I got one of this; I can control it via Hue, but with Indigo it is seen as dimmable device and cannot control it; am I doing something wrong?nsheldon wrote:Version 1.7.16 Posted
[*] Added support for the on/off OSRAM Smart+ Plug.
Marco
Hi Marco. When editing the Indigo device, select On/Off Devices from the Model pop up menu. The Osram Plug should appear in the list of devices.MarcoGT wrote:I got one of this; I can control it via Hue, but with Indigo it is seen as dimmable device and cannot control it; am I doing something wrong?nsheldon wrote:Version 1.7.16 Posted
Marco
No. You’re not missing anything. Philips have configured the Hue bridge to only enable Apple HomeKit support for Philips certified devices. So only Philips lights and sensors will appear in HomeKit. Other non-Philips devices will only appear in the Hue app but not in HomeKit.MarcoGT wrote:Uhm...strangely the plug does not appear in the homekit&Siri section of the Hue app.
Any idea?
As I’ve mentioned in previous posts, I need the plugin debug logs and the name you’ve given the bulb in order to add support.MarcoGT wrote:This Trader bulb is not recognised by the plugin:
TRADFRI bulb E27 WS opal 1000lm
I have added it and it works
Ok, I will paste it here, but the model name is exactly that I wrote in my last post. I have added it to “supportedDevices.py” and it gets recognized without problemsnsheldon wrote: As I’ve mentioned in previous posts, I need the plugin debug logs and the name you’ve given the bulb in order to add support.
The reason I need the debug log output is because I need to know what features to enable for the device (full color, color temperature, dimming only, on/off only, etc). Just knowing the model ID doesn't tell me what features the light supports. The raw JSON data from the Hue bridge does show what features are supported though. So that's why I need the logs.MarcoGT wrote:Ok, I will paste it here, but the model name is exactly that I wrote in my last post. I have added it to “supportedDevices.py” and it gets recognized without problems
Got response {u'1': {u'swversion': u'1.46.13_r26312', u'name': u'Soggiorno TV', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-07T20:20:05'}, u'productid': u'Philips-LTW012-1-E14CTv1', u'uniqueid': u'00:17:88:01:03:bb:4d:dc-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 450, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance candle', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 128, u'ct': 367}, u'manufacturername': u'Philips', u'swconfigid': u'5E2017D8', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'candlebulb'}, u'type': u'Color temperature light', u'modelid': u'LTW012'}, u'3': {u'swversion': u'5.127.1.26581', u'name': u'Reno', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-25T20:18:06'}, u'uniqueid': u'00:17:88:01:03:31:c1:65-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue bloom', u'state': {u'on': True, u'hue': 12868, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.4121], u'reachable': False, u'mode': u'homeautomation', u'bri': 206, u'sat': 52}, u'manufacturername': u'Philips', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'huebloom'}, u'type': u'Color light', u'modelid': u'LLC011'}, u'2': {u'swversion': u'5.127.1.26581', u'name': u'Rosy', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-25T10:07:39'}, u'uniqueid': u'00:17:88:01:03:31:c1:6a-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue bloom', u'state': {u'on': True, u'hue': 12868, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.4121], u'reachable': True, u'mode': u'homeautomation', u'bri': 204, u'sat': 52}, u'manufacturername': u'Philips', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'huebloom'}, u'type': u'Color light', u'modelid': u'LLC011'}, u'4': {u'swversion': u'2.0.022', u'name': u'Plafoniera cameretta', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-15T17:54:16'}, u'uniqueid': u'cc:cc:cc:ff:fe:3a:8a:c7-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 87, u'ct': 454}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'TRADFRI bulb E27 WS opal 1000lm'}}
Hue Lights Debug Loaded lights list - {u'1': {u'swversion': u'1.46.13_r26312', u'name': u'Soggiorno TV', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-07T20:20:05'}, u'productid': u'Philips-LTW012-1-E14CTv1', u'uniqueid': u'00:17:88:01:03:bb:4d:dc-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 450, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance candle', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 128, u'ct': 367}, u'manufacturername': u'Philips', u'swconfigid': u'5E2017D8', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'candlebulb'}, u'type': u'Color temperature light', u'modelid': u'LTW012'}, u'3': {u'swversion': u'5.127.1.26581', u'name': u'Reno', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-25T20:18:06'}, u'uniqueid': u'00:17:88:01:03:31:c1:65-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue bloom', u'state': {u'on': True, u'hue': 12868, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.4121], u'reachable': False, u'mode': u'homeautomation', u'bri': 206, u'sat': 52}, u'manufacturername': u'Philips', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'huebloom'}, u'type': u'Color light', u'modelid': u'LLC011'}, u'2': {u'swversion': u'5.127.1.26581', u'name': u'Rosy', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-25T10:07:39'}, u'uniqueid': u'00:17:88:01:03:31:c1:6a-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue bloom', u'state': {u'on': True, u'hue': 12868, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.4121], u'reachable': True, u'mode': u'homeautomation', u'bri': 204, u'sat': 52}, u'manufacturername': u'Philips', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'upwards', u'archetype': u'huebloom'}, u'type': u'Color light', u'modelid': u'LLC011'}, u'4': {u'swversion': u'2.0.022', u'name': u'Plafoniera cameretta', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-15T17:54:16'}, u'uniqueid': u'cc:cc:cc:ff:fe:3a:8a:c7-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 87, u'ct': 454}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'TRADFRI bulb E27 WS opal 1000lm'}}
