Hue Lights discussion
yassi
Re: Hue Lights discussion
Post by yassi »
Hi Nathan,
thanks for coming back.
Here we go.
The Inner bulb is called "Bettlampe", as mentioned it's the RB 185C.
27.01.2019, 10:02:41
   Hue Lights                      Debug logging enabled
   Hue Lights Debug                Starting updateSensorsList.
   Hue Lights Debug                Starting parseAllHueSensorsData.
   Reloading plugin "Hue Lights 1.6.27"
   Stopping plugin "Hue Lights 1.6.27" (pid 19646)
   Hue Lights Debug                runConcurrentThread stopped.
   Hue Lights Debug                runConcurrentThread exiting.
   Hue Lights Debug                Stopping device: Couchlampe
   Hue Lights Debug                Stopping device: Flurlampe
   Stopped plugin "Hue Lights 1.6.27"
   Starting plugin "Hue Lights 1.6.27" (pid 36496)
   Hue Lights Debug                Initializing Plugin.
   Started plugin "Hue Lights 1.6.27"
   Hue Lights Debug                Startup called.
   Hue Lights Debug                Running plugin version check (if enabled).
   Hue Lights Debug                pluginPrefs contains 30 presets.
   Hue Lights Debug                pluginPrefs are:
Prefs : (dict)
     address : 192.168.100.105 (string)
     debugLabel :  (string)
     emailLabel :  (string)
     hostId : 7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq (string)
     instructions0 :  (string)
     instructions1 :  (string)
     instructions2 :  (string)
     instructions3 :  (string)
     labelAddress :  (string)
     labelHostId :  (string)
     maxPresetCount : 30 (string)
     maxPresetCountLabel :  (string)
     noticeLabel :  (string)
     noticeLabel0 :  (string)
     presets : (list)
          Item : (list)
               Item : Preset 1 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 2 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 3 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 4 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 5 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 6 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 7 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 8 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 9 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 10 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 11 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 12 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 13 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 14 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 15 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 16 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 17 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 18 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 19 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 20 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 21 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 22 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 23 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 24 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 25 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 26 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 27 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 28 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 29 (string)
               Item : (dict)
          Item : (list)
               Item : Preset 30 (string)
               Item : (dict)
     sep0 :  (string)
     sep00 :  (string)
     sep1 :  (string)
     sep2 :  (string)
     showDebugInfo : true (bool)
     startPairingButton :  (string)
     title :  (string)
     updaterEmail : [email protected] (string)
     updaterEmailsEnabled : true (bool)
     updaterLastCheck : 1548530176 (real)
     updaterLastVersionEmailed : 1.6.27 (string)
   Hue Lights Debug                The username Hue Lights uses to connect to the Hue hub is 7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq
   Hue Lights Debug                Starting getHueConfig.
   Hue Lights Debug                Sending command to hub: http://192.168.100.105/api/7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq/
   Hue Lights Debug                Got response {u'rules': {}, u'resourcelinks': {}, u'scenes': {u'FknzutOGHm4BYsX': {u'picture': u'', u'group': u'1', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'usdOu_r01_d07'}, u'lights': [u'1', u'2'], u'lastupdated': u'2019-01-25T16:54:44', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'yFwsHk1yJxSFl89': {u'picture': u'', u'group': u'3', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'lNgcI_r03_d05'}, u'lights': [u'3'], u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'kdzO5Ko18osmZD3': {u'picture': u'', u'group': u'4', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'fNBn4_r04_d06'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'lrfEjORNiWi57sk': {u'picture': u'', u'group': u'4', u'name': u'Tropend\xe4mmerung', u'appdata': {u'version': 1, u'data': u'oZLWi_r04_d16'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'hQaXlPphHWVOxDF': {u'picture': u'', u'group': u'4', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'eSBHw_r04_d05'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'7QgI7NTQy8fZcu3': {u'picture': u'', u'group': u'4', u'name': u'Fr\xfchlingsbl\xfcten', u'appdata': {u'version': 1, u'data': u'Q5MeU_r04_d18'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'WZnkjWsKhaR3A0v': {u'picture': u'', u'group': u'4', u'name': u'Lesen', u'appdata': {u'version': 1, u'data': u'taa8l_r04_d02'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:37', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'-cndADBHxR71zS9': {u'picture': u'', u'group': u'3', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'R2BaF_r03_d06'}, u'lights': [u'3'], u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'c37A8UgQg5CTb03': {u'picture': u'', u'group': u'4', u'name': u'Entspannen', u'appdata': {u'version': 1, u'data': u'vJEIV_r04_d01'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:37', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'S0mKdDgaKyvV-Me': {u'picture': u'', u'group': u'3', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'1Iamu_r03_d07'}, u'lights': [u'3'], u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'h9bdCAjaKr5tpVq': {u'picture': u'', u'group': u'1', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'1VI5t_r01_d05'}, u'lights': [u'1', u'2'], u'lastupdated': u'2019-01-25T16:54:44', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'yQ17vjEsOf3udxO': {u'picture': u'', u'group': u'4', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'ehrih_r04_d07'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'0U5B7gai07Ju1UY': {u'picture': u'', u'group': u'4', u'name': u'Energie tanken', u'appdata': {u'version': 