Timed Devices plugin
Re: Timed Devices plugin
It sounds right to me.
Is there not an Action for the running timer, to reset it?
Yes, Running Timer is the correct device type to do this. In addition to this hour, day week, month, the device will provide the total for each of the prior 24 hours, 7 days, 4 weeks, and 1 year.welchgregusa wrote:Does anyone (kmarkley?) know whether the Running Timer is the appropriate (best) option? I'd like to know how long the valve was open today, this week, this month, etc. A Running Timer seems like the right one.
There is no way to reset the count. Not sure what the use case is as it could potentially delete quite a lot of data.welchgregusa wrote:Assuming so, does anyone know if there is a way to reset the running count? I can't find any way to do so.
I suppose there could be a new, additional field to store running time since the last reset (and a reset would only clear this one field)...
Hi Kmarkley
I'm helping @farberm on another topic viewtopic.php?f=107&t=23484
We're trying to count activity within a period (hour, day).
Your activity timer should do it, if we set:
However the plugin is still extending the timer when any true input is received, regardless of the setting of the Always Extend checkbox.
Can you have a look?
Peter
- Threshold to a high number (9999)
- Reset timer: 1 hour
- Off timer: Irrelevant
- Always Extend: Unchecked
Peter
Hi howartp.
The original purpose of the that device type is to infer continued activity from intermittent inputs. So the 'always extend' check box refers to the primary timer that switches the device back off after a period of inactivity and not the secondary timer used to decide when to turn the device on.
For example, say the device requires 3 pulses within 5 minutes to turn on and then turns off after an hour. If a pulse is received 15 minutes after turning on, 'always extend' determines if the device should turn off in 45 minutes (an hour after first turning on) or in an hour (an hour after this new pulse).
To have this setting also affect the reset timer would have adverse results. For example, suppose pulses were received at 0, 4, 6, and 8 minutes. The last three pulses were within 5 minutes and should turn the device on, but would not do so if the timer expired at the 5 minute mark.
It would possible to create a second, similar setting that only affects the reset timer, but I'm not sure that would really make this the best device type to use in your situation. I think your idea of a generic counting plugin makes more sense. There's a case to be made that it would be easy to roll this into my plugin by making what is essentially a cross between the Activity Timer and Running Timer device types. But it's different enough in purpose (i.e. not actually a timer) that it would probably be better in its own plugin.
Hi kmarkley,
I updated to the latest version of the plugin and one of my Threshold Timers is no longer working. Here's a screenshot of the config for that device. I reverted to the previous version and it's working again.
- Screen Shot 2020-03-29 at 4.13.40 PM.png (223 KiB) Viewed 6912 times
Hi vtmikel.
I set up a timer like yours but am unable to reproduce the issue. It what manner is it not working?
Sorry for the delay.
The device I took a screen shot of was a device I had set up using your plugin under a past version, and is now not working.
To test, I also created a new device, using the exact same setup. I notice that I get an error that "count out of sync [count:-1, max:1]" on the freshly created device. It also never turns "ON". In my test case, it is a threshold timer set to Sonos speaker's ZP_STATE, which is the field where it will say "PLAYING" if the Sonos is playing. Under the new version of the plugin, it does not turn on (the legacy threshold device, as well as the newly created device). On the past version of the plugin, it does trigger to on when the Sonos is playing, and begins a countdown to turn off based on the threshold amount. I use this to avoid unnecessary triggers during short pauses in my music.
Not sure what else to provide to reproduce?
Sorry for my delay as well.
Unlike the other device types Threshold Timers keep an internal tally of your tracked device state and the error you are getting indicates that it is getting out of sync with the Indigo Server. Usually this a communication error and it will get back in sync after the error message. I don't understand why it keeps recurring in your case.
Please try the following:
- disable the countdown timer if enabled
- turn on debugging
- toggle the device state you are tracking from PLAYING to something else and then back again
- disable the timer device
- change the device state you are tracking (only one direction)
- enable the timer device
- toggle the device state you are tracking (both ways)
- post what you get in the log
- turn on debugging
Scratch all that. I think I figured out what was wrong.
Please try new plugin version on github here: https://github.com/kmarkley/Indigo-Time ... tag/0.0.25
Installed the latest, got these errors:
Apr 26, 2020 at 1:08:56 PM
Reloading plugin "Timed Devices 0.0.25"
Stopping plugin "Timed Devices 0.0.25" (pid 96337)
Stopped plugin "Timed Devices 0.0.25"
Starting plugin "Timed Devices 0.0.25" (pid 19951)
Started plugin "Timed Devices 0.0.25"
Z-Wave received "Master Bathroom Motion Sensor" status update is on
Timed Devices "Master Bathroom Presence" on
Script auto_lights script for Zone 'Master Bathroom': processing change to Master Bathroom Motion Sensor (action reason: the requisite conditions have been met: presence is detected for a OnOffZone, the zone is dark, and we are NOT using Timed Brightness Mode) :
Script turning on 'Master Bathroom Vanity Lights'
Timed Devices Debug Debug logging enabled
Apr 26, 2020 at 1:09:40 PM
Z-Wave received "Master Bedroom Closet Motion Sensor" status update is off
Timed Devices Error "Upstairs Presence" thread error
global name 'rawVal' is not defined
File "plugin.py", line 454, in run
self.devChanged(arg1,arg2)
File "plugin.py", line 494, in devChanged
.format(self.name, newDev.name, stateKey, rawVal, type(rawVal), boolVal))
NameError: global name 'rawVal' is not defined
Timed Devices Error "Upstairs Presence 2 device threshhold" thread error
Timed Devices Error "Master Bedroom Presence Extended" thread error
Timed Devices Error "Master Bedroom Presence" thread error
Sorry, got ahead of myself.
Turn off verbose debugging and see if that works. If so, I'll release a new version that fixes this new error.
Hi there-
Turning off verbose removed the crashes. And, the Threshold Timer that I previously had trouble with is now working. However, an Activity Timer that was previously working is not, I've attached the screenshot for the device config. No significant information in the Log to share, and I can see that the state value for the device I've attached to the Activity Timer is changing, but the device is not triggering.
- Screen Shot 2020-04-26 at 5.06.38 PM.png (169.8 KiB) Viewed 6762 times
Working well so far.. thanks for your attention to this! Great plugin!kmarkley wrote:Please try this: https://github.com/kmarkley/Indigo-Time ... tag/0.0.26
I know this is going to be simple, But...
I want to know how long my HVAC ran today.
I found the Timed Devices Plugin and it's "Running Timer. I set it up to run when when the AC is on (living in AZ it runs a LOT)
I can see the time in the state field going up as it runs! Perfect. I would like to email be the run time at midnight.
I can't figure where to convert the state to a variable to email it
Can someone point me in the correct direction
Bob Ross
Bob Ross
