloud key can be upgraded to v 6.
most reports work, but not stat reports (daily ,...)
2. will now autodetect the controller ports and login and api web pages,
no config setup required for:
ie 8443/ 433; /proxy/network/api/s/ vs /api/s; /api/auth/login vs /api/login
hope that helps..
hope that helps..
changes in V 7.35.322 @ 2021-02-11
1. now all "post" functions work for the new unifi op-sys v 6.x. ("get" worked fine)
eg set AP-led on/off
get wan / ap stats
etc
this took >>> 6 months to figure out
get wan / ap stats
etc
changes in V 7.35.324 @ 2021-02-12
1. added rx_Bytes_last5Minutes and tx ... to unifi client dev states
- this gets updated once every 5 minutes and shows the # of bytes as integer
time bins are 0-5 5-10 ... minutes
if eg time is 12:07 it shows the bytes from time bin 12:00-12:05
the dict returned by unifi has RX and TX flipped. It is corrected in the plugin.
