New Plugin - Flair Smart Vents
I've started working on a plugin for Flair devices - https://flair.co
If anyone is using these devices and would be willing to help test things I the plugin progresses, please let me know. I need someone else to test the initial authentication as soon as possible, to make sure that the method I'm using works for all users, and not just on my account (which is tied to the developer agreement).
SSteve
Re: New Plugin - Flair Smart Vents
Post by SSteve »
I'm using the thermostat pucks, not the smart vents, but if it's helpful I can try to do some testing.
SSteve wrote:I'm using the thermostat pucks, not the smart vents, but if it's helpful I can try to do some testing.
As long as you have a Flair login, that should work. I'll post something this weekend.
Pre-release 0.0.0 - https://github.com/FlyingDiver/Indigo-F ... /tag/0.0.0
Create an account device with username and password. If you have vents, create vent devices.
Use the menu command to dump the Flair data to the log.
SSteve
Post by SSteve »
The account device seems to be working. Here's the log output.
   Flair                           Flair account (233791916): Data:
    "7638": {
        "attributes": {
            "active-schedule-id": null,
            "city": redacted,
            "country": "US",
            "created-at": "2019-01-18T22:13:55.270925+00:00",
            "default-hold-duration": "3h",
            "frozen-pipe-pet-protect": true,
            "hold-reason": null,
            "hold-until": null,
            "hold-until-schedule-event": false,
            "home": true,
            "home-away-mode": "Flair Autohome Autoaway",
            "humidity-away-max": 80,
            "humidity-away-min": 10,
            "hysteresis-a": 50,
            "hysteresis-b": 100,
            "hysteresis-heat-cool-mode": 111,
            "is-active": true,
            "latitude": redacted,
            "licensed-features": [],
            "location": redacted,
            "location-type": "address",
            "longitude": redacted,
            "mode": "manual",
            "name": "Our Place in the Sun",
            "preheat-precool": true,
            "puck-client-id": redacted,
            "puck-client-secret": redacted,
            "release-channel": "production",
            "reporting-gateway": true,
            "set-point-mode": "Home Evenness For Active Rooms Follow Third Party",
            "set-point-temperature-c": 17.78,
            "setup-complete": true,
            "setup-mode": false,
            "setup-mode-first-time": true,
            "setup-step": "step-five",
            "state": "CA",
            "state-updated-at": "2020-01-05T20:16:39.026684+00:00",
            "structure-away-mode": "Off Only",
            "structure-heat-cool-mode": "float",
            "structure-heat-cool-mode-calculated": null,
            "structure-heat-cool-mode-popup-resolved-at": null,
            "structure-type": null,
            "temp-away-max-c": 25.0,
            "temp-away-min-c": 16.6,
            "temperature-scale": "F",
            "time-zone": "America/Los_Angeles",
            "updated-at": "2020-01-05T20:16:39.225957+00:00",
            "use-remote-sensor-occupancy": null,
            "zip-code": redacted
        "pucks": {
            "bd921f58-5b5c-5d96-fbf2-7f8059fa3338": {
                "beacon-interval-ms": 4095,
                "bluetooth-tx-power-mw": 500,
                "created-at": "2019-01-24T06:12:46.262792+00:00",
                "current-humidity": 57.9166666666667,
                "current-rssi": -82.0,
                "current-temperature-c": 18.3116666666667,
                "demo-mode": 0,
                "display-number": "bd92",
                "drop-rate": 1.02708333333333,
                "features": null,
                "humidity-offset": null,
                "inactive": false,
                "ir-download": false,
                "ir-setup-enabled": null,
                "is-gateway": false,
                "locked": null,
                "name": "Bedroom-bd92",
                "oauth-app-assigned-at": null,
                "orientation": "standing",
                "puck-display-color": "white",
                "reporting-interval-ds": 255,
                "sub-ghz-radio-tx-power-mw": null,
                "temperature-offset-c": null,
                "temperature-offset-override-c": null,
                "updated-at": "2020-01-04T20:08:02.655700+00:00"
            "e6328d39-83fd-56b6-6cd9-34a96a5e967d": {
                "created-at": "2019-01-24T06:11:23.277207+00:00",
                "current-humidity": 51.0,
                "current-rssi": 0.0,
                "current-temperature-c": 19.1675,
                "demo-mode": 0,
                "display-number": "e632",
                "drop-rate": 1.03416666666667,
                "features": null,
                "inactive": false,
                "is-gateway": true,
                "locked": null,
                "name": "Living Room-e632",
                "updated-at": "2020-01-05T00:40:40.109129+00:00"
        "rooms": {
            "9267": {
                "active": true,
                "air-return": false,
                "created-at": "2019-01-24T06:02:33.559949+00:00",
                "hold-until": null,
                "hold-until-schedule-event": null,
                "level": null,
                "name": "Living Room",
                "occupancy-mode": "Flair Auto",
                "pucks-inactive": "Active",
                "room-away-mode": "Smart Away",
                "room-type": null,
                "set-point-c": 20.01,
                "set-point-manual": false,
                "state-updated-at": "2019-12-02T13:41:06.219738+00:00",
                "temp-away-max-c": 22.5,
                "temp-away-min-c": 16.0,
                "updated-at": "2019-12-02T13:41:06.223472+00:00",
                "windows": null
            "9268": {
                "active": true,
                "created-at": "2019-01-24T06:14:45.464153+00:00",
                "current-humidity": 57.916666666666664,
                "hold-until": null,
                "level": null,
                "name": "Bedroom",
                "room-type": null,
                "state-updated-at": "2019-12-02T13:41:11.513290+00:00",
