New hue bulbs not showing in drop downs...
Jann
Post by Jann »
Hi all!
I have new bulbs - Gen3 - the ones that work on hub AND bluetooth... I happen to be using them using the hub. They work great using the hue app...
No indication of "part number" but they show (on the box) manufacture date May 2019.
They show in hue app as LWA002 - firmware 1.53.3_r27175
They won't show up no matter which Hue "Type" I choose.
They are the only LWA002's in my list of items (35-ish)
Strange, though. The LWB004's I've had for a year or so show up... so if you simply go by part number (Which is stupid I know) they should've been released AFTER these...but these are the newest model on amazon.
Any ideas? Newest "Hue-Lights-1.7.16" plugin... with indigo 7.4.
Jann
nsheldon
Re: New hue bulbs not showing in drop downs...
Post by nsheldon »
Hi Jann.
Check out the last few posts in the Hue Lights discussion thread. I need some debug log output from the plugin in order to add support since those bulbs aren’t yet listed in the Hue API.
viewtopic.php?f=31&t=9067&start=1080
Jann
Post by Jann »
Hi Nathan,
Is this what you need?
 Hue Lights                      Turning on debug logging
   Hue Lights Debug                Starting updateSensorsList.
   Hue Lights Debug                Starting parseAllHueSensorsData.
   Hue Lights Debug                Starting updateLightsList.
   Hue Lights Debug                Sending command to bridge: http://10.0.1.101/api/XGNUiLU04wDk2xkE7YJ2PY8aPvX52UYS8RC3whdz/lights
   Hue Lights Debug                Got response {u'42': {u'swversion': u'1.46.13_r26312', u'name': u'Guest Front Bedroom Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:57:52'}, u'productid': u'Philips-LWB014-1-A19DLv4', u'uniqueid': u'00:17:88:01:03:4e:f5:cd-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 38, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'69806BE9', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'43': {u'swversion': u'1.53.3_r27175', u'name': u'Garage Ceiling Front Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-11-12T23:42:32'}, u'productid': u'Philips-LWA002-1-A19DLv5', u'uniqueid': u'00:17:88:01:06:3b:8a:4c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'192966A5', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Dimmable light', u'modelid': u'LWA002'}, u'26': {u'swversion': u'1.46.13_r26312', u'name': u'Dining 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:57:55'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:1f:b5:cd-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'27': {u'swversion': u'1.46.13_r26312', u'name': u'Living Room Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T02:00:24'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:3b:3b:6c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 51, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'20': {u'swversion': u'1.46.13_r26312', u'name': u'Guest Back Bedroom Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-28T00:35:56'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:7a:a2:10-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 38, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'22': {u'swversion': u'5.127.1.26581', u'name': u'Right Nightstand', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-04T01:54:35'}, u'uniqueid': u'00:17:88:01:00:b1:c4:d9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 13524, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5017, 0.4152], u'reachable': True, u'mode': u'homeautomation', u'bri': 128, u'ct': 443, u'sat': 200}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'23': {u'swversion': u'1.46.13_r26312', u'name': u'Dining 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:05'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:3b:31:49-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'46': {u'swversion': u'1.53.3_r27175', u'name': u'Garage Ceiling Rear Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-11-12T23:46:55'}, u'productid': u'Philips-LWA002-1-A19DLv5', u'uniqueid': u'00:17:88:01:06:97:8d:38-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'192966A5', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Dimmable light', u'modelid': u'LWA002'}, u'44': {u'swversion': u'1.53.3_r27175', u'name': u'Garage Ceiling Front Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-11-12T23:44:07'}, u'productid': u'Philips-LWA002-1-A19DLv5', u'uniqueid': u'00:17:88:01:06:97:b7:de-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'192966A5', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Dimmable light', u'modelid': u'LWA002'}, u'45': {u'swversion': u'1.53.3_r27175', u'name': u'Garage Ceiling Rear Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-11-12T23:45:51'}, u'productid': u'Philips-LWA002-1-A19DLv5', u'uniqueid': u'00:17:88:01:06:c4:6c:84-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'192966A5', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Dimmable light', u'modelid': u'LWA002'}, u'28': {u'swversion': u'1.46.13_r26312', u'name': u'Dining 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:09'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:95:02:a5-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'29': {u'swversion': u'1.46.13_r26312', u'name': u'Dining 5', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:12'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:3e:81:b3-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'40': {u'swversion': u'1.46.13_r26312', u'name': u'Front Hall Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:01'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:80:4d:f0-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'41': {u'swversion': u'1.46.13_r26312', u'name': u'Back Hall Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:18'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:83:1e:d6-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'7': {u'swversion': u'5.127.1.26420', u'name': u'French