- Added support for the IKEA dimmable 980 lumen E27 color temperature bulb.
Hue Lights discussion
Re: Hue Lights discussion
Version 1.6.25 Posted
Thanks. Working great
Niko dimmer switch for hue system
Hy all,
I have been waiting for these since they were annnounced!
These are an abolute game changer as my wife was (out of habit) switching our hue lights of with the original switch. And that means the lights were powered off, so the lights were not responding...
Now I'm gonna change the switches with the new ones and my wife can still turn of the lights with the switch and there is space for other actions, etc... as there are four switches in one!
I finally got three and will mount them tonight at home!
These are for the European market as they fit a standard wall mounting box. They can also be glued with de included adhesive strips to any wall. No need in wiring your walls for switches anymore!!
There is also an American manufacturar for the American market, don't remeber the name tough.
Gilles
Gilles
- IMG_0421.jpg (170.97 KiB) Viewed 4162 times
- IMG_0420.jpg (155.22 KiB) Viewed 4162 times
- IMG_0419.jpg (151.31 KiB) Viewed 4162 times
Version 1.6.26 Posted
- Added support for another Hue Ambiance Ceiling light variant.
Hi Nathan
i was wondering if it would be possible to add another GLEDOPTO controller.
{u'swversion': u'1.0.7', u'name': u'gledopto', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-01-17T15:54:40'}, u'uniqueid': u'00:00:4b:00:1d:3a:aa:fc-0b', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Dimmable light', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'GLEDOPTO', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'GL-C-009'}}
Sure. I’ll get that one into the next patch update.
Version 1.6.27 Posted
- Added support for a GLEDOPTO dimmable LED controller.
Any one else seen a Hue Motion Detector start reporting temperature hundreds of times a minute ( actually about 10 times a minute)?
I have changed out the batteries, a reboot of sorts, and reset through Hue interface and set it up again nut it is still reporting temp like it is going out of fashion.
Anyone any ideas?
22 Jan 2019 at 09:07:28
Hue Lights received "Motion - Kitchen (Hue)" status update is on
Trigger Ensure Kitchen Top Lights Turn On Fully
Sent Hue Lights "Kitchen Top Left" on to 100 at ramp rate 1.0 sec.
Sent Hue Lights "Kitchen Top Right" on to 100 at ramp rate 1.0 sec.
Schedule Heating Period 2 - Day - Set Zone Current Temp
Schedule Turn On Heating Failover
Z-Wave sent "Heating System" on
Hue Lights received "Motion - Kitchen (Hue)" status update is off
Hue Lights received "Temp: WC (Hue)" sensor update to 16.9 ºC
Hue Lights received "Temp: Landing 2 (Hue)" sensor update to 18.3 ºC
Schedule Set Heating Demand to 1
Hue Lights received "Temp: Kitchen (Hue)" sensor update to 19.6 ºC
Trigger Fridge Temp Ok - Just right
Hue Lights received "Luminance - Kitchen (Hue)" sensor update to 184 lux
Hue Lights received "Luminance - Study (Hue)" sensor update to 21.6 lux
Hue Lights received "Luminance - Landing 2 (Hue)" sensor update to 75.7 lux
Hue Lights received "Luminance - Guest Ensuite (Hue)" sensor update to 29.1 lux
Hue Lights received "Luminance - WC (Hue)" sensor update to 7.16 lux
Z-Wave received "Kitchen Freezer Door Temp Sensor" sensor update to 21.68 °C
Hue Lights received "Luminance - Bathroom (Hue)" sensor update to 59.3 lux
Updated "Landing Group" on to 49
Updated "Landing Group" off
Hue Lights received "Luminance - Ensuite (Hue)" sensor update to 27.9 lux
Hue Lights received "Luminance - Landing 2 (Hue)" sensor update to 15.1 lux
Hue Lights received "Luminance - Guest Ensuite (Hue)" sensor update to 11.4 lux
Hue Lights received "Temp: Study (Hue)" sensor update to 20.6 ºC
Hue Lights received "Temp: Guest Ensuite (Hue)" sensor update to 16.7 ºC
Hue Lights received "Temp: WC (Hue)" sensor update to 17.1 ºC
Schedule Set Heating Demand to 1Anyone any ideas?
Hi there.
That's odd indeed. However, I don't think it's the motion sensor. The Hue Lights plugin simply asks the Hue bridge for a status update of each motion sensor. If the status reported back to the plugin is different from the last value stored for that motion sensor, the Hue Lights plugin reports a sensor update. Since it's reporting the exact same value each time, it looks like the plugin thinks it's a new temperature for some reason.
Maybe you could get some debug logs for me (enable debug logging by going to Plugins -> Hue Lights -> Toggle Debugging), then reload the plugin (Plugins -> Hue Lights -> Reload). After the plugin reloads, it'll spew a bunch of text. I'll need at least the first 20 seconds worth of text. Include the debug log in your reply. I'll try to figure out why it's not saving the temperature value.
What are you doing up!! All Californians should be asleep by now
I'll do that now and return to you.
I've run the Debug
I've emailed you a Dropbox link to the log file
I have taken the batteries out to the Hue Motion Detector for now - too noisy in the logs.
Hi.
Thanks. I got the notification from Dropbox. A Dropbox account is required to access the file. I don't have a Dropbox account (and don't want one really). If you could zip the file and just email it to me that'd be better. Compressing it will make it more manageable for email too.
Regards,
Nathan
Regards,
Nathan
Nathan, I'm not sure, but I think the Innr bulbs are not supported yet, right?
I finally bought one now (have 3 other Philips) - it's the RB 185C color bulb.
Was able to add it via the Hue App, but can't figure out how to add it as a device in Indigo.
Yassi
Yassi
Hi Yassi.
Yes, if they don’t appear in any of the model types when creating a new Hue Lights device then the bulb isn’t supported yet. I can add support though. The most reliable way is to enable debug logging by going to the Plugins menu then Hue Lights then Toggle Debugging. Then reload the plugin, copy the debug log info from the Event Log window end provide that in your reply. Be sure to tell me what you’ve named the bulb in you Hue app so I can find it in the debug logs.
