Powermiser Plugin
Colorado4Wheeler
Re: Powermiser Plugin
Post by Colorado4Wheeler »
Ok, I put up a pre-release on Github (click this link). See if this addresses the issue(s).
KSimmons
Post by KSimmons »
Yes! That fixed the issue. The "Devices" field is now populated again.
Thank you.
– Kevin
dnomode
Post by dnomode »
It also works for me. Thanks :D
Edmond
dnomode
Post by dnomode »
I should have written that the devices show up. I don't think its working correctly, unless Im missing something. Devices are not turning off after the 5 minutes I gave.
KSimmons
Post by KSimmons »
I did a functional check this morning, and the plug-in seems to be working correctly on my system.
– Kevin
dnomode
Post by dnomode »
Thanks for the feed back, Kevin.
I uninstalled the plugin and reinstalled and everything works great.
Colorado4Wheeler, thanks for the fix
Edmond
dnomode
Post by dnomode »
Hello
This morning I discovered Powermiser trying to control a z-wave motion detector and Its been on an endless loop since 8:41 on 10-11-2018.
Please see below code:
2018-10-11 08:18:43.955	Application	v0.8.8 of plugin FindFriendsMini is already installed and enabled
2018-10-11 08:19:04.511	Application	Installing and enabling plugin EPS - Powermiser v2.2.1
2018-10-11 08:19:04.584	Application	Loading plugin "EPS - Powermiser 2.2.1"
2018-10-11 08:19:04.587	Application	Starting plugin "EPS - Powermiser 2.2.1" (pid 1167)
2018-10-11 08:19:06.605	Application	Started plugin "EPS - Powermiser 2.2.1"
2018-10-11 08:19:09.894	EPS - Powermiser	Debug logging disabled
2018-10-11 08:19:10.286	EPS - Powermiser	EPS - Powermiser is loaded and ready to use
2018-10-11 08:19:17.151	Z-Wave	received "003 - Notification Sensor" status update battery level 100%
2018-10-11 08:20:24.222	Received INSTEON	"Upstairs Hallway Closet" on
2018-10-11 08:20:24.240	EPS - Powermiser	Conditions passed on 'AutoOff Upstairs Hallway Closet'
2018-10-11 08:20:24.241	EPS - Powermiser	Upstairs Hallway Closet will turn off automatically at 2018-10-11 08:25:24
2018-10-11 08:25:25.913	EPS - Powermiser	Turning off device Upstairs Hallway Closet
2018-10-11 08:25:26.122	Sent INSTEON	"Upstairs Hallway Closet" off
2018-10-11 08:41:28.483	Trigger	Are we home check
2018-10-11 08:41:37.604	Trigger	Are we home check
2018-10-11 08:41:44.120	EPS - Powermiser	Conditions passed on 'AutoOff Upstairs Hallway Closet'
2018-10-11 08:41:44.121	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:46:44
2018-10-11 08:41:44.134	EPS - Powermiser	Conditions passed on 'AutoOff Class Room Closet '
2018-10-11 08:41:44.135	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:46:44
2018-10-11 08:41:44.148	EPS - Powermiser	Conditions passed on 'AutoOff Kids Room Closet'
2018-10-11 08:41:44.149	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:46:44
2018-10-11 08:41:44.163	EPS - Powermiser	Conditions passed on 'AutoOff Master Closet'
2018-10-11 08:41:44.164	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:46:44
2018-10-11 08:41:44.178	EPS - Powermiser	Conditions passed on 'AutoOff Master Bath Closet'
2018-10-11 08:41:44.180	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:46:44
2018-10-11 08:41:44.365	Z-Wave	received "002 - Notification Sensor" status update battery level 100%
2018-10-11 08:41:45.436	EPS - Powermiser	Conditions passed on 'AutoOff Upstairs Hallway Closet'
2018-10-11 08:41:45.437	EPS - Powermiser	Extending 002 - Notification Sensor time on by 5 minutes
2018-10-11 08:41:45.438	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:51:44
2018-10-11 08:41:45.446	EPS - Powermiser	Conditions passed on 'AutoOff Class Room Closet '
2018-10-11 08:41:45.446	EPS - Powermiser	Extending 002 - Notification Sensor time on by 5 minutes
2018-10-11 08:41:45.447	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:51:44
2018-10-11 08:41:45.454	EPS - Powermiser	Conditions passed on 'AutoOff Kids Room Closet'
2018-10-11 08:41:45.455	EPS - Powermiser	Extending 002 - Notification Sensor time on by 5 minutes