Hue Lights Debug Got response {u'11': {u'swversion': u'1.46.13_r26312', u'name': u'Kontor 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LWG001-1-GU10DLv1', u'uniqueid': u'00:17:88:01:04:30:38:22-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 300}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white spot', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Philips', u'swconfigid': u'ACCF4E76', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Dimmable light', u'modelid': u'LWG001'}, u'10': {u'swversion': u'1.46.13_r26312', u'name': u'Kontor 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LWG001-1-GU10DLv1', u'uniqueid': u'00:17:88:01:04:70:8b:48-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 300}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white spot', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Philips', u'swconfigid': u'ACCF4E76', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Dimmable light', u'modelid': u'LWG001'}, u'13': {u'swversion': u'1.55.7_r28193', u'name': u'Pendel innerst', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LWG004-1-GU10DLv2', u'uniqueid': u'00:17:88:01:06:8d:76:75-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 400}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white spot', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 230, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'A7C27E3B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 179}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWG004'}, u'12': {u'swversion': u'1.55.7_r28193', u'name': u'Pendel ytterst', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LWG004-1-GU10DLv2', u'uniqueid': u'00:17:88:01:06:8d:79:6d-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 400}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white spot', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 230, u'alert': u'none'}, u'manufacturername': u'Philips', u'swconfigid': u'A7C27E3B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 180}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWG004'}, u'15': {u'swversion': u'2.0.022', u'name': u'Skrivebord', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-16T17:53:26'}, u'uniqueid': u'14:b4:57:ff:fe:44:84:1e-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 346}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'flexiblelamp'}, u'type': u'Color temperature light', u'modelid': u'TRADFRI bulb E14 WS opal 600lm'}, u'14': {u'swversion': u'1.3.002', u'name': u'Lampe Hall', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-16T17:35:14'}, u'uniqueid': u'14:b4:57:ff:fe:3c:c2:40-01', u'capabilities': {u'control': {u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color light', u'state': {u'on': True, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.458, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'sat': 0}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'decorative', u'direction': u'omnidirectional', u'archetype': u'tableshade'}, u'type': u'Color light', u'modelid': u'TRADFRI bulb E27 CWS opal 600lm'}, u'1': {u'swversion': u'5.127.1.26420', u'name': u'Gang 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:d7:1a:1b-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 141}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'3': {u'swversion': u'5.127.1.26420', u'name': u'Gang 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:d7:1c:75-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 141}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'2': {u'swversion': u'5.127.1.26420', u'name': u'Gang 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:d7:20:5b-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 141}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'7': {u'swversion': u'1.46.13_r26312', u'name': u'Soverom tak', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:04:87:5f:6a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 51438, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.2798, 0.1089], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 254}, u'manufacturername': u'Philips', u'swconfigid': u'52E3234B', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'6': {u'swversion': u'1.46.13_r26312', u'name': u'Lysekrone loftstue', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LCT015-1-A19ECLv5', u'uniqueid': u'00:17:88:01:04:a0:7b:be-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8382, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4594, 0.4104], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 143}, u'manufacturername': u'Philips', u'swconfigid': u'52E3234B', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT015'}, u'9': {u'swversion': u'1.46.13_r26312', u'name': u'Kontor 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LWG001-1-GU10DLv1', u'uniqueid': u'00:17:88:01:04:30:36:c3-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 300}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white spot', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Philips', u'swconfigid': u'ACCF4E76', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Dimmable light', u'modelid': u'LWG001'}, u'8': {u'swversion': u'1.46.13_r26312', u'name': u'Kontor 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LWG001-1-GU10DLv1', u'uniqueid': u'00:17:88:01:04:70:8b:01-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 300}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white spot', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'ACCF4E76', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Dimmable light', u'modelid': u'LWG001'}}
