pixelpipeline
Post by pixelpipeline »
Hello Karl,
no changes with a wired connection ...
But now I get
   piBeacon Warning                error in socket-send to rPi:0 192.168.100.242, connection refused, rebooting/restarting RPI?
Debug rpi; in config at the bottom
siclark
Post by siclark »
Hi Karl,
I am suddenly getting lots of errors from piBeacon in the last 2 days. I have tried rebooting the mac and still exist. This is the start of the errors just now. I was also seeing the TCP issues as above, but latest version seem to have fixed that. I also updated to latest version this morning, after getting these issues, and they still persiste.
Any ideas? I also cant see any of the pi servers in the drop down lists .
thanks
7 Oct 2019 at 12:32:20
piBeacon Error Error in plugin execution startup:
File "plugin.py", line 357, in startup
File "plugin.py", line 713, in getDebugLevels
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site.py", line 360, in __call__
SystemExit: 1
piBeacon Error Line 2956 has error='Plugin' object has no attribute 'currentVersion'
piBeacon Error Line 3078 has error='Plugin' object has no attribute 'freezeAddRemove'
piBeacon Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 9212, in runConcurrentThread
File "plugin.py", line 9235, in dorunConcurrentThread
File "plugin.py", line 9050, in initConcurrentThread
AttributeError: 'Plugin' object has no attribute 'userIdOfServer'
Does this include the VERY first error after plugin restart?
And what opsys version ...
siclark
Post by siclark »
Yes. Just disabled it and renabled it after an hour. Still not showing errors, other than time out when I try to do basic setup.
Error (client) timeout waiting for plugin response from com.karlwachs.piBeacon for request UiGetValues1
Error (client) timeout waiting for plugin response from com.karlwachs.piBeacon for request CallPluginFunc
Error (client) runDialogForMenuAction() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
opsys is 10.14.5
Is there anything in the plugin.log file?
siclark
Post by siclark »
2019-10-07 15:53:58 logger enabled for THREADDEBUG ==> TEST ONLY
2019-10-07 15:53:58 logger enabled for DEBUG ==> TEST ONLY
2019-10-07 15:53:58 logger enabled for INFO ==> TEST ONLY
2019-10-07 15:53:58 logger enabled for WARNING ==> TEST ONLY
2019-10-07 15:53:58.797 ERROR Plugin.__init__ logger enabled for ERROR ==> TEST ONLY
2019-10-07 15:53:58.797 CRITICAL Plugin.__init__ logger enabled for CRITICAL ==> TEST ONLY
2019-10-07 15:53:58.810 CRITICAL Plugin.getDebugLevels --------------------------------------------------------------------------------------------------------------
2019-10-07 15:53:58.810 CRITICAL Plugin.getDebugLevels Line 706 has error=invalid literal for int() with base 10: ''
2019-10-07 15:53:58.810 CRITICAL Plugin.getDebugLevels Error in startup of plugin, waiting for 2000 secs then restarting plugin
2019-10-07 16:26:33 logger enabled for THREADDEBUG ==> TEST ONLY
2019-10-07 16:26:33 logger enabled for DEBUG ==> TEST ONLY
2019-10-07 16:26:33 logger enabled for INFO ==> TEST ONLY
2019-10-07 16:26:33 logger enabled for WARNING ==> TEST ONLY
2019-10-07 16:26:33.557 ERROR Plugin.__init__ logger enabled for ERROR ==> TEST ONLY
2019-10-07 16:26:33.557 CRITICAL Plugin.__init__ logger enabled for CRITICAL ==> TEST ONLY
2019-10-07 16:26:33.571 CRITICAL Plugin.getDebugLevels --------------------------------------------------------------------------------------------------------------
2019-10-07 16:26:33.571 CRITICAL Plugin.getDebugLevels Line 706 has error=invalid literal for int() with base 10: ''
2019-10-07 16:26:33.571 CRITICAL Plugin.getDebugLevels Error in startup of plugin, waiting for 2000 secs then restarting plugin
This is when I restart. I cant do anything in the plugin menu, config, initial basic setup etc as it times out like this
Error (client) timeout waiting for plugin response from com.karlwachs.piBeacon for request UiGetValues2
Error (client) runDialogForDevice() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
So cant increase logging. I have just downgraded a couple of versions, but still same.
siclark
Post by siclark »
I restarted the indigo server last night at 21:06 and it seems to have stopped then. Have these lines in the log from last night. Appears to have gone wrong then. It was working fine until that point, and all pi servers and devices show last updated at 21:06 last night.