1, u'data': u'AB5Ky_r04_d04'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'UusHfDe9hOQiIAW': {u'picture': u'', u'group': u'1', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'tMqXz_r01_d06'}, u'lights': [u'1', u'2'], u'lastupdated': u'2019-01-25T16:54:44', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'dXMWPRKM1o19CJb': {u'picture': u'', u'group': u'4', u'name': u'Nordlichter', u'appdata': {u'version': 1, u'data': u'yTx1G_r04_d17'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'Pu5spbERsxuPreh': {u'picture': u'', u'group': u'4', u'name': u'Konzentrieren', u'appdata': {u'version': 1, u'data': u'6ztbk_r04_d03'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'9Emql0TziBf5wSL': {u'picture': u'', u'group': u'4', u'name': u'Sonnenuntergang Savanne', u'appdata': {u'version': 1, u'data': u'L4qxq_r04_d15'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}}, u'lights': {u'1': {u'swversion': u'5.127.1.26420', u'name': u'Couchlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-28T18:36:14'}, u'uniqueid': u'00:17:88:01:10:2f:f2:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'1.46.13_r26312', u'name': u'Flurlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-28T18:38:01'}, u'productid': u'Philips-LWB010-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:86:2a:7c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Philips', u'swconfigid': u'564ABA6B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'2': {u'swversion': u'5.127.1.26420', u'name': u'Papierlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-28T18:36:16'}, u'uniqueid': u'00:17:88:01:02:30:83:9b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'4': {u'swversion': u'2.0', u'name': u'Bettlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-01-25T16:47:48'}, u'uniqueid': u'00:15:8d:00:02:0a:f5:3c-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.7, 0.3], [0.11, 0.82], [0.12, 0.08]], u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 370, u'sat': 204}, u'manufacturername': u'innr', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'RB 185 C'}}, u'groups': {u'1': {u'name': u'Wohnzimmer', u'lights': [u'1', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Flur', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'4': {u'name': u'Schlafzimmer', u'lights': [u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.4101], u'bri': 254, u'ct': 370, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}}, u'schedules': {}, u'sensors': {u'1': {u'name': u'Daylight', u'config': {u'on': True, u'configured': False, u'sunriseoffset': 30, u'sunsetoffset': -30}, u'swversion': u'1.0', u'state': {u'daylight': None, u'lastupdated': u'none'}, u'manufacturername': u'Philips', u'type': u'Daylight', u'modelid': u'PHDL00'}, u'2': {u'name': u'HL-S00-5000', u'uniqueid': u'4c:61:70:41:70:70:73-HL-00-00', u'config': {u'on': True, u'reachable': True}, u'swversion': u'1.0', u'state': {u'status': 0, u'lastupdated': u'none'}, u'manufacturername': u'LapApps, LLC', u'recycle': False, u'type': u'CLIPGenericStatus', u'modelid': u'HL_STATE'}}, u'config': {u'starterkitid': u'', u'portalconnection': u'connected', u'whitelist': {u'AqX9SvzhdHFIDi-cahZPXc-gqPkrqZ6rrbkw7pCy': {u'last use date': u'2019-01-26T14:08:55', u'create date': u'2017-01-13T17:09:38', u'name': u"OnSwitch#Yasmin's iPhone SE"}, u'ISgrTozzVVEstv43Wj20rKQhmd2P1cn1BbvU1K2g': {u'last use date': u'2017-01-13T17:20:31', u'create date': u'2017-01-13T17:10:51', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'XbfaBtDpRukAw6X01Xd09N6GOyO0KRKPDveTlg0a': {u'last use date': u'2019-01-26T14:08:55', u'create date': u'2019-01-07T20:42:26', u'name': u"HueLights#Yasmin's iPhone SE"}, u'7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq': {u'last use date': u'2019-01-27T09:02:50', u'create date': u'2016-11-16T18:34:51', u'name': u'Indigo Hue Lights'}, u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW': {u'last use date': u'2019-01-26T21:23:55', u'create date': u'2017-08-02T17:59:29', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'ZwgEWT0bpB3PCHYckFuA-oIN4FFuWHYSNGaIfxjX': {u'last use date': u'2017-08-01T20:42:29', u'create date': u'2017-07-08T16:02:57', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'JRhVcJCbOZYvqfjUR9To5u5AF0i0shLWlVM1eM3U': {u'last use date': u'2019-01-26T14:08:55', u'create date': u'2019-01-07T19:52:07', u'name': u'LightShow-Mac'}}, u'zigbeechannel': 20, u'timezone': u'Europe/Berlin', u'gateway': u'192.168.100.254', u'modelid': u'BSB002', u'portalstate': {u'communication': u'disconnected', u'outgoing': True, u'signedon': True, u'incoming': False}, u'proxyaddress': u'none', u'datastoreversion': u'76', u'replacesbridgeid': None, u'swupdate2': {u'bridge': {u'state': u'noupdates', u'lastinstall': u'2019-01-14T19:38:57'}, u'lastchange': u'2019-01-25T16:47:48', u'checkforupdate': False, u'state': u'noupdates', u'autoinstall': {u'on': False, u'updatetime': u'T14:00:00'}}, u'dhcp': True, u'localtime': u'2019-01-27T10:02:50', u'proxyport': 0, u'UTC': u'2019-01-27T09:02:50', u'factorynew': False, u'swupdate': {u'devicetypes': {u'bridge': False, u'sensors': [], u'lights': []}, u'url': u'', u'text': u'', u'checkforupdate': False, u'updatestate': 0, u'notify': True}, u'apiversion': u'1.29.0', u'mac': u'00:17:88:40:4e:5f', u'linkbutton': False, u'bridgeid': u'001788FFFE404E5F', u'ipaddress': u'192.168.100.105', u'portalservices': False, u'name': u'Philips hue', u'swversion': u'1811120916', u'netmask': u'255.255.255.0', u'internetservices': {u'swupdate': u'connected', u'time': u'connected', u'remoteaccess': u'disconnected', u'internet': u'connected'}, u'backup': {u'status': u'idle', u'errorcode': 0}}}
   Hue Lights Debug                Loaded entire Hue hub configuration - {u'rules': {}, u'resourcelinks': {}, u'scenes': {u'FknzutOGHm4BYsX': {u'picture': u'', u'group': u'1', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'usdOu_r01_d07'}, u'lights': [u'1', u'2'], u'lastupdated': u'2019-01-25T16:54:44', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'yFwsHk1yJxSFl89': {u'picture': u'', u'group': u'3', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'lNgcI_r03_d05'}, u'lights': [u'3'], u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'kdzO5Ko18osmZD3': {u'picture': u'', u'group': u'4', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'fNBn4_r04_d06'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'lrfEjORNiWi57sk': {u'picture': u'', u'group': u'4', u'name': u'Tropend\xe4mmerung', u'appdata': {u'version': 1, u'data': u'oZLWi_r04_d16'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'hQaXlPphHWVOxDF': {u'picture': u'', u'group': u'4', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'eSBHw_r04_d05'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'7QgI7NTQy8fZcu3': {u'picture': u'', u'group': u'4', u'name': u'Fr\xfchlingsbl\xfcten', u'appdata': {u'version': 1, u'data': u'Q5MeU_r04_d18'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'WZnkjWsKhaR3A0v': {u'picture': u'', u'group': u'4', u'name': u'Lesen', u'appdata': {u'version': 