iBeacon shows as expired but it's not
Re: iBeacon shows as expired but it's not
does your RPI have a single ip#?
!!! If not, no guarantee what so ever!!!
That will screw things up big time, constant switching, expiring ...
johnfdl
Post by johnfdl »
Yes, it has a single IP. I included the ifconfig in a previous post showing it had just one IP after I disabled the wireless.
Ok could you do debuglog all in config
And post plugin.log
Mask the passwords
johnfdl
Post by johnfdl »
rPi and Beacon is currently showing up. Here's the log;
logsnip.txt
(101.88 KiB) Downloaded 218 times
There is still a connect problem
What is your connection speed. Do a ping
johnfdl
Post by johnfdl »
Johns-MacBook-Pro-3:~ johndeluca$ ping 192.168.0.43
PING 192.168.0.43 (192.168.0.43): 56 data bytes
64 bytes from 192.168.0.43: icmp_seq=0 ttl=64 time=2.603 ms
64 bytes from 192.168.0.43: icmp_seq=1 ttl=64 time=6.065 ms
64 bytes from 192.168.0.43: icmp_seq=2 ttl=64 time=1.432 ms
64 bytes from 192.168.0.43: icmp_seq=3 ttl=64 time=3.656 ms
64 bytes from 192.168.0.43: icmp_seq=4 ttl=64 time=2.349 ms
64 bytes from 192.168.0.43: icmp_seq=5 ttl=64 time=1.453 ms
64 bytes from 192.168.0.43: icmp_seq=6 ttl=64 time=1.353 ms
64 bytes from 192.168.0.43: icmp_seq=7 ttl=64 time=12.735 ms
64 bytes from 192.168.0.43: icmp_seq=8 ttl=64 time=2.144 ms
64 bytes from 192.168.0.43: icmp_seq=9 ttl=64 time=2.220 ms
64 bytes from 192.168.0.43: icmp_seq=10 ttl=64 time=12.672 ms
64 bytes from 192.168.0.43: icmp_seq=11 ttl=64 time=2.344 ms
64 bytes from 192.168.0.43: icmp_seq=12 ttl=64 time=2.206 ms
64 bytes from 192.168.0.43: icmp_seq=13 ttl=64 time=3.668 ms
64 bytes from 192.168.0.43: icmp_seq=14 ttl=64 time=2.174 ms
64 bytes from 192.168.0.43: icmp_seq=15 ttl=64 time=1.993 ms
64 bytes from 192.168.0.43: icmp_seq=16 ttl=64 time=2.494 ms
64 bytes from 192.168.0.43: icmp_seq=17 ttl=64 time=2.235 ms
64 bytes from 192.168.0.43: icmp_seq=18 ttl=64 time=6.399 ms
64 bytes from 192.168.0.43: icmp_seq=19 ttl=64 time=12.955 ms
64 bytes from 192.168.0.43: icmp_seq=20 ttl=64 time=2.255 ms
64 bytes from 192.168.0.43: icmp_seq=21 ttl=64 time=1.658 ms
64 bytes from 192.168.0.43: icmp_seq=22 ttl=64 time=1.174 ms
64 bytes from 192.168.0.43: icmp_seq=23 ttl=64 time=3.698 ms
64 bytes from 192.168.0.43: icmp_seq=24 ttl=64 time=2.184 ms
^C
--- 192.168.0.43 ping statistics ---
25 packets transmitted, 25 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 1.174/3.845/12.955/3.529 ms
Note: MacBookPro is connected via Wifi | rPi is ethernet connected.
so it is not speed.
there must be some other messages in your logfile
could you restart the plugin?
and which version are you running?
johnfdl
Post by johnfdl »
Karl,
I ordered two Nonda iHere beacons from amazon. They are coming tomorrow. Let me experiment with them to be sure I don't just have a beacon that has gone bad. If I have the same trouble, I'll re-engage you....but I don't want to drag you down a rathole if it's just a bad beacon.
The rPi has been up since yesterday.
Just FYI: Beacons stop pinging when the iPhone app is running
johnfdl
Post by johnfdl »
Yes....I am aware of that. I killed the app on my phone. New Beqcons arrived today and appear to be working properly....so perhaps the Beacon is the issue.
just FOI- the beacon that does not work: what kind of beacon is it?
johnfdl
Post by johnfdl »
Nonda iHere (triangle usb). It worked fine for years, but seems to have gone bad. My two new Nonda iHere beacons have been flawless now for a week.
when you charge it does it go green?
johnfdl
Post by johnfdl »
Yes, it does go green, so it's not that it is dead.
You could try the iHere app to revitalize it
Don’t forget to stop the app once you are done.
Return to “piBeacon”
