Adapters Plugin [archive]
Re: Adapters Plugin
Not sure what's causing the error, but it's working fine for me. Do your settings resemble these?
My Plugins and Scripts
Re: Adapters Plugin
Dave, Thanks for the support. I put the parameters you recommended into the adapter. I assume the symbol for degree is option shift 8 on a Mac keyboard.
Adapters Error Error in plugin execution ServerReplacedElem:
File "plugin.py", line 127, in deviceUpdated
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/plugin_base.py", line 1179, in deviceUpdated
File "plugin.py", line 110, in deviceStartComm
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/sensor_adapter.py", line 25, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/sensor_adapter.py", line 76, in __init__
KeyError: key formula not found in dict
Mike
Mike
- Screen Shot 2019-06-09 at 1.29.53 PM.jpg (79.91 KiB) Viewed 9302 times
Re: Adapters Plugin
Dave,
So if these parameters work correctly on your system there must be something wrong with my Indigo setup.
Mike
Mike
Re: Adapters Plugin
Hi Again Dave,
So restarting IndigoServer eliminated the errors buy the Adapter plugin now shows 0 degrees even those I'm asking it to subtract 6.8 degrees from the physical device's reported 78.2 degrees.
Could the ° symbol I used is not recognized as a valid unit?
Thx
Mike
Thx
Mike
Re: Adapters Plugin
I'm digging in the code.
The error isn't anything you're doing - there appears to be a bug in the code, because "formula" (key formula not found in dict) is not supposed to be in the dict, so it shouldn't be trying to reference it.
I also get 0, and if you stop/start the device you get the error back again...
Dave, is it working for you?
Re: Adapters Plugin
Thanks guys!!!
Re: Adapters Plugin
Ok, he's got an easily fixable bug.
Download the attached Devices.xml and save it into
\Library\Application Support\Perceptive Automation\Indigo 7.3\Plugins\Adapters.indigoPlugin\Contents\Server Plugin\
(If you're not familiar with plugins, you'll need to right-click Adapters.indigoPlugin and "Show package contents")
Then restart the plugin, delete your adapter device, and recreate it.
Peter
Peter
- Devices.xml
- (6.72 KiB) Downloaded 330 times
Re: Adapters Plugin
Matt/Jay, i'm intending publishing a new Nissan Leaf plugin (also Dusty's).
Dusty has touched his github account twice in the last 18 months, so obviously isn't active anywhere at present.
Can I takeover his plugin(s) - Nissan Leaf and Adapters certainly, to post up this fixed version? Not sure if he has others?
Peter
Peter
Re: Adapters Plugin
(Just looked; the only other plugin is Ecobee - anyone else want to take on that one?)
Peter
Peter
Re: Adapters Plugin
That’s great; I only searched his posts on here, I didn’t actually read them so it might have said that in a reply sonewhere.
Re: Adapters Plugin
It's working for me without errors, but I can't guarantee that I'm on the latest version of the plugin. It look like the degree symbol is being used in a standard python string format conversion, so it really shouldn't be related to the error. Regardless, it sounds like Peter may be willing to fork the plugin and fix the error for good.howartp wrote:I'm digging in the code.
- jay (support)
- Site Admin
- Contact:
Re: Adapters Plugin
@howartp - I've sent @DustySparkle an email to enquire. I'll let you know when I get a reply. If he's no longer maintaining them, then we'll figure out the best course for getting those moved to the right spots so you can take over maintenance. Thanks for the offer!howartp wrote:Can I takeover his plugin(s) - Nissan Leaf and Adapters certainly, to post up this fixed version? Not sure if he has others?
Re: Adapters Plugin
Any news Jay?
- jay (support)
- Site Admin
- Contact:
Re: Adapters Plugin
No. If I don't hear by Monday, we'll consider what to do next. The issue is that he used the Apache 2.0 license (rather than a less restrictive license like MIT or Unlicense). That license carries some requirements that are somewhat burdensome, namely section 4b:
This is why the MIT license is SO MUCH BETTER for our purposes and we highly recommend that people use that instead.
That's a pain to enforce when multiple people are working on the same source. Since we would be distributing the plugin via the store, we would (theoretically) be liable for a variety of things: 1) the License file wouldn't be included in the plugin bundle so it would have the effect of being distributed without the license and 2) if you (or anyone contributing to it) forgot to attribute their changes clearly in the source, then we would be liable for that as well (again because we're distributing it).You must cause any modified files to carry prominent notices stating that You changed the files
Re: Adapters Plugin
Leaf won’t be a problem as I’m rewriting that with a different base library; I never liked his implementation anyway!
