Pulse Counting
Discuss Python scripts here.
farberm
Pulse Counting
Post by farberm »
I am in need of some help setting up pulse counting to determine the hourly and daily water usage. I currently have a water meter that outputs 2 pulses per gallon and the output is connected to an Insteon 2450 i/O Linc. I know is is connected correctly as the light flashes when water is being used. What I would like to do is be able to set up a script to track the water usage hourly and daily and display it in a format similar to the following (see image) When entering a date it display the hourly amounts at the top graph and the daily for the month below.
I'm kind of new to using python and would need some help getting started and how to accomplish this. I have search online but did not really find anything. One option is to use Grafana but I still need to log the hourly and daily amount and store the data. That is the first part of the project. Once that is completed then I can work on the display options.
The graphic comes from a device called irrigation caddy. Mine is starting to fail and no longer reliable. I am not sure how to hack the web interface to determine how things are scripted. If someone can tell me how to do that then that would also be a solution.
Screen Shot 2020-01-14 at 10.31.36 PM.png (82.8 KiB) Viewed 3677 times
howartp
Re: Pulse Counting
Post by howartp »
I think my starting point would be the Timed Devices plugin, which has a few different device types. I think the Activity Tracker will be the one you want; one for hourly and one for daily.
Then you just need a trigger and script to store the value into a variable just before it resets, to maintain your historical data.
The Device Variable plugin will optionally collate the variables into one device for viewing in the UI.
Then either of the graphing plugins should be able to display your history for you.
farberm
Re: Pulse Counting
Post by farberm »
Thanks for your reply. I have set up two Timed devices (hourly, daily). Threshold set to 1, reset hourly or daily, off timer=0
Not sure how to go about setting up a trigger and script to store value before it resets.
I created two variablesHourlyUsage and DailyUsage
Create Schedule for every 60 min Insert Device State of Hourly Timed Device (counting) into HourlyUsage Variable
Create Schedule for every 24 hours Insert DEvice State Daily Timed Device (Counting) into DailyUsage Variable
Do you think this should work?
I should not need to reset the devices as that is handled by theTimed Devices setting correct.
howartp
Re: Pulse Counting
Post by howartp »
Great
I’ll need to be at my PC to play with the next bit I think.
lalisingh
Re: Pulse Counting
Post by lalisingh »
Does the activity tracker handle the case where the pulse counting device is offline or not able to upload the data?
If not the schedules will use the data from the last time the pulse counting device updated Indigo.
A timestamp of last update could solve this problem otherwise.
[url]https://www.VillageWorker.com[/url]
Extreme data analytics, Sensing, Control integration work.
Indigo • Barix • Kentix • Mobotix • Mikrotik • Apple
farberm
Re: Pulse Counting
Post by farberm »
Not sure I follow you. I agree the data will be impacted when the device is offline etc. how do you propose to,use time stamp?
howartp
Re: Pulse Counting
Post by howartp »
Ah, I thought that previous post was by the OP, which confused me.
Given how Indigo is reading the pulses, it’s impossible to know whether the pulse device is “offline” or water is just not being used at that time.
Back to the earlier question you’ll need multiple variables to store hour1, hour2, hour3 etc up to 24 hours. I can’t recall if there a trigger for “when activity timer restarts” so you don’t need a separate hourly schedule.
farberm
Re: Pulse Counting
Post by farberm »
Here is a screen shot of my timed variable. Similar for both. Not sure this is how it is supposed to be set up but its not really doing what I thought it should do.
What I want it to do....
Starting at 12:00 am track how many pulses are received each hour for the next 24 hour. Sum up the pulses for each day. Thus track pulses per hour and pulses per day. Once I have those going then use Grafana to display hourly, daily usage in graphic format.
Right now the timers only start one they receive a pulse, not every hour). Not sure if I have then set up correctly? Once a pulse is received they start the count down of one hour. So if a pulse is received in the middle of an hour 8:36 for instance the time runs till 9:36. Not what I want.
Screen Shot 2020-01-18 at 2.39.04 PM.png (129.23 KiB) Viewed 3461 times
howartp
Re: Pulse Counting
Post by howartp »
I’ll be at my desk shortly to have a look.
howartp
Re: Pulse Counting
Post by howartp »
I've just had a play.
The Activity Timer isn't working correctly so i've filed a bug with the author.
If you set the threshold to a high number (eg 9999) and untick "always extend" then the timer should never be extended, so should always contain an accurate count for 1 hour.
Regardless, i've also looked at the plugin store and feel there's a need for a generic counting plugin that achieves what you're after, to handle all the other bits. I'm interested in writing it, but it may be a week or three before I get to it at the moment.
Peter
farberm
Re: Pulse Counting
Post by farberm »
That would be great if you could write the new plug-in
System still now counting pulses correctly etc.
Any other suggestions?
Re: Pulse Counting
the "old" indigoplotd plugin does all kinds of counting
counts/hour /day... with budget multiplier etc and then you can also plot it. Some folks have been using it to count and display for some time to for water and gas usage.
vtmikel
Re: Pulse Counting
Post by vtmikel »
The grafana plugin could also likely calculate and visualize it.
howartp
Re: Pulse Counting
Post by howartp »
viewforum.php?f=333
The plugin isn't there yet, but will hopefully have it up this week.
farberm
Re: Pulse Counting
Post by farberm »
thx
Return to “Python Scripting”
