Apologies for being off topic, but this is the audience that might have an answer for me.
A Galaxy Tab GT-P7510 running Honeycomb 3.1 has come into my hands and the hardware is pristine. Unfortunately the software is just about useless--can't log in to the software update as I get "your country is unsupported" error, so can't add anything.
I'm looking first for any hints about how I might update this after the internet proved no help. And second, if I can't update it, anyone have ideas how I could use this as more than a rather limited web page display?
thanks!
Stuck in the Honeycomb
- Different Computers
- Contact:
- RogueProeliator
Re: Stuck in the Honeycomb
Probably your only option to get up to a decent version is going to be to unlock the bootloader, root the device, and install a custom recovery... then that will allow you to install a custom ROM built on, say, Nougat. That is a pretty old device and I didn't see much available past that on a quick search.I'm looking first for any hints about how I might update this after the internet proved no help. And second, if I can't update it, anyone have ideas how I could use this as more than a rather limited web page display?
That is a decent amount of work to do but there should be some scripts out there that you can run with it connected to your computer via USB in debug mode. Most older devices have an unlock / root method that has been scripted. Anything you find from XDA (forums.xda-developers.com) should be safe and pretty solid.
As @Ianbrown said, you need at least 4.4, I would consider Android 5.0 (Lollipop) a minimum really.
- Contact:
Thanks for the advice and links. I did find some references to Honeycomb/my model Tab and Odin, so I think it can work.
Also good to know that choosing to root my device isn't necessarily risking me giving some root kit writer access too.