Door Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-05T17:48:15'}, u'uniqueid': u'00:17:88:01:00:d5:9a:e4-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'9': {u'swversion': u'5.127.1.26420', u'name': u'French Door Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-04T01:52:50'}, u'uniqueid': u'00:17:88:01:00:df:31:5c-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'8': {u'swversion': u'5.127.1.26420', u'name': u'Foyer front', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-04T01:54:56'}, u'uniqueid': u'00:17:88:01:00:df:4d:de-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'11': {u'swversion': u'5.127.1.26581', u'name': u'Rear Pergola Strips', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-27T23:09:04'}, u'uniqueid': u'00:17:88:01:00:cd:08:c6-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue lightstrip', u'state': {u'on': True, u'hue': 55884, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4398, 0.1889], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'sat': 253}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Color light', u'modelid': u'LST001'}, u'10': {u'swversion': u'5.127.1.26581', u'name': u'Front Pergola  Strips', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-27T23:08:58'}, u'uniqueid': u'00:17:88:01:00:cd:08:bf-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue lightstrip', u'state': {u'on': True, u'hue': 55884, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4398, 0.1889], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'sat': 253}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Color light', u'modelid': u'LST001'}, u'39': {u'swversion': u'1.46.13_r26312', u'name': u'Back Hall Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:57:58'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:84:8d:96-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'38': {u'swversion': u'1.46.13_r26312', u'name': u'Front Hall Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:32'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:83:23:b9-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'17': {u'swversion': u'5.127.1.26581', u'name': u'Left Nightstand', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-27T23:08:25'}, u'uniqueid': u'00:12:4b:00:02:31:67:10-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 13524, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5017, 0.4152], u'reachable': True, u'mode': u'homeautomation', u'bri': 128, u'ct': 443, u'sat': 200}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'19': {u'swversion': u'1.46.13_r26312', u'name': u'Guest Back Bedroom Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:79:03:24-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 38, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'18': {u'swversion': u'1.46.13_r26312', u'name': u'Front Door', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:73:13:0b-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8381, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4583, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 141}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'31': {u'swversion': u'1.46.13_r26312', u'name': u'Living Room Floor Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:44'}, u'productid': u'Philips-LWB014-1-A19DLv4', u'uniqueid': u'00:17:88:01:02:fa:6d:70-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 51, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'69806BE9', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'30': {u'swversion': u'1.46.13_r26312', u'name': u'Dining 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:37'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:f4:12:11-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'37': {u'swversion': u'5.127.1.26420', u'name': u'Loft Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-04T01:53:39'}, u'uniqueid': u'00:17:88:01:00:d5:a4:10-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 13, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'tableshade'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'36': {u'swversion': u'5.127.1.26420', u'name': u'Mike\u2019s Office Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-04T01:53:46'}, u'uniqueid': u'00:17:88:01:00:d5:ba:c9-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 13, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'tableshade'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'35': {u'swversion': u'1.46.13_r26312', u'name': u'Guest Front Bedroom Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-04-19T17:06:57'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:03:5b:fe:da-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 38, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'34': {u'swversion': u'1.46.13_r26312', u'name': u'Foyer back', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-03-04T03:43:08'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:1e:c6:e1-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'32': {u'swversion': u'1.46.13_r26312', u'name': u'Living Room Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:50'}, u'productid': u'Philips-LWB014-1-A19DLv4', u'uniqueid': u'00:17:88:01:02:d1:38:a5-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 51, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'69806BE9', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}}