                "updated-at": "2019-12-02T13:41:11.519032+00:00",
                "windows": null
        "thermostats": {},
        "vents": {},
        "zones": {
            "37414": {
                "created-at": "2019-01-18T22:14:25.517121+00:00",
                "name": "Dining Room",
                "updated-at": "2019-10-02T13:05:55.264200+00:00"
            "37778": {
                "created-at": "2019-01-27T18:02:06.227813+00:00",
                "name": "Bedroom",
                "updated-at": "2019-10-02T13:05:55.498480+00:00"
Excellent. Now, what do you want the plugin to do for your setup? You have no vents to control, which is my use case. I'm thinking a pseudo-thermostat device which shows temperature and humidity?
SSteve
Post by SSteve »
Being able to manually turn the power on/off and set the temperature would be a great start.
Right now I'm going to be limited to showing status. The API calls to change a device don't seem to be working. I've got to open a ticket with Flair.
I'm working on adding minimal support for the mini splits. I forgot to put that into the first release, and I don't have any so I'm doing this just based on the API docs. I'll have that for you to try tomorrow, I think. Still status only until Flair gets back to me.
Pre-release 0.0.1 - https://github.com/FlyingDiver/Indigo-F ... /tag/0.0.1
If you have mini-split HVAC units controlled by Flair, please install this version and post the Data. Also, please advise on whether
This version does have a Thermostat device for the mini-split, but it's not operational yet. I've done two Thermostat devices before (Ecobee and Nexia), but those are traditional ducted units, not mini-splits. The API that Flair uses is confusing. In manual mode, it only has one set point. In automatic mode, the set points are for the room, not the HVAC unit. So I'm not really sure how to model it in Indigo.
SSteve
Post by SSteve »
I'm going to be away for a few days. I'll give it a try when I get back.
SSteve wrote:I'm going to be away for a few days. I'll give it a try when I get back.
So will I. Leaving this afternoon, should be back Saturday.
SSteve
Post by SSteve »
Installed 0.0.1. Here's the data:
      "FAN AUTO": [
                                    "25"
                            "ON": {
                                "FAN AUTO": [
                                    "25"
                        "COOL": {
                            "OFF": {
                                "FAN AUTO": [
                                    "25",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN HI": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN LOW": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN MID": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                            "ON": {
                                "FAN AUTO": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN HI": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN LOW": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN MID": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                        "DRY": {
                            "OFF": {
                                "FAN AUTO": [
                                    "25"
                            "ON": {
                                "FAN AUTO": [
                                    "25"
                        "FAN": {
                            "OFF": {
                                "FAN AUTO": [
                                    "25"
                            "ON": {
                                "FAN AUTO": [
                                    "25"
                        "HEAT": {
                            "OFF": {
                                "FAN AUTO": [
                                    "25",
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN HI": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN LOW": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN MID": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                            "ON": {
                                "FAN AUTO": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN HI": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN LOW": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN MID": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                "default-fan-speed": "AUTO",
                "fan-speed": "Auto",
                "incremental": false,
                "ir-device-model-id": null,
                "make-id": "3f6b4204-b4e8-4f41-89e4-7ae7950a57b8",
                "make-name": "FUJITSU",
                "mode": "Heat",
                "model-id": "0790ffdd-adf7-4e9a-b0ab-35ce28fa4206",
                "power": "Off",
                "quiet-hours-end": "07:30:00",
                "quiet-hours-start": "23:00:00",
                "swing": "On",
                "swing-auto": true,
                "temperature": 20,
                "temperature-compensation": "FLAIR NUDGE",
                "to-download": false,
                "type": "MiniSplit"
            "e0a094db-cc5a-4f8e-9810-08096a774a82": {
                "-temperature-compensation-limit-c": 300,
                "button-presses": [],
                "capabilities": "Both",
                "codeset-id": "821",
                "codesets": [
                        "id": 3,
                        "rank": 2
                "constraints": {
                    "OFF": {
                        "COOL": {
                            "OFF": {
                                "FAN AUTO": [
                                    "25"
                            "ON": {
                                "FAN AUTO": [
                                    "25"
                    "ON": {
                        "AUTO": {
                            "OFF": {
                                "FAN AUTO": [
                                    "25"
                            "ON": {
                                "FAN AUTO": [
                                    "25"
                        "COOL": {
                            "OFF": {
                                "FAN AUTO": [