1, u'data': u'taa8l_r04_d02'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:37', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'-cndADBHxR71zS9': {u'picture': u'', u'group': u'3', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'R2BaF_r03_d06'}, u'lights': [u'3'], u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'c37A8UgQg5CTb03': {u'picture': u'', u'group': u'4', u'name': u'Entspannen', u'appdata': {u'version': 1, u'data': u'vJEIV_r04_d01'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:37', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'S0mKdDgaKyvV-Me': {u'picture': u'', u'group': u'3', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'1Iamu_r03_d07'}, u'lights': [u'3'], u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'h9bdCAjaKr5tpVq': {u'picture': u'', u'group': u'1', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'1VI5t_r01_d05'}, u'lights': [u'1', u'2'], u'lastupdated': u'2019-01-25T16:54:44', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'yQ17vjEsOf3udxO': {u'picture': u'', u'group': u'4', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'ehrih_r04_d07'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'0U5B7gai07Ju1UY': {u'picture': u'', u'group': u'4', u'name': u'Energie tanken', u'appdata': {u'version': 1, u'data': u'AB5Ky_r04_d04'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'UusHfDe9hOQiIAW': {u'picture': u'', u'group': u'1', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'tMqXz_r01_d06'}, u'lights': [u'1', u'2'], u'lastupdated': u'2019-01-25T16:54:44', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'dXMWPRKM1o19CJb': {u'picture': u'', u'group': u'4', u'name': u'Nordlichter', u'appdata': {u'version': 1, u'data': u'yTx1G_r04_d17'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'Pu5spbERsxuPreh': {u'picture': u'', u'group': u'4', u'name': u'Konzentrieren', u'appdata': {u'version': 1, u'data': u'6ztbk_r04_d03'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}, u'9Emql0TziBf5wSL': {u'picture': u'', u'group': u'4', u'name': u'Sonnenuntergang Savanne', u'appdata': {u'version': 1, u'data': u'L4qxq_r04_d15'}, u'lights': [u'4'], u'lastupdated': u'2019-01-25T16:50:38', u'recycle': False, u'version': 2, u'owner': u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW', u'locked': False, u'type': u'GroupScene'}}, u'lights': {u'1': {u'swversion': u'5.127.1.26420', u'name': u'Couchlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-28T18:36:14'}, u'uniqueid': u'00:17:88:01:10:2f:f2:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'1.46.13_r26312', u'name': u'Flurlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-28T18:38:01'}, u'productid': u'Philips-LWB010-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:86:2a:7c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Philips', u'swconfigid': u'564ABA6B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'2': {u'swversion': u'5.127.1.26420', u'name': u'Papierlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-28T18:36:16'}, u'uniqueid': u'00:17:88:01:02:30:83:9b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'4': {u'swversion': u'2.0', u'name': u'Bettlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-01-25T16:47:48'}, u'uniqueid': u'00:15:8d:00:02:0a:f5:3c-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.7, 0.3], [0.11, 0.82], [0.12, 0.08]], u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 370, u'sat': 204}, u'manufacturername': u'innr', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'RB 185 C'}}, u'groups': {u'1': {u'name': u'Wohnzimmer', u'lights': [u'1', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Flur', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'4': {u'name': u'Schlafzimmer', u'lights': [u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.4101], u'bri': 254, u'ct': 370, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}}, u'schedules': {}, u'sensors': {u'1': {u'name': u'Daylight', u'config': {u'on': True, u'configured': False, u'sunriseoffset': 30, u'sunsetoffset': -30}, u'swversion': u'1.0', u'state': {u'daylight': None, u'lastupdated': u'none'}, u'manufacturername': u'Philips', u'type': u'Daylight', u'modelid': u'PHDL00'}, u'2': {u'name': u'HL-S00-5000', u'uniqueid': u'4c:61:70:41:70:70:73-HL-00-00', u'config': {u'on': True, u'reachable': True}, u'swversion': u'1.0', u'state': {u'status': 0, u'lastupdated': u'none'}, u'manufacturername': u'LapApps, LLC', u'recycle': False, u'type': u'CLIPGenericStatus', u'modelid': u'HL_STATE'}}, u'config': {u'starterkitid': u'', u'portalconnection': u'connected', u'whitelist': {u'AqX9SvzhdHFIDi-cahZPXc-gqPkrqZ6rrbkw7pCy': {u'last use date': u'2019-01-26T14:08:55', u'create date': u'2017-01-13T17:09:38', u'name': u"OnSwitch#Yasmin's iPhone SE"}, u'ISgrTozzVVEstv43Wj20rKQhmd2P1cn1BbvU1K2g': {u'last use date': u'2017-01-13T17:20:31', u'create date': u'2017-01-13T17:10:51', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'XbfaBtDpRukAw6X01Xd09N6GOyO0KRKPDveTlg0a': {u'last use date': u'2019-01-26T14:08:55', u'create date': u'2019-01-07T20:42:26', u'name': u"HueLights#Yasmin's iPhone SE"}, u'7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq': {u'last use date': u'2019-01-27T09:02:50', u'create date': u'2016-11-16T18:34:51', u'name': u'Indigo Hue Lights'}, u'FHizAWZ-oqj-I6Ec9hgusF0dtUA20DO-vZNB3XMW': {u'last use date': u'2019-01-26T21:23:55', u'create date': u'2017-08-02T17:59:29', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'ZwgEWT0bpB3PCHYckFuA-oIN4FFuWHYSNGaIfxjX': {u'last use date': u'2017-08-01T20:42:29', u'create date': u'2017-07-08T16:02:57', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'JRhVcJCbOZYvqfjUR9To5u5AF0i0shLWlVM1eM3U': {u'last use date': u'2019-01-26T14:08:55', u'create date': u'2019-01-07T19:52:07', u'name': u'LightShow-Mac'}}, u'zigbeechannel': 20, u'timezone': u'Europe/Berlin', u'gateway': u'192.168.100.254', u'modelid': u'BSB002', u'portalstate': {u'communication': u'disconnected', u'outgoing': True, u'signedon': True, u'incoming': False}, u'proxyaddress': u'none', u'datastoreversion': u'76', u'replacesbridgeid': None, u'swupdate2': {u'bridge': {u'state': u'noupdates', u'lastinstall': u'2019-01-14T19:38:57'}, u'lastchange': u'2019-01-25T16:47:48', u'checkforupdate': False, u'state': u'noupdates', u'autoinstall': {u'on': False, u'updatetime': u'T14:00:00'}}, u'dhcp': True, u'localtime': u'2019-01-27T10:02:50', u'proxyport': 0, u'UTC': u'2019-01-27T09:02:50', u'factorynew': False, u'swupdate': {u'devicetypes': {u'bridge': False, u'sensors': [], u'lights': []}, u'url': u'', u'text': u'', u'checkforupdate': False, u'updatestate': 0, u'notify': True}, u'apiversion': u'1.29.0', u'mac': u'00:17:88:40:4e:5f', u'linkbutton': False, u'bridgeid': u'001788FFFE404E5F', u'ipaddress': u'192.168.100.105', u'portalservices': False, u'name': u'Philips hue', u'swversion': u'1811120916', u'netmask': u'255.255.255.0', u'internetservices': {u'swupdate': u'connected', u'time': u'connected', u'remoteaccess': u'disconnected', u'internet': u'connected'}, u'backup': {u'status': u'idle', u'errorcode': 0}}}
   Hue Lights                      Loaded 4 lights.
