Better Email Change Mail Password
Had to change the password I was using for my Better Email plugin and now it’s erroring out
and won’t allow me to open the configure to change it.
Tried the device settings menu on the device as well and it won’t open there either.
Seems completely locked up. Is there some way to disable it and be able to make the password change?
Carl
Carl
- FlyingDiver
Re: Better Email Change Mail Password
Post the errors from the log.
2019-08-03 00:14:42.396 Better Email Error Better Email Setup: SMTP server connection error: (535, '5.7.8 Username and Password not accepted. Learn more at\n5.7.8 https://support.google.com/mail/?p=BadCredentials n140sm78677234pfd.132 - gsmtp')
gin1() caught exception: PacketTargetNotConnectedError -- plugin Better Email is not enabled
Error (client) getXmlFromPlugin() caught exception: PacketTargetNotConnectedError -- plugin Better Email is not enabled
Error (client) runConfigDialog() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
Carl
- FlyingDiver
Does the Indigo client lock up totally, or just the plugin? Can you use the Menu command to clear all the queues?
- FlyingDiver
Is "Better Email Setup" the name of your SMTP server device?
The server is very sluggish and I'm not able to open the BE device to edit it.
Here's another error log section.
Carl
Better Email Error Better Email IMAP: Error connecting to IMAP server: IMAP4 protocol error: socket error: <type 'exceptions.IOError'> - Too many read 0
Better Email Error exception in deviceStartComm(Better Email IMAP): IMAP4 protocol error: socket error: <type 'exceptions.IOError'> - Too many read 0
Error (client) received unexpected packet response CalcDeviceFunc (waiting for )
Error (client) received unexpected packet response UiGetValues2 (waiting for )
Error (client) received unexpected packet response CallPluginFunc (waiting for )
Error (client) received unexpCarl
- FlyingDiver
Are you able to use the "Clear All Email Queues" menu item in the plugins->Better Email menu?
- FlyingDiver
Have you actually restarted the plugin? I think it's stuck because there's an email it's trying to send, and it's can't. Restarting the plugin should clear that email from the queue so it won't get stuck. You need to make sure there's nothing else going on that would try to send an email while you're fixing the password.
I have restarted the plugin a number of times, cleared the email que and restarted the Indigo server.
I was just now able to edit the device settings to change the password but the BE device still shows “failure”.
I checked the other gmail settings and all seems the same. No idea what’s happening.
edit: It’s been so long since I set this up I don’t remember why I have 2 BE devices.
Are two required?
Carl
Are two required?
Carl
- 2FC44D32-7070-43BF-B742-ED6B4A98055B.jpeg (35.17 KiB) Viewed 3974 times
- FlyingDiver
Can you enable debug level logging? I have no idea why it's getting stuck where it is after a restart.
No, can’t enable debugging. Very locked up again.
Carl
Carl
- FlyingDiver
Stop the plugin and edit the preferences file by hand. Set the log level to 10. If you're running 7.3, it's at:
/Library/Application Support/Perceptive Automation/Indigo 7.3/Preferences/Plugins/com.flyingdiver.indigoplugin.betteremail.indiPref
- FlyingDiver
If they're both of type SMTP, then no. You only need one SMTP device per sending account. And an IMAP or POP device to receive emails.ckeyes888 wrote: edit: It’s been so long since I set this up I don’t remember why I have 2 BE devices.
I would definitely delete one of them.
I set the the pref file and see this in the log:
Started plugin "Better Email 7.2.4"
Better Email Starting Better Email
Better Email Debug Better Email IMAP: Starting device (imapAccount)
Better Email Debug Better Email IMAP: Creating IMAP Server
Better Email Debug Better Email IMAP: Using IMAP IDLE
Better Email Debug Better Email IMAP: Doing connect using encryptionType = SSL
Also deleted one of the BE devices but nothing has changed.
Carl
Carl
- FlyingDiver
That's all? Nothing after that? That doesn't even show the SMTP device starting up.