2019-10-06 17:09:37 TCPIP socket error rate high for 192.168.0.39/none ; previous:2019-10-06 17:09:37
17:09:37 pi TCPIP socket -IP name type first last #MSGs #bytes bytes/MSG maxBytes bytes/min MSGs/min
17:09:37 -192.168.0.39 none timeout 2019-03-19 07:56:05 2019-10-06 17:09:37 1161 0 0 0 0.0 0.00
17:09:37 -192.168.0.39 none unknown 2019-04-28 18:10:51 2019-05-05 06:29:18 3 0 0 0 0.0 0.00
17:09:37 -192.168.0.39 pi_IN_4 ok 2019-03-18 22:28:13 2019-10-06 17:09:27 912628 271173150 297 771 545.3 1.84
17:09:37 -192.168.0.39 pi_IN_Alive ok 2019-03-18 22:28:05 2019-10-06 17:07:29 21269 6592178 309 489 13.3 0.04
17:09:37 -192.168.0.39 unknown errIP 2019-05-25 05:50:01 2019-05-25 05:59:35 5 0 0 0 0.0 0.00
2019-10-06 21:09:26 rpi: 13 state: stopped
2019-10-06 21:09:26 rpi: 0 state: stopped
2019-10-06 21:09:26 rpi: 2 state: stopped
2019-10-06 21:09:26 rpi: 3 state: stopped
2019-10-06 21:09:26 rpi: 18 state: stopped
2019-10-06 21:09:26 rpi: 14 state: stopped
2019-10-06 21:09:27 rpi: 6 state: stopped
2019-10-06 21:09:27 rpi: 3 state: stopped
2019-10-06 21:09:27 rpi: 11 state: stopped
2019-10-06 21:09:27 rpi: 12 state: stopped
2019-10-06 21:09:27 rpi: 1 state: stopped
2019-10-06 21:09:27 rpi: 10 state: stopped
2019-10-06 21:09:27 rpi: 8 state: stopped
2019-10-06 21:09:27 rpi: 5 state: stopped
2019-10-06 21:09:27 rpi: 16 state: stopped
2019-10-06 21:09:27 rpi: 9 state: stopped
2019-10-06 21:09:27 rpi: 2 state: stopped
2019-10-06 21:09:27 rpi: 15 state: stopped
2019-10-06 21:09:27 rpi: 19 state: stopped
2019-10-06 21:09:27 rpi: 17 state: stopped
2019-10-06 21:09:27 rpi: 4 state: stopped
2019-10-06 21:09:27 rpi: 7 state: stopped
2019-10-06 21:09:27 rpi: 0 state: stopped
2019-10-06 21:10:05 logger enabled for THREADDEBUG ==> TEST ONLY
2019-10-06 21:10:05 logger enabled for DEBUG ==> TEST ONLY
2019-10-06 21:10:05 logger enabled for INFO ==> TEST ONLY
2019-10-06 21:10:05 logger enabled for WARNING ==> TEST ONLY
2019-10-06 21:10:05.386 ERROR Plugin.__init__ logger enabled for ERROR ==> TEST ONLY
2019-10-06 21:10:05.387 CRITICAL Plugin.__init__ logger enabled for CRITICAL ==> TEST ONLY
2019-10-06 21:10:05.510 CRITICAL Plugin.getDebugLevels --------------------------------------------------------------------------------------------------------------
2019-10-06 21:10:05.510 CRITICAL Plugin.getDebugLevels Line 706 has error=invalid literal for int() with base 10: ''
2019-10-06 21:10:05.510 CRITICAL Plugin.getDebugLevels Error in startup of plugin, waiting for 2000 secs then restarting plugin
    <Field id="debugRPI"   type = "menu" defaultValue = "-1"  >
        <Label>Debug...which RPI:</Label>
                <List class="self" filter="" method="filterPiC" dynamicReload="false"/>
        </Field>
is call by :
def getDebugLevels(self):
			self.debugLevel			= []
			for d in ["Logic","DevMgmt","BeaconData","SensorData","OutputDevice","UpdateRPI","OfflineRPI","Fing","BLE","CAR","BC","all","Socket","Special","PlotPositions","SocketRPI"]:
				if self.pluginPrefs.get(u"debug"+d, False): self.debugLevel.append(d)
			self.debugRPI=-1
			self.debugRPI			 = int(self.pluginPrefs.get(u"debugRPI", -1))
 		except Exception, e:
			self.indiLOG.critical(u"--------------------------------------------------------------------------------------------------------------")
			self.indiLOG.critical(u"Line {} has error={}".format(sys.exc_traceback.tb_lineno, e) )
			self.indiLOG.critical(u"Error in startup of plugin, waiting for 2000 secs then restarting plugin")
			self.sleep(2000)
			exit(1)
		return
the pluginConfig pref debugRPI is not an integer. should be initialized to one.