   Hue Lights                      Loaded 3 groups.
   Hue Lights                      Loaded 17 scenes.
   Hue Lights                      Loaded 2 sensors.
   Hue Lights Debug                Starting device: Couchlampe
   Hue Lights Debug                Starting rebuildDevice.
   Hue Lights Debug                The Couchlampe device is a Hue light device and it's configured.
   Hue Lights Debug                Hue device definition:
address : 192.168.100.105 (ID 1)
batteryLevel : None
blueLevel : None
brightness : 0
buttonGroupCount : 0
configured : True
defaultBrightness : 100
description :
deviceTypeId : hueLivingWhites
displayStateValRaw : 0
displayStateValUi : 0
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 169844372
     com.indigodomo.opensource.alexa-hue-bridge : (dict)
          ahb-45202195 : (dict)
               alternate-name : Lampe Couch (string)
               published : True (string)
     com.nathansheldon.indigoplugin.HueLights : (dict)
          SupportsColor : false (bool)
          SupportsRGB : false (bool)
          SupportsWhite : false (bool)
          SupportsWhiteTemperature : false (bool)
          address : 192.168.100.105 (ID 1) (string)
          bulbId : 1 (string)
          defaultBrightness : 100 (string)
          manufacturerName : Philips (string)
          modelId : LWB006 (string)
          nameOnHub : Couchlampe (string)
          rate : 0 (string)
          savedBrightness : 1 (integer)
          swVersion : 5.127.1.26420 (string)
          type : Dimmable light (string)
          uniqueId : 00:17:88:01:10:2f:f2:0b-0b (string)
greenLevel : None
lastChanged : 2019-01-26 18:01:37
lastSuccessfulComm : 2019-01-26 18:01:37
ledStates : []
model : LivingWhites (Hue Lux, Generic Light, etc.)
onBrightensToDefaultToggle : False
onBrightensToLast : False
onState : False
ownerProps : com.nathansheldon.indigoplugin.HueLights : (dict)
     bulbId : 1 (string)
     rate : 0 (string)
pluginId : com.nathansheldon.indigoplugin.HueLights
pluginProps : com.nathansheldon.indigoplugin.HueLights : (dict)
     bulbId : 1 (string)
     rate : 0 (string)
protocol : Plugin
redLevel : None
remoteDisplay : True
states : States : (dict)
     alertMode : none (string)
     brightnessLevel : 0 (integer)
     brightnessLevel.ui : 0 (string)
     effect :  (string)
     online : true (bool)
     online.ui : True (string)
subModel :
supportsAllOff : False
supportsColor : False
supportsRGB : False
supportsStatusRequest : True
supportsWhite : False
version : None
whiteLevel : None
whiteLevel2 : None
whiteTemperature : None
   Hue Lights Debug                Starting device: Flurlampe
   Hue Lights Debug                The Flurlampe device is a Hue light device and it's configured.
address : 192.168.100.105 (ID 3)
batteryLevel : None
blueLevel : None
brightness : 0
configured : True
description :
enabled : True
errorState :
folderId : 636007061
          address : 192.168.100.105 (ID 3) (string)
          bulbId : 3 (string)
          modelId : LWB010 (string)
          nameOnHub : Flurlampe (string)
          rate : 0 (string)
          swVersion : 1.46.13_r26312 (string)
          uniqueId : 00:17:88:01:02:86:2a:7c-0b (string)
greenLevel : None
lastChanged : 2019-01-27 10:01:54
lastSuccessfulComm : 2019-01-27 10:01:54
ledStates : []
onState : False
     bulbId : 3 (string)
     rate : 0 (string)
     bulbId : 3 (string)
     rate : 0 (string)
protocol : Plugin
redLevel : None
     alertMode.ui : none (string)
     effect :  (string)
subModel :
supportsRGB : False
version : None
whiteLevel : None
whiteLevel2 : None
   Hue Lights Debug                Starting device: Papierlampe
   Hue Lights Debug                The Papierlampe device is a Hue light device and it's configured.
address : 192.168.100.105 (ID 2)
batteryLevel : None
blueLevel : None
brightness : 0
configured : True
description :
enabled : True
errorState :
               alternate-name : Papierlampe (string)
          address : 192.168.100.105 (ID 2) (string)
          bulbId : 2 (string)
          defaultBrightness : 50 (string)
          nameOnHub : Papierlampe (string)
          rate : 0 (string)
          uniqueId : 00:17:88:01:02:30:83:9b-0b (string)
greenLevel : None
lastChanged : 2019-01-26 22:13:55
lastSuccessfulComm : 2019-01-26 22:13:55
ledStates : []
onState : False
     bulbId : 2 (string)
     rate : 0 (string)
     bulbId : 2 (string)
     rate : 0 (string)
protocol : Plugin
redLevel : None
     alertMode : select (string)
     alertMode.ui : select (string)
     effect :  (string)
subModel :
supportsRGB : False
version : None
whiteLevel : None
whiteLevel2 : None
   Hue Lights Debug                Starting didDeviceCommPropertyChange.
   Hue Lights Debug                Starting runConcurrentThread.
   Hue Lights Debug                Starting updateLightsList.
   Hue Lights Debug                Sending command to hub: http://192.168.100.105/api/7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq/lights
   Hue Lights Debug                Got response {u'1': {u'swversion': u'5.127.1.26420', u'name': u'Couchlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-28T18:36:14'}, u'uniqueid': u'00:17:88:01:10:2f:f2:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'1.46.13_r26312', u'name': u'Flurlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-28T18:38:01'}, u'productid': u'Philips-LWB010-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:86:2a:7c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Philips', u'swconfigid': u'564ABA6B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'2': {u'swversion': u'5.127.1.26420', u'name': u'Papierlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-28T18:36:16'}, u'uniqueid': u'00:17:88:01:02:30:83:9b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'4': {u'swversion': u'2.0', u'name': u'Bettlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-01-25T16:47:48'}, u'uniqueid': u'00:15:8d:00:02:0a:f5:3c-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.7, 0.3], [0.11, 0.82], [0.12, 0.08]], u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 370, u'sat': 204}, u'manufacturername': u'innr', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'RB 185 C'}}
   Hue Lights Debug                Loaded lights list - {u'1': {u'swversion': u'5.127.1.26420', u'name': u'Couchlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-28T18:36:14'}, u'uniqueid': u'00:17:88:01:10:2f:f2:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'1.46.13_r26312', u'name': u'Flurlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-28T18:38:01'}, u'productid': u'Philips-LWB010-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:86:2a:7c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Philips', u'swconfigid': u'564ABA6B', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'2': {u'swversion': u'5.127.1.26420', u'name': u'Papierlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-28T18:36:16'}, u'uniqueid': u'00:17:88:01:02:30:83:9b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'4': {u'swversion': u'2.0', u'name': u'Bettlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-01-25T16:47:48'}, u'uniqueid': u'00:15:8d:00:02:0a:f5:3c-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.7, 0.3], [0.11, 0.82], [0.12, 0.08]], u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 370, u'sat': 204}, u'manufacturername': u'innr', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'RB 185 C'}}
   Hue Lights Debug                Starting parseAllHueLightsData.