   Hue Lights Debug                Loaded lights list - {u'42': {u'swversion': u'1.46.13_r26312', u'name': u'Guest Front Bedroom Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:57:52'}, u'productid': u'Philips-LWB014-1-A19DLv4', u'uniqueid': u'00:17:88:01:03:4e:f5:cd-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 38, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'69806BE9', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'43': {u'swversion': u'1.53.3_r27175', u'name': u'Garage Ceiling Front Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-11-12T23:42:32'}, u'productid': u'Philips-LWA002-1-A19DLv5', u'uniqueid': u'00:17:88:01:06:3b:8a:4c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'192966A5', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Dimmable light', u'modelid': u'LWA002'}, u'26': {u'swversion': u'1.46.13_r26312', u'name': u'Dining 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:57:55'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:1f:b5:cd-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'27': {u'swversion': u'1.46.13_r26312', u'name': u'Living Room Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T02:00:24'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:3b:3b:6c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 51, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'20': {u'swversion': u'1.46.13_r26312', u'name': u'Guest Back Bedroom Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-28T00:35:56'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:7a:a2:10-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 38, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'22': {u'swversion': u'5.127.1.26581', u'name': u'Right Nightstand', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-04T01:54:35'}, u'uniqueid': u'00:17:88:01:00:b1:c4:d9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 13524, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5017, 0.4152], u'reachable': True, u'mode': u'homeautomation', u'bri': 128, u'ct': 443, u'sat': 200}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'23': {u'swversion': u'1.46.13_r26312', u'name': u'Dining 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:05'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:3b:31:49-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'46': {u'swversion': u'1.53.3_r27175', u'name': u'Garage Ceiling Rear Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-11-12T23:46:55'}, u'productid': u'Philips-LWA002-1-A19DLv5', u'uniqueid': u'00:17:88:01:06:97:8d:38-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'192966A5', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Dimmable light', u'modelid': u'LWA002'}, u'44': {u'swversion': u'1.53.3_r27175', u'name': u'Garage Ceiling Front Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-11-12T23:44:07'}, u'productid': u'Philips-LWA002-1-A19DLv5', u'uniqueid': u'00:17:88:01:06:97:b7:de-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'192966A5', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Dimmable light', u'modelid': u'LWA002'}, u'45': {u'swversion': u'1.53.3_r27175', u'name': u'Garage Ceiling Rear Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-11-12T23:45:51'}, u'productid': u'Philips-LWA002-1-A19DLv5', u'uniqueid': u'00:17:88:01:06:c4:6c:84-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'192966A5', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Dimmable light', u'modelid': u'LWA002'}, u'28': {u'swversion': u'1.46.13_r26312', u'name': u'Dining 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:09'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:95:02:a5-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'29': {u'swversion': u'1.46.13_r26312', u'name': u'Dining 5', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:12'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:3e:81:b3-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'40': {u'swversion': u'1.46.13_r26312', u'name': u'Front Hall Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:01'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:80:4d:f0-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'41': {u'swversion': u'1.46.13_r26312', u'name': u'Back Hall Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:18'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:83:1e:d6-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'7': {u'swversion': u'5.127.1.26420', u'name': u'French Door Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-05T17:48:15'}, u'uniqueid': u'00:17:88:01:00:d5:9a:e4-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'9': {u'swversion': u'5.127.1.26420', u'name': u'French Door Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-04T01:52:50'}, u'uniqueid': u'00:17:88:01:00:df:31:5c-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'8': {u'swversion': u'5.127.1.26420', u'name': u'Foyer front', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-04T01:54:56'}, u'uniqueid': u'00:17:88:01:00:df:4d:de-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'11': {u'swversion': u'5.127.1.26581', u'name': u'Rear Pergola Strips', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-27T23:09:04'}, u'uniqueid': u'00:17:88:01:00:cd:08:c6-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue lightstrip', u'state': {u'on': True, u'hue': 55884, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4398, 0.1889], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'sat': 253}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Color light', u'modelid': u'LST001'}, u'10': {u'swversion': u'5.127.1.26581', u'name': u'Front Pergola  Strips', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-27T23:08:58'}, u'uniqueid': u'00:17:88:01:00:cd:08:bf-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue lightstrip', u'state': {u'on': True, u'hue': 55884, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4398, 0.1889], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'sat': 253}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Color light', u'modelid': u'LST001'}, u'39': {u'swversion': u'1.46.13_r26312', u'name': u'Back Hall Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:57:58'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:84:8d:96-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'38': {u'swversion': u'1.46.13_r26312', u'name': u'Front Hall Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:32'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:83:23:b9-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'17': {u'swversion': u'5.127.1.26581', u'name': u'Left Nightstand', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-27T23:08:25'}, u'uniqueid': u'00:12:4b:00:02:31:67:10-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 