Pi-Hole (ad blocking DNS server) Controller
Ramias
Re: Pi-Hole (ad blocking DNS server) Controller
Post by Ramias »
What issue did you have with the virtual switch?
Professor Falken
Post by Professor Falken »
I'm suddenly having trouble again toggling off the pi-hole and having it stay off. I had this issue before with the first iteration of the plugin (see earlier in this thread) but this time even using the "turn-off" command isn't sticking. The pi-hole briefly disables but then almost immediately turns itself back on.
Since I am away from home at the moment, I can not easily access the native pi-hole browser-based controls to see if disabling it that way would work better.
Has anyone else seen this behavior recently?
Ramias
Post by Ramias »
Not seen this.
Are you using a toggle command or discreet off/on commands?
johnfdl
Post by johnfdl »
I'd love if the Alexa command to temporarily turn off pihole was "Alexa, shut your pie hole"
Professor Falken
Ramias wrote:Not seen this.
I've been using the toggle command without issue since your fix right after the release.
I think it's the Pi. It seems to lock up, and when it does, it won't allow the plugin to disable. At the same time, it won't let me in via the native browser interface either. I've had to hard reset it to regain control. Strangely, I think its blocking functions continue to work perfectly when this happens.
In order to maintain peace in my family (apparently everyone else is just fine with being tracked and ad-served to death) I've had to take it offline until I can figure out what is going on.
do you do a night reboot?
some apps do not shut down with "sudo reboot now"
you need to do a "sudo killall -9 xxx; sleep 1; sudo reboot now"
with xxx the programs you like to stop eg python
when the reboot starts most processes stop (eg ssh server... ) but if some continue, the reboot does not complete.
Professor Falken
That's an interesting idea. I guess I could look into how to schedule a nightly reboot. Is this a common practice with people's pi-hole setups. I have a different Pi managing my alarm system and have never had this issue.
Is there a command to schedule a reboot on the pi, or is that something handled through Indigo with a plugin?
jalves
Post by jalves »
Professor Falken wrote:That's an interesting idea. I guess I could look into how to schedule a nightly reboot. Is this a common practice with people's pi-hole setups.
The only time I reboot my pi-hole is an occasional maintenance update. Perhaps once a month?
Jeff
DaveL17
Post by DaveL17 »
jalves wrote:The only time I reboot my pi-hole is an occasional maintenance update. Perhaps once a month?
Likewise. I don't think I've ever rebooted my pi-hole for any other reason. I do not use the plugin, if that's a factor.
My Plugins and Scripts
autolog
Post by autolog »
I am trying to log into my raspberry pi running pi-hole using ssh.I am getting connection refused on port 22 before I even get the chance to enter the password. :?
It's a while since I have tried this - what userid should I sign in with?
DaveL17
Post by DaveL17 »
Depending on how you have it set up, you might need to sudo.
The only thing I do differently is I typically use the mDNS name of the pi.
autolog wrote:I am trying to log into my raspberry pi running pi-hole using ssh.I am getting connection refused on port 22 before I even get the chance to enter the password. :?
Are you sure you enabled ssh on the rPi? It's not enabled by default.
And the default userid on an rPi is 'pi'.
DaveL17
Post by DaveL17 »
Good call on both those tips, too.
When I first set up a pi, I establish a new user and delete the user ‘pi’.
Professor Falken
When mine is locking up (which we know because it stops responding to the plugin) I have been unable to easily SSH in either. Although it will prompt me for the password, it won't accept it.
I am by no means a networking guru, but I found a tip online to try the command: ssh -I pi@address. I then used the standard ssh pi@address and it would prompt and accept my password. I don't even know what the -I command is doing, but it unsticks it enough for me to get in.
I would let it run do a terminal ssh session
And a
tail -F /var/log/syslog
Leave it running. ( capital F just in case the file gets recycled )
That should show you when something is happening.
Return to “User Plugins”
