Thank you for creating this plugin! It's been working well until recently. I opened Indigo and noticed a sea of red in the log. Here's a snippet of what is being returned. I did notice an update to the MyQ iOS app in the last couple days. Could Chamberlain have changed the backend to cause a conflict?
MyQ Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
MyQ Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 78, in runConcurrentThread
File "plugin.py", line 394, in getDevices
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/models.py", line 816, in json
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/__init__.py", line 307, in loads
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/decoder.py", line 335, in decode
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/decoder.py", line 353, in raw_decode
ValueError: No JSON object could be decoded
MyQ Plugin Now Returns an Error
- FlyingDiver
Re: MyQ Plugin Now Returns an Error
Something changed on the MyQ servers again. It'll be broken until an update to the library I use is posted.
- FlyingDiver
Release 7.5.0 on the store...
Thanks for rolling out the fix so quickly!
My Plugins and Scripts
Fantastic, thanks a lot!
Indigo 7.1.1, OS 10.14.6, MacMini .3.2 GHz 6 Intel Core i7, 64 GB ram
Works like a charm! Thanks!
Thanks for your hard work.