13524, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5017, 0.4152], u'reachable': True, u'mode': u'homeautomation', u'bri': 128, u'ct': 443, u'sat': 200}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'19': {u'swversion': u'1.46.13_r26312', u'name': u'Guest Back Bedroom Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:79:03:24-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 38, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'18': {u'swversion': u'1.46.13_r26312', u'name': u'Front Door', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:73:13:0b-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8381, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4583, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 141}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'31': {u'swversion': u'1.46.13_r26312', u'name': u'Living Room Floor Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:44'}, u'productid': u'Philips-LWB014-1-A19DLv4', u'uniqueid': u'00:17:88:01:02:fa:6d:70-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 51, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'69806BE9', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'30': {u'swversion': u'1.46.13_r26312', u'name': u'Dining 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:37'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:f4:12:11-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'37': {u'swversion': u'5.127.1.26420', u'name': u'Loft Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-04T01:53:39'}, u'uniqueid': u'00:17:88:01:00:d5:a4:10-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 13, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'tableshade'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'36': {u'swversion': u'5.127.1.26420', u'name': u'Mike\u2019s Office Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-04T01:53:46'}, u'uniqueid': u'00:17:88:01:00:d5:ba:c9-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 13, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'tableshade'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'35': {u'swversion': u'1.46.13_r26312', u'name': u'Guest Front Bedroom Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-04-19T17:06:57'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:03:5b:fe:da-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 38, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'34': {u'swversion': u'1.46.13_r26312', u'name': u'Foyer back', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-03-04T03:43:08'}, u'productid': u'Philips-LWB014-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:1e:c6:e1-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'E790821B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}, u'32': {u'swversion': u'1.46.13_r26312', u'name': u'Living Room Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T01:58:50'}, u'productid': u'Philips-LWB014-1-A19DLv4', u'uniqueid': u'00:17:88:01:02:d1:38:a5-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 840}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 51, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'69806BE9', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'powerfail'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB014'}}
   Hue Lights Debug                Starting parseAllHueLightsData.
   Hue Lights Debug                parseAllHueLightsData: There are 31 lights on the Hue bridge and 32 Indigo devices controlling Hue devices.
   Hue Lights Debug                Starting updateGroupsList.
   Hue Lights Debug                Sending command to bridge: http://10.0.1.101/api/XGNUiLU04wDk2xkE7YJ2PY8aPvX52UYS8RC3whdz/groups
   Hue Lights Debug                Got response {u'24': {u'name': u'Loft', u'lights': [u'37'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 13, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'20': {u'name': u'Master Bathroom', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'21': {u'name': u'Pergola', u'lights': [u'10', u'11'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 55884, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4398, 0.1889], u'bri': 254, u'sat': 253}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'22': {u'name': u'Garden', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'23': {u'name': u'Patio', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'1': {u'name': u'Guest Front Bedroom', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u"Maura's House", u'lights': [u'8', u'9'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': True, u'bri': 77, u'alert': u'select'}}, u'2': {u'name': u'Rear Yard', u'lights': [u'7'], u'state': {u'any_on': True, u'all_on': True}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': True, u'bri': 77, u'alert': u'select'}}, u'5': {u'name': u'Porch', u'lights': [u'7', u'9'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 77, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Garden'}, u'4': {u'name': u'Front Door', u'lights': [u'18'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8381, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4583, 0.4099], u'bri': 254, u'ct': 366, u'sat': 141}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Front door'}, u'7': {u'name': u'Hallway', u'lights': [u'38', u'39', u'40', u'41'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'6': {u'name': u'Den', u'lights': [u'35', u'42'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 38, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'9': {u'name': u'Foyer', u'lights': [u'8', u'34'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'8': {u'name': u'Dining Room', u'lights': [u'23', u'28', u'29', u'30', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 254, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Dining'}, u'11': {u'name': u'Master Bedroom', u'lights': [u'22', u'17'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 13524, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5017, 