   Hue Lights Debug                parseAllHueLightsData: There are 4 lights on the Hue bridge and 3 Indigo devices controlling Hue devices.
   Hue Lights Debug                Starting updateGroupsList.
   Hue Lights Debug                Sending command to hub: http://192.168.100.105/api/7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq/groups
   Hue Lights Debug                Got response {u'1': {u'name': u'Wohnzimmer', u'lights': [u'1', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Flur', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'4': {u'name': u'Schlafzimmer', u'lights': [u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.4101], u'bri': 254, u'ct': 370, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}}
   Hue Lights Debug                Loaded groups list - {u'1': {u'name': u'Wohnzimmer', u'lights': [u'1', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Flur', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'4': {u'name': u'Schlafzimmer', u'lights': [u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.4101], u'bri': 254, u'ct': 370, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}}
   Hue Lights Debug                Starting parseAllHueGroupsData.
   Hue Lights Debug                Starting validatePrefsConfigUi.
   Hue Lights Debug                validatePrefsConfigUi: Values passed:
UiValuesDict : (dict)
     sep0 :  (string)
     sep00 :  (string)
     sep1 :  (string)
     sep2 :  (string)
     showDebugInfo : false (bool)
     title :  (string)
   Hue Lights Debug                validatePrefsConfigUi: Validating IP address "192.168.100.105".
   Hue Lights Debug                validatePrefsConfigUi: Verifying that a Hue hub exists at IP address "192.168.100.105".
   Hue Lights Debug                validatePrefsConfigUi: Accessing URL: http://192.168.100.105/description.xml
   Hue Lights Debug                validatePrefsConfigUi: Got response:
<?xml version="1.0" encoding="UTF-8" ?>
<root xmlns="urn:schemas-upnp-org:device-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<URLBase>http://192.168.100.105:80/</URLBase>
<device>
<deviceType>urn:schemas-upnp-org:device:Basic:1</deviceType>
<friendlyName>Philips hue (192.168.100.105)</friendlyName>
<manufacturer>Royal Philips Electronics</manufacturer>
<manufacturerURL>http://www.philips.com</manufacturerURL>
<modelDescription>Philips hue Personal Wireless Lighting</modelDescription>
<modelName>Philips hue bridge 2015</modelName>
<modelNumber>BSB002</modelNumber>
<modelURL>http://www.meethue.com</modelURL>
<serialNumber>001788404e5f</serialNumber>
<UDN>uuid:2f402f80-da50-11e1-9b23-001788404e5f</UDN>
<presentationURL>index.html</presentationURL>
<iconList>
<icon>
<mimetype>image/png</mimetype>
<height>48</height>
<width>48</width>
<depth>24</depth>
<url>hue_logo_0.png</url>
</icon>
</iconList>
</device>
</root>
   Hue Lights Debug                validatePrefsConfigUi: Verified that this is a Hue hub.
   Hue Lights Debug                closedPrefsConfigUi: Starting closedPrefsConfigUi.
   Hue Lights Debug                closedPrefsConfigUi: pluginPrefs contains 30 presets.
   Hue Lights                      Debug logging disabled
Yassi
nsheldon
Post by nsheldon »
Version 1.6.28 Posted
  • Added support for the Innr RB-185C color and color temperature light.
  • Fixed a bug with the Hue Motion Sensor's Celsius temperature calculation that could cause constant "received ... sensor update" messages in the Indigo Event Log.
yassi
Post by yassi »
Nathan, thanks!
But I have an issue after installing the new version, plugin runs and quits (but strange, remains "on" in the menu)
Stopping plugin Hue Lights (pid 410)
   Stopped plugin Hue Lights
   Upgrading plugin Hue Lights to newer version 1.6.28 (previous version moved to trash)
   Loading plugin "Hue Lights 1.6.28"
   Starting plugin "Hue Lights 1.6.28" (pid 850)
   Hue Lights Error                Error in plugin execution InitializeMain:
IndentationError: ('unexpected indent', ('plugin.py', 6440, 3, '\t\t\telse:\n'))
   Stopping plugin "Hue Lights 1.6.28" (pid 850)
   Stopped plugin "Hue Lights 1.6.28"
Yassi
Bildschirmfoto 2019-01-28 um 08.08.15.png (35.3 KiB) Viewed 5568 times
nsheldon
Post by nsheldon »
Hi Yassi.
Sorry about that. I've fixed the plugin. Please re-download it. You'll need to manually replace the bad plugin with the fixed one. You can replace the broken plugin which will be in the main hard drive, in the Library folder -> Application Support folder -> Perceptive Automation folder -> Indigo 7.2 folder -> Plugins folder. Drag the new plugin file to that folder and replace the old one. Sorry for the trouble. Let me know if that fixes it.
yassi
Post by yassi »
Hi Nathan,
no problem at all, can happen.
Glad you can integrate so fast the new bulbs, thanks again for your work!
I the meantime I have re-installed the old plugin (.27), I will download it again and update it.
Yassi
UPDATE: works! :lol:
Bildschirmfoto 2019-01-28 um 09.37.29.png (79.66 KiB) Viewed 5551 times
nsheldon
Post by nsheldon »
Awesome! Glad that fixes it.
steinis
Post by steinis »
Hi Nathan
I was working on a deCONZ plugin for indigo when I so that the guys making the deCONZ hub are using the same format as the HUE API.
so I have a big question for you:)
Would it be an idea to integrate the deCONZ hub into the Hue plugin?
I have it running fine with your plugin now, only added the gateway name to the "dirty check";) (if "Philips hue bridge" not in r.content or "Phoscon-GW" not in r.content:)
So thats the easy part, the job is adding all the new devices supported by deCONZ(Not Hue).
