Error "Not authorized to send Apple events to Messages"
- matt (support)
- Site Admin
- Contact:
Re: Error "Not authorized to send Apple events to Messages"
Did you see and follow the steps in my post above?
Yes, sorry, forgot to mention, but no popup (of course I replaced Spotify with Messages)
- matt (support)
- Site Admin
- Contact:
Okay, I'm not sure what else to suggest but I do believe we have this working better in the next release of Indigo (7.4.2 or 7.5.0). I don't yet have an ETA as to when it will be available, unfortunately.
Hello,
Does anybody has been able to make this work? I'm using Mojave but getting the following when trying to send a message:
Jul 7, 2020 at 12:36:21 AM
Action Group Send iMessage Test
iMessage Plugin Debug sendImsg() method called.
iMessage Plugin Debug sendImsg() buddyHandle:[email protected] and theMessage:Testosterona and use lastBuddy:False
iMessage Plugin Debug as_sendmessage() method called.
iMessage Plugin Debug Sending iMsg:Testosterona to Buddy/User:[email protected]
iMessage Plugin Debug A error of type :ScriptError occured. The longer message is :Not authorized to send Apple events to Messages.
iMessage Plugin Error An Error occured within the iMsg AppleScript component - ScriptError
iMessage Plugin Error The Error was :Not authorized to send Apple events to Messages. (-1743) app=u'Messages' range=103-105
iMessage Plugin Error Caught Exception:
File "plugin.py", line 1184, in sendiMsg
self.as_sendmessage(buddyHandle, theMessage)
File "plugin.py", line 462, in as_sendmessage
reply = my_ascript_from_string.run()
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/applescript/__init__.py", line 90, in run
return self._unpackresult(*self._script.executeAndReturnError_(None))
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/applescript/__init__.py", line 65, in _unpackresult
raise ScriptError(errorinfo)
ScriptError: Not authorized to send Apple events to Messages. (-1743) app=u'Messages' range=103-105
Any news so far?
PP
Any news so far?
PP
- matt (support)
- Site Admin
- Contact:
Did you try the steps mentioned earlier in this thread? You'll want to replace "Spotify" with "Messages".
Hi Matt,
Yep... tried creating the script
Then running from an action group but no pop up... but the good news is, while I was typing this reply, I gave it another try with:
It gave me an error but opened the pop up... now it is working.
Did something similar with iTunes local control:
And it worked as well in my Mojave.
Regards,
PP
tell application "Messages"
end tellCode: Select all
set theBuddy to buddy "[email protected]" of service "iCloud"
send "Hi there" to theBuddy
end tellDid something similar with iTunes local control:
tell application "iTunes"
set sound volume to 40
set EQ enabled to true
play
end tellRegards,
PP
- jay (support)
- Site Admin
- Contact:
Yeah, sorry, this was my bad. I discovered that you have to actually have the app do something before the workaround above works correctly. I was going to update the post (which I have now) but it just slipped my mind.
philipbasile
Awesome !
Worked.
Worked.
- matt (support)
- Site Admin
- Contact:
Indigo 7.5 is now available and should avoid this macOS security snafu.