                                    "25",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN HI": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN LOW": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN MID": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                            "ON": {
                                "FAN AUTO": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN HI": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN LOW": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN MID": [
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                        "DRY": {
                            "OFF": {
                                "FAN AUTO": [
                                    "25"
                            "ON": {
                                "FAN AUTO": [
                                    "25"
                        "FAN": {
                            "OFF": {
                                "FAN AUTO": [
                                    "25"
                            "ON": {
                                "FAN AUTO": [
                                    "25"
                        "HEAT": {
                            "OFF": {
                                "FAN AUTO": [
                                    "25",
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN HI": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN LOW": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN MID": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                            "ON": {
                                "FAN AUTO": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN HI": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN LOW": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                                "FAN MID": [
                                    "16",
                                    "17",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "25",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
                "mode": "Heat",
                "name": "Bedroom",
                "power": "On",
                "swing": "On",
                "swing-auto": true,
                "temperature": 19,
                "type": "MiniSplit"
        "pucks": {
                "current-humidity": 50.1666666666667,
                "current-rssi": -77.3333333333333,
                "current-temperature-c": 19.4975,
                "demo-mode": 0,
                "features": null,
                "inactive": false,
                "locked": null,
                "updated-at": "2020-01-16T14:31:27.361770+00:00"
                "current-humidity": 50.0,
                "current-temperature-c": 18.6125,
                "demo-mode": 0,
                "features": null,
                "inactive": false,
                "is-gateway": true,
                "locked": null,
                "updated-at": "2020-01-12T05:49:39.668690+00:00"
        "rooms": {
            "9267": {
                "active": true,
                "hold-until": null,
                "level": null,
                "room-type": null,
                "state-updated-at": "2020-01-11T14:48:19.993046+00:00",
                "updated-at": "2020-01-11T14:48:19.998585+00:00",
                "windows": null
            "9268": {
                "active": true,
                "current-humidity": 50.166666666666664,
                "hold-until": null,
                "level": null,
                "name": "Bedroom",
                "room-type": null,
                "set-point-c": 18.9,
                "state-updated-at": "2020-01-16T14:27:40.861928+00:00",
                "updated-at": "2020-01-16T14:27:40.867132+00:00",
                "windows": null
        "structure": {
            "city": "redacted",
            "country": "US",
            "hold-reason": "geofence",
            "hold-until": null,
            "home": true,
            "hysteresis-a": 50,
            "is-active": true,
            "location": "redacted.",
            "mode": "manual",
            "puck-client-id": "8b1evO3eopxAk9vGrXjyYWzny6920Rjk5XjzT6oO",
            "puck-client-secret": "PExuvkRhYXZsQqDNxLzolUOpQutTeK0fOP2pEOzXbggBixylhUc7x3ZVgVGr",
            "state": "CA",
            "state-updated-at": "2020-01-16T20:02:56.960524+00:00",
            "updated-at": "2020-01-16T20:02:57.165850+00:00",
            "zip-code": "redacted"
        "thermostats": {},
        "vents": {}
Did you miss the beginning of that data? Looks like the first lines are missing.
SSteve
Post by SSteve »
I think something got written to the log after I selected but before I hit Copy. There was some extra stuff at the end after I pasted. I didn't think to look at the beginning to see if the same number of characters got lopped off. Anyway, here's the first bit:
    "7638": {
        "hvac-units": {
            "3ef8ce07-0603-4fe9-88ab-a8e8ed05b3a6": {
                "codesets": [
                        "id": 3,
                        "rank": 2
                "constraints": {
                    "OFF": {
                        "COOL": {
                            "OFF": {
                                "FAN AUTO": [
                                    "25"
                            "ON": {
                                "FAN AUTO": [
                                    "25"
                    "ON": {
                        "AUTO": {
                            "OFF": {
                                "FAN AUTO": [
                                    "25"
                            "ON": {
                                "FAN AUTO": [
                                    "25"
                        "COOL": {
                            "OFF": {
                                "FAN AUTO": [
                                    "25",
                                    "18",
                                    "19",
                                    "20",
                                    "21",
                                    "22",
                                    "23",
                                    "24",
                                    "26",
                                    "27",
                                    "28",
                                    "29",
                                    "30"
Locked
Return to “Discontinued Plugins”