I fully understand if this is to much, but since the gateways are so similar I needed to ask:)
If deCONZ dosent ring a bell its a Zigbee dongle you can run on Windows or a raspberry. Think of it as a Hue hub, but you have a lot more devices you can add. All the cheap sensor from Xiaomi for example. it also have a nice way do display and manage your zigbee-devices.
https://www.dresden-elektronik.de/funkt ... f81b62b2bd
Here is an example of the Xiaomi door sensor:
	"config": {
		"battery": 100,
		"on": true,
		"reachable": true,
		"temperature": 2400
	"ep": 1,
	"etag": "2b97bb1b1d827526e450678eb0a822d8",
	"manufacturername": "LUMI",
	"modelid": "lumi.sensor_magnet.aq2",
	"name": "entree_dor",
	"state": {
		"lastupdated": "2019-02-03T22:51:25",
		"open": false
	"swversion": "20161128",
	"type": "ZHAOpenClose",
	"uniqueid": "00:15:8d:00:02:72:35:b0-01-0006"
Busta999
Post by Busta999 »
First of all many thanks for this Plugin very much appreciated and used/relied upon heavily.
Enhancement Request
In config for Plugin - option to disable sensor readings writing to event log.
I have 10 Hue motion detectors in the house, and each reports temp, luminance, every couple of mins generating a lot of ‘chatter’ in the logs that only need to be there if debugging an issue.
The same could be said of the light bulbs reporting over a long dimming stint, 60+ Hue lights on slow fade, driven by motion detectors generates a lot of traffic, so could that be muted in the config too?
No rush, not an issue, just housekeeping.
nsheldon
Post by nsheldon »
Hi steinis.
Thanks for sharing the deCONZ information. I hadn't heard of that ZigBee hub before. That's actually quite nice that they're using such a similar API. It certainly makes writing applications and plugins to use it easier.
As you pointed out, modifying the Hue Lights plugin to work with the deCONZ hub appears to be somewhat trivial, but adding support for the large and expanding list of additional ZigBee devices might be where most of the work comes in.
I have no good way to test new code against a deCONZ hub or any associated devices, and the additional time required to handle end user support is probably more than I am able to provide. However, the Hue Lights plugin code and content is available on GitHub. So, one could either branch that repository to create a new deCONZ variant of the Hue Lights plugin, or just borrow any code in there to be included in a deCONZ plugin.
steinis wrote:Hi Nathan
nsheldon
Post by nsheldon »
Hi Busta999.
I'm glad the plugin has been so useful to you. And thanks for the suggestion.
I can't guarantee any new features, but adding some kind of ability to disable logging within each device's settings might be possible in a future update. Disabling just light status updates during a slow dimming cycle wouldn't be possible because there's no way for the plugin to tell the difference between a change in light status due to some external controller (Hue app, Hue Tap activation, etc) and a light status change as the result of an ongoing dimming cycle. That's because the Hue Lights plugin doesn't control the actual dimming process. It just tells the Hue bridge to start dimming a light or group and the bridge handles all the rest. Any light status changes are just the ones reported by the bridge itself whenever the Hue Lights plugin asks for an update.
Busta999 wrote:First of all many thanks for this Plugin very much appreciated and used/relied upon heavily.
Enhancement Request
Busta999
Post by Busta999 »
Ok
Understood, if we could optionally quiet down the motion, temp,luminance log reporting that would help de clutter things
If you look at a zwave motion detector/ multi sensors you can turn off individual sensor logging.
No important, no rush, just a thought :-)
Busta999
Post by Busta999 »
Can you please add new Hue device - Outdoor Motion Sensor
{u'operator': u'eq', u'value': u'true', u'address': u'/groups/23/state/any_on'}]}, u'79': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'XFDani[7][1]23498udsalkj', u'created': u'2017-01-05T18:15:34', u'actions': [{u'body': {u'status': u'enabled'}, u'method': u'PUT', u'address': u'/schedules/12'}, {u'body': {u'transitiontime': 100, u'xy': [0.4265, 0.3611], u'bri': 254}, u'method': u'PUT', u'address': u'/groups/7/action'}], u'recycle': False, u'owner': u'93GLtVxv1etzVkTHPvLvpNp4M18im0GyPtDmwuA2', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/47/state/status'}, {u'operator': u'eq', u'value': u'5', u'address': u'/sensors/48/state/status'}, {u'operator': u'dx', u'address': u'/sensors/48/state/lastupdated'}]}, u'78': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'XFDani[7][1]sdaklsdu435', u'created': u'2017-01-05T18:15:34', u'actions': [{u'body': {u'status': u'enabled'}, u'method': u'PUT', u'address': u'/schedules/11'}, {u'body': {u'transitiontime': 100, u'xy': [0.5415, 0.4001], u'bri': 203}, u'method': u'PUT', u'address': u'/groups/7/action'}], u'recycle': False, u'owner': u'93GLtVxv1etzVkTHPvLvpNp4M18im0GyPtDmwuA2', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/47/state/status'}, {u'operator': u'eq', u'value': u'4', u'address': u'/sensors/48/state/status'}, {u'operator': u'dx', u'address': u'/sensors/48/state/lastupdated'}]}}, u'resourcelinks': {u'30778': {u'classid': 10020, u'name': u'MotionSensor 