Pi-Hole (ad blocking DNS server) Controller
Sat Apr 27, 2019 6:20 am
siclark offline
Re: Pi-Hole (ad blocking DNS server) Controller
If it's toggling straight back on I think you are using the wing password. It's a very long string for a web password. It's not the same admin page password to get to the console
Sat Apr 27, 2019 7:08 am
Professor Falken offline
That would cause different behavior when using the "toggle" Indigo command as opposed to "Turn On" or "Turn Off", both of which seem to work? It seems like would keep the plugin from working at all.
I used the API token I found on the console admin page.
Sat Apr 27, 2019 7:33 am
autolog offline
I think it is a bug in the plugin - I have just tested it and it does as you say. :|
At the risk of poking my nose in and getting it wrong :wink: and taking a quick look at the plugin code there is a comment where I would expect the code to do the hardware toggle i.e:
# Command hardware module (dev) to toggle here:
It looks as if the Indigo device is getting updated but no command is sent to Pi-Hole to do the same. The Indigo Device is therefore set back to the state of Pi-hole which hasn't been toggled at the next polling update (i.e. within 10 seconds in my case).
No doubt easily fixable. :)
Sat Apr 27, 2019 7:54 am
Ramias offline
Just pushed a new release to Github with toggle support.
EDIT: it is now in the Plugin Store.
Sat Apr 27, 2019 7:57 am
Ramias offline
Pi Hole has great logging. From the longs you can whitelist certain sites that are causing you issues (i.e. emails not rendering properly; so you can allow more in than what PiHole would initially block).
Separately, I did have issues with PiHole on a Raspberry Pi which I think was related to IO on the SD card. For this reason I run it in a docker container on my snap and it runs awesome. You could also run it in a docker container on your Mac.
Sat Apr 27, 2019 8:12 am
Thanks for both. I'll look into those options.
Sat Apr 27, 2019 8:26 am
siclark offline
I hadn't checked emails since setting this up yesterday but yes, had same problem but only had 2 sites to whitelist, so far. Better than turning the whole thing off.
Sat Apr 27, 2019 9:13 am
autolog offline
Not sure how long it will take to get to the Indigo Plugin Store.
But you can get it directly here: https://github.com/Ramias1/indigo-pi-ho ... /tag/1.1.0
Installed and tested OK. :)
Thanks for the ultra-quick fix. :D
Sun Apr 28, 2019 1:58 pm
Yes, the updated plugin fixed that issue perfectly, thanks.
I'm trying a fresh install (new card) with the pi before moving on to Docker on our Mac Mini. I did install Docker (toolbox, my mini is still running El Capitan) but it seemed to eat up a fair amount of memory, so I'd like to see if I can get pi-hole to run on the pi first before committing to that route. So far it's running a lot smoother (no DNS errors), but I've still got it in the "off" state right now, before enabling it and setting to whitelisting some of the sites that were causing family strife earlier.
Thanks for the update.
Sun Apr 28, 2019 3:06 pm
jalves offline
Just a suggestion for those who are inclined to try setting up a Pi-Hole as a result of this test. Go ahead and get a pi properly configured, but then try it out on a single machine on your LAN. Easy to do. On the Mac, go into the Network settings panel and click on advanced. Find the DNS tab and enter the ip address of your Pi. Then you can try normal activities on your Mac to see if anything is broken. Once you are comfortable, change your other computers over to the pi-hole.
Running Indigo 7.4 on a 27" iMac (mid-2017), 40G memory, 1T Fusion Drive, OS X 10.15.2
Jeff
Sun Apr 28, 2019 3:27 pm
Yeah, I kinda thought about that, but as the default "network manager" for a family of 4, I think I'd rather just get hit with all the various complaints (from all the devices) at once this weekend and see if I can knock them out with whitelisting.
I appreciate all the suggestions in this thread though.
It's funny how the Indigo board turns out to be such a useful resource for so much of home automation outside of just the Indigo implementation.
Sun Apr 28, 2019 11:35 pm
siclark offline
Interested to know what your issues were as I am running on a pi but have a qnap as well. Was it performance/speed related? Or it just didn't work?
Mon Apr 29, 2019 4:55 am
Ramias offline
Night,y around 10pm or so dns queries would just be not responsive for a brief period of time. Then resume.
0 issues in a container on the Qnap.
Fri May 03, 2019 12:19 pm
siclark offline
Cheers. Going to try the container. Did you follow instructions for it? I've found this which suggests a different way to install it got seems easy to follow.
https://forum.qnap.com/viewtopic.php?t=147501
Fri May 03, 2019 5:01 pm
siclark offline
Got this working as per the instructions but lots of difficulty with the virtual switch for a few hours.
So much faster then the rPi2. I don't suggest anyone try on less than a 3.