then the plugin exits, which is a little to strong of a remedy..
thats an easy fix. will post in short order
published .313, that should fix this.
siclark
Post by siclark »
That has worked, thanks for quick turnaround.
I found a few menu items in config that were not selected in the drop downs, so populated those. Not sure if that was a problem or not.
I have covered most of them with defaults, but when its a number i need to do
try; value= int(..)
except: value=default
I might have missed one or two
GlennNZ
Post by GlennNZ »
Hi Karl,
With latest version getting this error in most RPI - all of which are marked as down...
pi@raspberrypi:~/pibeacon $ sudo python master.py
20-13:28:21 master          execMaster           L:1624 Lv:30 ========================= starting master  version: 11.3
Killed
pi@raspberrypi:~/pibeacon $ 20-13:28:25 master          execMaster           L:1672 Lv:30 START.. indigoServer IP:>>192.168.1.19<<
20-13:28:27 master          execMaster           L:1683 Lv:50 hw clock info: ('', 'hwclock: Cannot access the Hardware Clock via any known method.\nhwclock: Use the --debug option to see the details of our search for an access method.\n')
20-13:28:37 master          execMaster           L:1708 Lv:30 no ip number working, trying again, indigoServerOn:True, ip:
20-13:28:47 master          execMaster           L:1708 Lv:30 no ip number working, trying again, indigoServerOn:True, ip:
20-13:28:58 master          execMaster           L:1708 Lv:30 no ip number working, trying again, indigoServerOn:True, ip:
20-13:29:08 master          execMaster           L:1708 Lv:30 no ip number working, trying again, indigoServerOn:True, ip:
20-13:29:08 master          execMaster           L:1700 Lv:30 no ip number working, giving up, running w/o ip number, setting mode to clockMANUAL
20-13:29:09 master          readNewParams        L:382  Lv:30 UPS-V2 interface NOT enabled
20-13:29:10 INPUTgpio       <module>             L:204  Lv:30 starting INPUTgpio program
  File "/home/pi/pibeacon/INPUTgpio.py", line 208, in <module>
    INPUTcount = U.readINPUTcount()
  File "/home/pi/pibeacon/piBeaconUtils.py", line 1969, in readINPUTcount
    IPC[str(p)] =0
TypeError: list indices must be integers, not str
20-13:29:11 master          setACTIVEorKILL      L:537  Lv:30 started:INPUTgpio.py
20-13:29:11 INPUTgpio       <module>             L:204  Lv:30 starting INPUTgpio program
    IPC[str(p)] =0
20-13:29:11 installLibs     <module>             L:321  Lv:30  installLibs starting
20-13:29:11 installLibs     <module>             L:348  Lv:30  installLibs no opsys upgrade requested
20-13:29:11 installLibs     <module>             L:371  Lv:30 ==== libraries seem to be setup, no need for action
20-13:29:11 installLibs     <module>             L:373  Lv:30 ==== libraries install finished
20-13:29:12 beaconloop      startBlueTooth       L:126  Lv:30 (re)starting bluetooth
20-13:29:12 beaconloop      startBlueTooth       L:142  Lv:30 Beacon Use HCINo -1;  useHCI:hci0;  myBLEmac:B8:27:EB:47:6C:80; devId:0
20-13:29:12 beaconloop      startBlueTooth       L:154  Lv:30 hcitool -i hci0 cmd 0x08 0x0008 1E 02 01 1A 1A FF 4C 00 02 15 2f 23 44 54 cf 6d 4a 0f ad f2 f4 91 1b a9 ff a6 00 09 00 02 C5 00
20-13:29:12 beaconloop      startBlueTooth       L:162  Lv:30 hcitool -i hci0 cmd 0x08 0x0006 00 10 00 20 03 00 00 00 00 00 00 00 00 07 00