15', u'links': [u'/sensors/15', u'/sensors/16', u'/sensors/17', u'/groups/18', u'/rules/2', u'/rules/3', u'/rules/4', u'/rules/9', u'/rules/10', u'/rules/11', u'/rules/12', u'/rules/13', u'/scenes/F3TMvRGpMd8B05u', u'/scenes/OPRQ8yg3GKOMfRE', u'/scenes/aiKM8ARqlZaJABK'], u'recycle': False, u'owner': u'c36MmlgQdW4MNnx3PIY7W3FbQqN4kuHcqafLRxC0', u'type': u'Link', u'description': u'MotionSensor 15 behavior'}, u'30493': {u'classid': 1, u'name': u'HueLabs 2.0', u'links': [u'/resourcelinks/41325', u'/resourcelinks/51949', u'/resourcelinks/58432', u'/resourcelinks/56895'], u'recycle': False, u'owner': u'0yCQfTevxv4-cgtcdK4X3fUpbJkzZsPbZ3ZyH2Wk', u'type': u'Link', u'description': u'All installed formulas'}, u'51949': {u'classid': 2, u'name': u"Valentine's living scenes", u'links': [u'/groups/21', u'/sensors/62', u'/scenes/GN9Gn9tLHdE835X', u'/scenes/iHB8x5CgrzGM-a2', u'/scenes/mG5m7VDMZGYwvWr', u'/scenes/QWcdu81S4TBPNYx', u'/rules/125', u'/rules/126', u'/rules/127', u'/rules/128', u'/rules/130', u'/rules/131'], u'recycle': True, u'owner': u'P9W4vUnt8-ub5do5QLWtQ31NT-UNE1yiH-nGFlV0', u'type': u'Link', u'description': u'096d46ed7e9627e509f93249e29333c2:0:0e09d764b68169f7f2a8dab61b19'}, u'48018': {u'classid': 10010, u'name': u'MotionSensor 36', u'links': [u'/sensors/38'], u'recycle': False, u'owner': u'93GLtVxv1etzVkTHPvLvpNp4M18im0GyPtDmwuA2', u'type': u'Link', u'description': u'MotionSensor 36 behavior'}, u'40670': {u'classid': 10020, u'name': u'MotionSensor 32', u'links': [u'/sensors/32', u'/sensors/33', u'/sensors/34', u'/groups/4', u'/rules/31', u'/rules/32', u'/rules/33', u'/rules/34', u'/rules/35', u'/rules/36', u'/rules/37', u'/rules/38', u'/scenes/CEgwZVICl6sl42H', u'/scenes/KhLvHf-QBfAF6IP', u'/scenes/nJdj4JO2fK4aTiy'], u'recycle': False, u'owner': u'lAAienwLJSMjA6XY7TtonMZdXfBm2IzAKy0S-8lF', u'type': u'Link', u'description': u'MotionSensor 32 behavior'}, u'58497': {u'classid': 10022, u'name': u'Garage sensor', u'links': [u'/rules/100', u'/rules/85', u'/rules/84', u'/rules/83', u'/rules/72', u'/rules/71', u'/rules/70', u'/rules/69', u'/rules/68', u'/scenes/fWcXL8VnJyjWF-C', u'/rules/67', u'/rules/66', u'/sensors/66', u'/sensors/65', u'/scenes/xt7s-Pfo9c-7fDk', u'/groups/23', u'/sensors/67', u'/scenes/aHeFiNGTnkbtVvU'], u'recycle': False, u'owner': u'0yCQfTevxv4-cgtcdK4X3fUpbJkzZsPbZ3ZyH2Wk', u'type': u'Link', u'description': u'Garage sensor behavior'}, u'56895': {u'classid': 2, u'name': u'Christmas living scenes', u'links': [u'/groups/19', u'/sensors/23', u'/scenes/dXNO4bznPt9hVWA', u'/scenes/Kz4dTuyjjPIAIbU', u'/scenes/e8x21NuWresZu0r', u'/scenes/IyOyxM0qSfNMq5p', u'/scenes/MNsX2ebfKjQc3GP', u'/scenes/UiUQRFsBBmTPVsh', u'/rules/86', u'/sensors/53', u'/rules/87', u'/rules/88', u'/rules/89', u'/rules/90', u'/rules/91', u'/rules/92', u'/rules/93', u'/rules/94'], u'recycle': True, u'owner': u'0yCQfTevxv4-cgtcdK4X3fUpbJkzZsPbZ3ZyH2Wk', u'type': u'Link', u'description': u'53e6535891f3f0827f6d554b83142b33:0:b908e0703c09cce9198db9f9aebb'}, u'26134': {u'classid': 10010, u'name': u'MotionSensor 32', u'links': [u'/sensors/32', u'/sensors/33', u'/sensors/34', u'/groups/4', u'/groups/12', u'/scenes/CEgwZVICl6sl42H', u'/scenes/KhLvHf-QBfAF6IP'], u'recycle': False, u'owner': u'ZtUOwcslyYt6pbsF7IWGGJc2ZHJKFlwqUuSt1cnd', u'type': u'Link', u'description': u'MotionSensor 32 behavior'}, u'21405': {u'classid': 10020, u'name': u'MotionSensor 64', u'links': [u'/sensors/4', u'/groups/11', u'/scenes/1LpfhmqskyOOKl2', u'/scenes/ElTueU5g06h9mxY', u'/scenes/sC4kmXB2H1gfN0f'], u'recycle': False, u'owner': u'ZtUOwcslyYt6pbsF7IWGGJc2ZHJKFlwqUuSt1cnd', u'type': u'Link', u'description': u'MotionSensor 64 behavior'}, u'20219': {u'classid': 10020, u'name': u'MotionSensor 64', u'links': [u'/sensors/4', u'/groups/11', u'/scenes/1LpfhmqskyOOKl2', u'/scenes/ElTueU5g06h9mxY', u'/scenes/sC4kmXB2H1gfN0f'], u'recycle': False, u'owner': u'ZtUOwcslyYt6pbsF7IWGGJc2ZHJKFlwqUuSt1cnd', u'type': u'Link', u'description': u'MotionSensor 64 behavior'}, u'53013': {u'classid': 10020, u'name': u'MotionSensor 22', u'links': [u'/sensors/22', u'/sensors/35', u'/sensors/36', u'/groups/14', u'/rules/44', u'/rules/45', u'/rules/46', u'/rules/47', u'/rules/48', u'/rules/49', u'/rules/50', u'/rules/51', u'/scenes/FHYDM3dTmFeEmmq', u'/scenes/WDQvvz8r806rOMK', u'/scenes/YVch5mBA-fm6WIY'], u'recycle': False, u'owner': u'0yCQfTevxv4-cgtcdK4X3fUpbJkzZsPbZ3ZyH2Wk', u'type': u'Link', u'description': u'MotionSensor 22 behavior'}, u'61414': {u'classid': 10020, u'name': u'MotionSensor 9', u'links': [u'/sensors/9', u'/sensors/11', u'/sensors/12', u'/groups/11', u'/rules/74', u'/rules/75', u'/rules/103', u'/rules/106', u'/rules/107', u'/rules/108', u'/rules/109', u'/rules/110', u'/scenes/ElTueU5g06h9mxY', u'/scenes/sC4kmXB2H1gfN0f'], u'recycle': False, u'owner': u'c36MmlgQdW4MNnx3PIY7W3FbQqN4kuHcqafLRxC0', u'type': u'Link', u'description': u'MotionSensor 9 behavior'}, u'423':
The new Outdoor Motion Sensor is called 'Garage sensor'
Hopefully it look and smells like a normal Hue Motion Sensor... Hopefully I got the right part of the log.
nsheldon
Post by nsheldon »
Hi again.
I can look into adding support for the outdoor version of the Hue motion sensor. It looks like you pasted in an excerpt of the resource links list from the Hue bridge, which isn’t the same list as the sensors list. But you can’t be blamed for missing it. The size of theJASON output from the Hue bridge, especially for people with lots of devices, is pretty huge. Try looking for a section in the response from the bridge that starts with “u’sensors’ : u’12’ : {“ the number could be anything. I just used 12 as an example. If you can’t find it, maybe zip the log and PM or email it to me.
