Adapters Plugin [archive]
Open source plugin that allows you to create devices which translate/transform values from other devices (Fahrenheit to Celsius for instance).
Korey
Re: Adapters Plugin
Post by Korey »
howartp wrote:Matt/Jay, i'm intending publishing a new Nissan Leaf plugin (also Dusty's).
Dusty has touched his github account twice in the last 18 months, so obviously isn't active anywhere at present.
Can I takeover his plugin(s) - Nissan Leaf and Adapters certainly, to post up this fixed version? Not sure if he has others?
Peter
Any news on this?
I use the Adaptor plugin for a bunch of conversion, but I find it will stop updating every so often and will require a reload of the plugin to make it function again.
Korey
matt (support)
Re: Adapters Plugin
Post by matt (support) »
I found another/different email address we had for dustysparkle and just sent him another message. I'll let you know when/if I hear back from him.
bsp9493
Re: Adapters Plugin
Post by bsp9493 »
Hi...
I have been seeing the following in my logs recently...
Is this being caused by the Adapters Plug in, or is my device that's feeding it causing the problem? This is the only error message that I am receiving and when I check my source device, everything appears to be ok.
Thanx in advance.
dave
   Adapters Error                  Error in plugin execution ServerReplacedElem:
  File "plugin.py", line 130, in deviceUpdated
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/sensor_adapter.py", line 39, in go
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/pyrescaler/pyrescaler.py", line 103, in format
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/pyrescaler/pyrescaler.py", line 106, in convert
ValueError: could not convert string to float: ----.-
DaveL17
Re: Adapters Plugin
Post by DaveL17 »
For some reason, the plugin is expecting a float value (decimal number) but is getting a string (text) instead. If this was working without error at one point, then either the plugin code has changed or the source data has changed types. If you're using a custom formula adapter, you may be able to solve the problem by changing 'x' in the formula to 'float(x)', but that solution is untested.
My Plugins and Scripts
bsp9493
Re: Adapters Plugin
Post by bsp9493 »
Thanx Dave...
I have 2 custom and 1 standard Predefined scale (temperature, F to C).
I have changed the custom ones to "float(x)" as you suggested, will see what happens.
Strange, it's intermittent and nothing has changed with the devices that I am using with them that I am aware of.
Will keep an eye out.
d
bsp9493
Re: Adapters Plugin
Post by bsp9493 »
If it helps... I turned on debug after I made those changes... this is what popped up in the a few mins after the change.
Adapters Debug                  ws1401ip variables['solarRadiation'] {0:.1f} units: 41.2 units
   Adapters Debug                  ws1401ip variables['UV'] {0:.1f} units: 41.9 units
   Adapters Debug                  resulting format with precision applied: {0:.1f} {1}
   Adapters Debug                  formatted result: 17.8 °C
   Adapters Debug                  ws1401ip variables['outdoorTemp'] °F -> °C: 17.8 °C
   Adapters Debug                  formatted result: 18.1 °C
   Adapters Debug                  ws1401ip variables['outdoorTemp'] °F -> °C: 18.1 °C
   Adapters Debug                  ws1401ip variables['solarRadiation'] {0:.1f} units: 47.5 units
   Adapters Debug                  ws1401ip variables['UV'] {0:.1f} units: 47.5 units
DaveL17
Re: Adapters Plugin
Post by DaveL17 »
Looks like it may be working then, yes?
ckeyes888
Re: Adapters Plugin
Post by ckeyes888 »
Just need to remove the decimal from my Davis temp device. 72.1 - 72
Maybe the plugin can do that?
Carl
DaveL17
Re: Adapters Plugin
Post by DaveL17 »
Yes. That's precisely what it was meant to do. :)
ckeyes888
Re: Adapters Plugin
Post by ckeyes888 »
Thanks Dave. Maybe a tip on how to do that?
Seeing a lot of formulas I don’t understand.
Carl
DaveL17
Re: Adapters Plugin
Post by DaveL17 »
Sure! No need to use a custom formula.
  1. Create a new Adapters device.
  2. Select Predefined Scale Adapter.
  3. Select the source sensor device.
  4. Select Scale Type: Temperature
  5. Native Scale: Fahrenheit (or choice)
  6. Desired Scale: Fahrenheit (or choice)
  7. Precision: 1 (zero decimal places)
That's it. Then use the Adapters device instead of the source device for displaying on control pages and so forth. If you want to do something more creative later (that requires a formula) I'm happy to help with that, too.
ckeyes888
Re: Adapters Plugin
Post by ckeyes888 »
Perfect...thanks a bunch!
Carl
DaveL17
Re: Adapters Plugin
Post by DaveL17 »
No problem!
ckeyes888
Re: Adapters Plugin - Issue Removing Decimal
Post by ckeyes888 »
Tried the settings you mentioned but am still getting the decimal.
Missed something? Still returns 43.1
Carl
ckeyes888 wrote:Tried the settings you mentioned but am still getting the decimal.
Missed something? Still returns 43.1l
Set "Precision" to 0.
Locked
Return to “Adapters”
