Web Content on Control Pages Alpha Test
- RogueProeliator
Re: Web Content on Control Pages Alpha Test
The beta channel has been updated with fixes to Notifications and Status Updates for Android O+ devices. The messaging was a huge hurdle to overcome and now that it is done, will be working on some of the improvements going into this release. Web content displays and RTSP streams hopefully are up next for improvement.
Adam
Adam
Working on my fire8
- 2018-12-13_05-11-44.jpeg (373.96 KiB) Viewed 7212 times
_______
Norm
Norm
I tried to view a Sense power meter web page - it requires a log-in UN/PW but that info does not come up on the screen - is that an artifact of the fire tablet or does the web display only work with sites that do not require a log in?
Can I pass the username / password within the sites URL?
_______
Norm
Norm
I need to start having a play with this!
- RogueProeliator
I assume it is popping up a login dialog as opposed to having a login form on the page? The url is passed along to the system web view, so I suppose you could try something along the lines of:Can I pass the username / password within the sites URL?
http://username:[email protected]/
Not sure if that would work or not... if not I would need to do some research to see if we could allow it to be input somewhere and utilized.
I will mess around with the log-in stuff and let you know - that page is actually not local - my power meter reports to the cloud and I log into my cloud account to look at various power graphs / reports. It is a big data thing....
I just tried it on weather underground. The today tab works - but no radar section fills in, the hourly tab works but the 10 day tab is blank - seems odd.
On thing that would be nice is if there could be a way to specify the offset from maybe the top left of the web page (if that is the 0x0 point - I would need to check). So the display would grab the correct portion of the web page for display. Just started messing with it but looks to be a very nice add to an already powerful tool!!!!!!
- 2018-12-13_05-45-29.jpeg (225.93 KiB) Viewed 7209 times
- 2018-12-13_05-43-54.jpeg (283.71 KiB) Viewed 7209 times
- 2018-12-13_05-46-12.jpeg (354.51 KiB) Viewed 7209 times
_______
Norm
Norm
- RogueProeliator
What URL are you using and what is the size of that web view / placeholder image? I'll try to duplicate. Off hand that looks either Javascript related or maybe serving files from a secondary domain and it is being blocked. If one of those is the case it may (hopefully) just be a case of finding a flag/feature to turn on for the view.I just tried it on weather underground. The today tab works - but no radar section fills in, the hourly tab works but the 10 day tab is blank - seems odd.
Adam
I sent you the url in a PM (for Weather underground) - the placeholder I'm using is (see below). BTW, passing the user name and password as part of the URL did not work for the power monitor site....
- 2018-12-13_06-41-56.jpeg (10.39 KiB) Viewed 7190 times
_______
Norm
Norm
Stop it all of you. I want to play but a pair of hungry twins are taking up all my free time!!
WU changed their layout and now everything is working - love this capability - wondering when it updates if it will stay on the same spot (on the web page)....
- 2018-12-15_05-05-15.jpeg (399.69 KiB) Viewed 7063 times
_______
Norm
Norm
Well, it looks like I somehow got a different URL (the one above)- it is perfect - I went to the normal one and it does not work - the URL that works is much longer - no idea why the new one works and the other (old) does not.
Xmas wish - Domopad adds a capability to snap the view on the device and save it off as a .png image every few min - that would basically allow indigo touch to have the same capability by invoking the refreshing URL on that image......
PS. I know snapping a picture of a web page may not be that easy unless you can force an organic screen shot and access the image somehow....
_______
Norm
Norm
Anyuser-updates on this? Control Pages? Customizations?
I've only done one trial, as a larger home role-out is a big deal with potential WAF complications. In my case, Dark Sky showed in a webpage on Domopad without problem.
Now- I just need to ensure my own UI/UX snafu's are minimal, then I'll be using this feature in every room of my house.