Busta999
Post by Busta999 »
here?
 u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}, u'25': {u'name': u'Kitchen', u'lights': [u'28', u'29', u'31', u'32', u'53', u'54', u'57', u'58'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 34816, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.3127, 0.329], u'bri': 254, u'ct': 230, u'sat': 5}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'26': {u'name': u'Stairs', u'lights': [u'55', u'56'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.0, 0.0], u'bri': 0, u'ct': 0, u'sat': 0}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'20': {u'name': u'Entertainment area 1', u'stream': {u'proxymode': u'auto', u'active': False, u'proxynode': u'/lights/34', u'owner': None}, u'locations': {u'11': [-0.85, 0.91, 0.0], u'27': [-0.75, -0.91, 0.0], u'22': [-1.0, 0.99, 0.0], u'48': [-0.66, 0.88, 0.0], u'23': [0.57, -0.94, 0.0], u'46': [0.01, 0.8, 0.0], u'47': [0.79, 0.89, 0.0], u'34': [-0.54, 0.06, 0.0], u'33': [0.05, -0.38, 0.0]}, u'lights': [u'48', u'47', u'46', u'34', u'11', u'27', u'22', u'23', u'33'], u'state': {u'any_on': True, u'all_on': False}, u'action': {u'on': False, u'hue': 8597, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4452, 0.4068], u'bri': 204, u'ct': 343, u'sat': 121}, u'recycle': False, u'sensors': [], u'type': u'Entertainment', u'class': u'TV'}, u'21': {u'name': u'Custom group for $lights', u'lights': [u'1', u'4', u'5', u'6', u'7', u'11', u'19', u'26', u'27'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8597, u'colormode': u'xy', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4452, 0.4068], u'bri': 204, u'ct': 343, u'sat': 121}}, u'22': {u'name': u'Study', u'lights': [u'18', u'12', u'14', u'3'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 34076, u'colormode': u'xy', u'effect': u'none', u'alert': u'lselect', u'xy': [0.3144, 0.3301], u'bri': 126, u'ct': 153, u'sat': 251}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Office'}, u'23': {u'name': u'Garage', u'lights': [u'52'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none', u'colormode': u'ct', u'bri': 127, u'ct': 366}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Carport'}, u'1': {u'name': u'WC', u'lights': [u'49'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none', u'colormode': u'ct', u'bri': 126, u'ct': 343}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Toilet'}, u'3': {u'name': u'Master Bedroom', u'lights': [u'8', u'24'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 7676, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5016, 0.4151], u'bri': 1, u'ct': 443, u'sat': 199}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'2': {u'name': u'Lounge', u'lights': [u'11', u'27', u'33', u'34', u'46', u'47', u'48', u'22', u'5', u'7', u'4', u'23'], u'state': {u'any_on': True, u'all_on': False}, u'action': {u'on': False, u'hue': 8597, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4452, 0.4068], u'bri': 204, u'ct': 343, u'sat': 121}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'5': {u'name': u'Front Door', u'lights': [u'30'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 9374, u'colormode': u'xy', u'effect': u'none', u'alert': u'lselect', u'xy': [0.5005, 0.4517], u'bri': 128, u'ct': 443, u'sat': 254}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Front door'}, u'4': {u'name': u'Landing', u'lights': [u'38', u'39'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none', u'colormode': u'ct', u'bri': 126, u'ct': 230}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'7': {u'name': u'SML', u'lights': [u'11', u'34', u'27', u'7', u'33', u'46', u'47', u'48', u'22', u'5', u'4', u'23'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8597, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4452, 0.4068], u'bri': 204, u'ct': 343, u'sat': 121}}, u'9': {u'name': u'Closet', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'8': {u'name': u'Molly', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kids bedroom'}, u'11': {u'name': u'Master Ensuite', u'lights': [u'25', u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none', u'colormode': u'hs', u'bri': 126, u'ct': 366}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}, u'10': {u'name': u'Spare', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'13': {u'name': u'Utility', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'12': {u'name': u'Hallway', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'15': {u'name': u'Office', u'lights': [u'26', u'20', u'19', u'6'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 14957, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4576, 0.4099], u'bri': 254, u'ct': 366, u'sat': 141}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Office'}, u'14': {u'name': u'Dining Room', u'lights': [u'35'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Dining'}, u'17': {u'name': u'Backdoor', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'16': {u'name': u'Status', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'19': {u'name': u'Custom group for $lights', u'lights': [u'11', u'22', u'23', u'27', u'33', u'34', u'46', u'47', u'48'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': True, u'hue': 8597, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4452, 0.4068], u'bri': 164, u'ct': 343, u'sat': 121}}, u'18': {u'name': u'Bathroom', u'lights': [u'16'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 126, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}}, u'schedules': {u'11': {u'status': u'disabled', u'name': u'23498udsalkj_G7_1', u'autodelete': False, u'created': u'2017-01-05T18:15:33', u'command': {u'body': {u'status': 5}, u'method': u'PUT', u'address': u'/api/93GLtVxv1etzVkTHPvLvpNp4M18im0GyPtDmwuA2/sensors/48/state'}, u'starttime': u'2017-01-05T18:15:55', u'time': u'R01/PT00:00:10', u'recycle': False, u'description': u'XFDani[7][1]23498udsalkj'}, u'10': {u'status': u'disabled', u'name': u'sdaklsdu435_G7_1', u'autodelete': False, u'created': u'2017-01-05T18:15:33', u'command': {u'body': {u'status': 4}, u'method': u'PUT', u'address': u'/api/93GLtVxv1etzVkTHPvLvpNp4M18im0GyPtDmwuA2/sensors/48/state'}, u'starttime': u'2017-01-05T18:15:45', u'time': u'R01/PT00:00:10', u'recycle': False, u'description': u'XFDani[7][1]sdaklsdu435'}, u'13': {u'status': u'disabled', u'name': u'sdkljsdloiweu79832_G2_1', u'autodelete': False, u'created': u'2017-04-19T13:07:41', u'command': {u'body': {u'status': 2}, u'method': u'PUT', u'address': u'/api/93GLtVxv1etzVkTHPvLvpNp4M18im0GyPtDmwuA2/sensors/55/state'}, u'starttime': u'2017-04-19T13:08:22', u'time': u'PT00:00:10'
nsheldon
Re: Hue Lights discussion
Post by nsheldon »
Nope. That looks like an excerpt from the Groups list. I guess you can have sensors in groups now.
Locked
Return to “Archives”
