UniFi WiFi AP: download
Re: uniFi WiFi AP: download
posted: 7.26.163
fixed: "key ip.. not found in dict"
the new version .165 posted:
Will adopt / add an unify automatically --> indigo device if
- a sw / ap / gw slot (in config) is "disabled and the ip number is NOT a valid one"
- it assumes that if there is a valid IP number and you have disabled it might be temporary setting by the user and will not change that
==> when editing the IP number in config, you MUST edit the field then click on another text field. otherwise it will not save that field (that's from indigo)
so when eg you edit the ip number and click on enable/disable, the ip textfield contents will not be saved.
new version 7.26.167 posted
Mojave seems to have problems with reading streaming files. It sometimes gives read error 22.
It looks as if a reduction in buffer size (from 32k to eg 16k) seems to solve that.
Added option to set read buffer for listeners - in config at the bottom.
Default is 32767(32k) .
Only change if you have read error 22,
Thanks to Wouter to help find this solution and test it.
- I am still on High Sierra on the Indigo server .. need to add a new graphics card to upgrade my MAC Pro
release v 7.26.168
The camera event logs from unifi have changed with the recent unify NVR op sys upgrade
Now handles also the new version - detects both versions
- Different Computers
- Contact:
I don't see any other mention of this, but when I click the "download release 7.26.163" button on http://www.indigodomo.com/pluginstore/7 ... /7.26.163/ I get sent to
https://github.com/kw123/unifi/releases ... Plugin.zip which has nothing on it but "Not Found". Nothing downloads.
when i go to the plugin store and download the latest release it works fine. : v 7.26.168
oooh I see you want to download an older version.. and yes that one seems to have disappeared.. Also not on GitHub..
can't you use the latest V?
- Contact:
I wasn't trying to download an old version, so I'm not sure how I got to that page. Actually I am--when I select Download New Version from the Unifiap plugin menu, it takes me to that page. Where I see:
Latest release: v7.26.168 released on June 26, 2019
Release downloaded: 1 times
Requires: Indigo v7.0.2 or higher
(Check the Releases tab below for older releases that may have different requirements)
Download release v7.26.163
That last line is the button to download. note the difference.
But I've got the current version now, from the link below that.
I guess the solution is to delete that one.. will ask Matt/ Jay.
==> Matt, Jay, could you remove the entry from the selection?.
http://www.indigodomo.com/pluginstore/73/#id1230
UnifiAP plugin release 7.26.163
- Screen Shot 2019-07-16 at 17.44.49.png (177.96 KiB) Viewed 15187 times
- Screen Shot 2019-07-16 at 17.42.23.png (368.29 KiB) Viewed 15187 times
- jay (support)
- Site Admin
- Contact:
Deleted. Given that you deleted it from GitHub, I believe it should stay deleted in the Plugin Store.
changes in V 7.26.169 @ 2019-12-03
1. added option for gateway devices to select which MAC number to be used for reports
gateways have several MAC numbers, and depending on version the query has to pick the proper MAC number for querries in the controller
in device edit you can pick the MAC number (MAC or MAClan)
changes in V 7.27.169 @ 2019-02-09
1. will suppress certain states and variables from being logged in SQL logger. only works w indigo 7.4.1
no change for lower versions
changes in V 7.29.186 @ 2019-04-23
1. added additional userid/passwd for UDM devices
UDM devices have different userid/passwd for ssh than AP and switches.
2. add auto fix for "unknown hosts".
fixes situations where userid.. gets changed on ssh devices.
will delete the ip# line in userid/.ssh/known_hosts
changes in V 7.30.189 @ 2019-04-25
1. added option for UDM as its own section
will not start individual message logs/dicts for AP and SW as they come from the same device
.. not fully tested yet
2. added option "strict:true" for web login. this seems to be neeed fro some UDM / configs, sys, if it currently works keep false
3. added option to ignore all new devices in config
after some struggling w UDM vs UDM-pro and cloudy controllers, I believe the V .210 should be better.
fixed different versions of login responses w https
did detailed analysis of event logs from UDM controller and it is used now in parallel to regular AP in a proper way.
there might be still some issues left, but i hope it is much more stable now
and thanks go to Gareth for patiently testing versions and looking at logs
changes in V 7.31.238 @ 2019-05-12
MOSTLY FOR UDM INSTALLATIONS!!
1. added logging statements in case userid/passwd ip number are wrong
2. added UDM dict analysis
3. fixed format error
4. added space in button menue to improve readability
5. fixed some format statements and added some logic
6. "ipNumber" is now the defined ipnumber in config and is NOT taken from the dict from unifi (key="ip")
the "ip" entry in the dict can chnage ie for UGS or UDM devceis as they use the external value
7. select proper userid/passwd for UDM ssh
8. added option in MAC log-tracking menu to save MAC list and reload after plugin restart
and changed display of list, dev name first then mac#
9. added vlan name to device(client) states (info from switch devices port_table/mac_table)
10. changed dev-state wanRunDate to wanSpeedTest, gives the date when last speedtest was done
and thanks go to Gareth for many hours of remote debugging.
the plugin seems to work now for UDM devices.
- regular AP devices show in their log connect / disconnect events, the UDM does not. For the dum the plugin polls the UDM though http for events and gets that info from there.
- the ssh Mac-dump on UDM devices gives different data than the regular GW. this will select the proper fields now for UDM and populates the devices states for the gateway.
- the UDM does not expose DHCP data, at least I have not found any. you could switch on DPI then that info is used.
NOT TESTED if this will work on an UDM-pro