0.4152], u'bri': 128, u'ct': 443, u'sat': 200}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'10': {u'name': u'Living Room', u'lights': [u'31', u'27', u'32'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 51, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'13': {u'name': u'Mike\u2019s Office', u'lights': [u'36'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 13, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Office'}, u'12': {u'name': u'Guest Back Bedroom', u'lights': [u'20', u'19'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'bri': 38, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'15': {u'name': u'Group group22 ', u'lights': [u'10'], u'state': {u'any_on': True, u'all_on': True}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': True, u'hue': 55884, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4398, 0.1889], u'bri': 254, u'sat': 253}}, u'14': {u'name': u'Group group21 ', u'lights': [u'11'], u'state': {u'any_on': True, u'all_on': True}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': True, u'hue': 55884, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4398, 0.1889], u'bri': 254, u'sat': 253}}, u'17': {u'name': u'Kitchen', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'19': {u'name': u'Main Bathroom', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'18': {u'name': u'Garage', u'lights': [u'43', u'44', u'45', u'46'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 127, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}}
   Hue Lights Debug                Loaded groups list - {u'24': {u'name': u'Loft', u'lights': [u'37'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 13, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'20': {u'name': u'Master Bathroom', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'21': {u'name': u'Pergola', u'lights': [u'10', u'11'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 55884, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4398, 0.1889], u'bri': 254, u'sat': 253}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'22': {u'name': u'Garden', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'23': {u'name': u'Patio', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'1': {u'name': u'Guest Front Bedroom', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u"Maura's House", u'lights': [u'8', u'9'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': True, u'bri': 77, u'alert': u'select'}}, u'2': {u'name': u'Rear Yard', u'lights': [u'7'], u'state': {u'any_on': True, u'all_on': True}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': True, u'bri': 77, u'alert': u'select'}}, u'5': {u'name': u'Porch', u'lights': [u'7', u'9'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 77, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Garden'}, u'4': {u'name': u'Front Door', u'lights': [u'18'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8381, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4583, 0.4099], u'bri': 254, u'ct': 366, u'sat': 141}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Front door'}, u'7': {u'name': u'Hallway', u'lights': [u'38', u'39', u'40', u'41'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'6': {u'name': u'Den', u'lights': [u'35', u'42'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 38, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'9': {u'name': u'Foyer', u'lights': [u'8', u'34'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'8': {u'name': u'Dining Room', u'lights': [u'23', u'28', u'29', u'30', u'26'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 254, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Dining'}, u'11': {u'name': u'Master Bedroom', u'lights': [u'22', u'17'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 13524, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5017, 0.4152], u'bri': 128, u'ct': 443, u'sat': 200}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'10': {u'name': u'Living Room', u'lights': [u'31', u'27', u'32'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 51, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'13': {u'name': u'Mike\u2019s Office', u'lights': [u'36'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 13, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Office'}, u'12': {u'name': u'Guest Back Bedroom', u'lights': [u'20', u'19'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4099], u'bri': 38, u'ct': 366, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'15': {u'name': u'Group group22 ', u'lights': [u'10'], u'state': {u'any_on': True, u'all_on': True}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': True, u'hue': 55884, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4398, 0.1889], u'bri': 254, u'sat': 253}}, u'14': {u'name': u'Group group21 ', u'lights': [u'11'], u'state': {u'any_on': True, u'all_on': True}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': True, u'hue': 55884, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4398, 0.1889], u'bri': 254, u'sat': 253}}, u'17': {u'name': u'Kitchen', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'19': {u'name': u'Main Bathroom', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'18': {u'name': u'Garage', u'lights': [u'43', u'44', u'45', u'46'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 127, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}}
   Hue Lights Debug                Starting parseAllHueGroupsData.
   Hue Lights Debug                Starting parseOneHueGroupData.
   Hue Lights Debug                Starting updateSensorsList.
   Hue Lights Debug                Starting parseAllHueSensorsData.
nsheldon
Re: New hue bulbs not showing in drop downs...
Post by nsheldon »
Yep. That's exactly what I was looking for.
I'll add support in the next update (it'll be a few days as I just released an update yesterday).
Jann
Post by Jann »
Thanks so much Nathan!!!
nsheldon
Post by nsheldon »
Version 1.7.17 Posted
  • Added support for a new Philips A19 dimmable light.
Locked
Return to “Archives”
