Invalid grant error
Invalid grant error
   Starting plugin "Ring 1.7.6" (pid 42446)
   Started plugin "Ring 1.7.6"
   Ring Debug                      Startup called
   Ring Debug                      Connected to Ring.com API?: False
   Ring                            Attempting to connect to Ring.com API and login as [email protected]
   Ring                            Connection to Ring.com API successful
   Ring Debug                      Getting events and device states from Ring.com API
   Ring Debug                      Error while trying to update devices from Ring.com API: InvalidGrantError(u'(invalid_grant) token is invalid or does not exists',)
   Ring Error                      Connection error - pausing for 30 seconds before retrying (error: (invalid_grant) token is invalid or does not exists)
May 23, 2020 at 10:18:43 AM
   Ring Error                      plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   Ring Debug                      Connected to Ring.com API?: True
  Ring                            Retrieving all available devices from Ring.com (this may take a moment, please be patient)
   Ring Error                      Error in plugin execution MenuAction:
  File "plugin.py", line 480, in printAvailableRingDevices
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/RingForIndigo.indigoPlugin/Contents/Server Plugin/ring_doorbell/__init__.py", line 75, in stickup_cams
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/RingForIndigo.indigoPlugin/Contents/Server Plugin/ring_doorbell/__init__.py", line 46, in devices
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/RingForIndigo.indigoPlugin/Contents/Server Plugin/ring_doorbell/__init__.py", line 40, in query
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/RingForIndigo.indigoPlugin/Contents/Server Plugin/ring_doorbell/auth.py", line 92, in query
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/RingForIndigo.indigoPlugin/Contents/Server Plugin/ring_doorbell/auth.py", line 54, in refresh_tokens
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/RingForIndigo.indigoPlugin/Contents/Server Plugin/requests_oauthlib/oauth2_session.py", line 446, in refresh_token
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/RingForIndigo.indigoPlugin/Contents/Server Plugin/oauthlib/oauth2/rfc6749/clients/base.py", line 421, in parse_request_body_response
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/RingForIndigo.indigoPlugin/Contents/Server Plugin/oauthlib/oauth2/rfc6749/parameters.py", line 431, in parse_token_response
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/RingForIndigo.indigoPlugin/Contents/Server Plugin/oauthlib/oauth2/rfc6749/parameters.py", line 438, in validate_token_parameters
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/RingForIndigo.indigoPlugin/Contents/Server Plugin/oauthlib/oauth2/rfc6749/errors.py", line 405, in raise_from_error
InvalidGrantError: (invalid_grant) token is invalid or does not exists
dssinger
Re: Invalid grant error
Post by dssinger »
I had a similar problem and worked round it like so:
* Logged onto ring.com and turned of SMS authentication.
* Logged out.
* Erased the token at /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.thebenzes.zachbenz.indigoplugin.ringforindigo.token
* Started the plugin and selected "Configure"
* Erased the password and pasted it back in.
* Hit "Save" - even though I'd turned off SMS authentication, the plugin still needed a code.
* Went back to a browser and logged into Ring
* It sent a code to my email address.
* Used that code in Indigo
and it seems to work.
Return to “RingForIndigo”