20-13:29:12 beaconloop      startBlueTooth       L:166  Lv:30 hcitool -i hci0 cmd 0x08 0x000a 01
20-13:29:12 beaconloop      startBlueTooth       L:174  Lv:30 BLE start returned:
hci0:	Type: Primary  Bus: UART
	BD Address: B8:27:EB:47:6C:80  ACL MTU: 1021:8  SCO MTU: 64:1
	UP RUNNING
	RX bytes:1560 acl:0 sco:0 events:102 errors:0
	TX bytes:5070 acl:0 sco:0 commands:102 errors:0
20-13:29:12 beaconloop      startBlueTooth       L:186  Lv:30 my BLE mac# is : B8:27:EB:47:6C:80
20-13:29:12 beaconloop      startBlueTooth       L:194  Lv:30 ble thread started
20-13:29:12 beaconloop      execbeaconloop       L:808  Lv:30 starting loop
20-13:29:13 beaconloop      execbeaconloop       L:1059 Lv:50 in Line 956 has error=string index out of range  bad data, skipping
	 MAC:   FB:3A:45:26:C0:15
	 UUID:  01
20-13:29:15 beaconloop      execbeaconloop       L:1059 Lv:50 in Line 956 has error=string index out of range  bad data, skipping
	 UUID:  01
20-13:29:16 beaconloop      execbeaconloop       L:1059 Lv:50 in Line 956 has error=string index out of range  bad data, skipping
	 MAC:   C8:AE:2B:E8:DC:8B
	 UUID:  01
20-13:29:17 beaconloop      execbeaconloop       L:1059 Lv:50 in Line 956 has error=string index out of range  bad data, skipping
	 UUID:  01
20-13:29:18 beaconloop      execbeaconloop       L:1059 Lv:50 in Line 956 has error=string index out of range  bad data, skipping
	 UUID:  01
20-13:29:19 beaconloop      execbeaconloop       L:1059 Lv:50 in Line 956 has error=string index out of range  bad data, skipping
	 UUID:  01
20-13:29:21 beaconloop      execbeaconloop       L:1059 Lv:50 in Line 956 has error=string index out of range  bad data, skipping
	 UUID:  01
20-13:29:22 beaconloop      execbeaconloop       L:1059 Lv:50 in Line 956 has error=string index out of range  bad data, skipping
	 UUID:  01
20-13:29:23 beaconloop      execbeaconloop       L:1059 Lv:50 in Line 956 has error=string index out of range  bad data, skipping
	 UUID:  01
20-13:29:24 beaconloop      execbeaconloop       L:1059 Lv:50 in Line 956 has error=string index out of range  bad data, skipping
	 UUID:  01
20-13:29:25 beaconloop      execbeaconloop       L:1059 Lv:50 in Line 956 has error=string index out of range  bad data, skipping
	 UUID:  01
& then this
20-13:12:55 beaconloop      execbeaconloop       L:1059 Lv:50 in Line 956 has error=string index out of range  bad data, skipping
	 UUID:  01
Repeating, as first example
Gone back to 7.112.313 and all RPIs now marked up and going again interestingly enough, but the same errors continue in the PIs and some of GPIO don’t seem to be responding.
On reflection I suspect the GPIOs have not been working for a few versions, use a few GPIO buttons (mainly in summer) and one for Gate open/close which is prone to hardware failure (so didn’t think much of it not reporting)
Ok, have done some research...
GPIO - not reporting since v7.111.311 @ 2019-09-16
Think issue:
PiBeaconUtils.py
Line 1957
				int(IPC[str(p)])
			except:
				#IPC[str(p)] =0
				IPC[int(p)] =0
Fixes, update GPIO Pi’s and all GPIO going again.
Still on older version mine you...
Glenn
Oops that’s bad. I thought that was working.
I don't recall changing things in the beacon monitoring .. mine works fine..
it looks as if there is a beacon that sends a non standard message and the pointers are off. I will add a check for that when I am home.
Return to “piBeacon”