2018-10-11 08:41:45.456	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:51:44
2018-10-11 08:41:45.463	EPS - Powermiser	Conditions passed on 'AutoOff Master Closet'
2018-10-11 08:41:45.464	EPS - Powermiser	Extending 002 - Notification Sensor time on by 5 minutes
2018-10-11 08:41:45.465	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:51:44
2018-10-11 08:41:45.472	EPS - Powermiser	Conditions passed on 'AutoOff Master Bath Closet'
2018-10-11 08:41:45.472	EPS - Powermiser	Extending 002 - Notification Sensor time on by 5 minutes
2018-10-11 08:41:45.473	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:51:44
2018-10-11 08:41:45.483	EPS - Powermiser	Conditions passed on 'AutoOff Upstairs Hallway Closet'
2018-10-11 08:41:45.483	EPS - Powermiser	Extending 002 - Notification Sensor time on by 5 minutes
2018-10-11 08:41:45.484	EPS - Powermiser		002 - Notification Sensor maximum repeats reached, cancelling auto off
2018-10-11 08:41:45.492	EPS - Powermiser	Conditions passed on 'AutoOff Class Room Closet '
2018-10-11 08:41:45.492	EPS - Powermiser	Extending 002 - Notification Sensor time on by 5 minutes
2018-10-11 08:41:45.493	EPS - Powermiser		002 - Notification Sensor maximum repeats reached, cancelling auto off
2018-10-11 08:41:45.500	EPS - Powermiser	Conditions passed on 'AutoOff Kids Room Closet'
2018-10-11 08:41:45.501	EPS - Powermiser	Extending 002 - Notification Sensor time on by 5 minutes
2018-10-11 08:41:45.501	EPS - Powermiser		002 - Notification Sensor maximum repeats reached, cancelling auto off
2018-10-11 08:41:45.509	EPS - Powermiser	Conditions passed on 'AutoOff Master Closet'
2018-10-11 08:41:45.509	EPS - Powermiser	Extending 002 - Notification Sensor time on by 5 minutes
2018-10-11 08:41:45.510	EPS - Powermiser		002 - Notification Sensor maximum repeats reached, cancelling auto off
2018-10-11 08:41:45.518	EPS - Powermiser	Conditions passed on 'AutoOff Master Bath Closet'
2018-10-11 08:41:45.519	EPS - Powermiser	Extending 002 - Notification Sensor time on by 5 minutes
2018-10-11 08:41:45.519	EPS - Powermiser		002 - Notification Sensor maximum repeats reached, cancelling auto off
2018-10-11 08:41:45.529	EPS - Powermiser	Conditions passed on 'AutoOff Upstairs Hallway Closet'
2018-10-11 08:41:45.531	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:46:45
2018-10-11 08:41:45.538	EPS - Powermiser	Conditions passed on 'AutoOff Class Room Closet '
2018-10-11 08:41:45.539	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:46:45
2018-10-11 08:41:45.546	EPS - Powermiser	Conditions passed on 'AutoOff Kids Room Closet'
2018-10-11 08:41:45.547	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:46:45
2018-10-11 08:41:45.554	EPS - Powermiser	Conditions passed on 'AutoOff Master Closet'
2018-10-11 08:41:45.555	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:46:45
2018-10-11 08:41:45.563	EPS - Powermiser	Conditions passed on 'AutoOff Master Bath Closet'
2018-10-11 08:41:45.564	EPS - Powermiser	002 - Notification Sensor will turn off automatically at 2018-10-11 08:46:45
2018-10-11 08:46:46.053	EPS - Powermiser	Turning off device 002 - Notification Sensor
2018-10-11 08:46:46.060	EPS - Powermiser	Turning off device 002 - Notification Sensor
2018-10-11 08:46:46.067	EPS - Powermiser	Turning off device 002 - Notification Sensor
2018-10-11 08:46:46.073	EPS - Powermiser	Turning off device 002 - Notification Sensor
2018-10-11 08:46:46.079	EPS - Powermiser	Turning off device 002 - Notification Sensor
2018-10-11 08:46:46.096	Z-Wave	updated "002 - Notification Sensor" to off
2018-10-11 08:46:46.097	Z-Wave	updated "002 - Notification Sensor" to off
2018-10-11 08:46:46.101	Z-Wave	updated "002 - Notification Sensor" to off
2018-10-11 08:46:46.102	Z-Wave	updated "002 - Notification Sensor" to off
2018-10-11 08:46:46.103	Z-Wave	updated "002 - Notification Sensor" to off
2018-10-11 08:46:47.093	EPS - Powermiser	Turning off device 002 - Notification Sensor
2018-10-11 08:46:47.100	Z-Wave	updated "002 - Notification Sensor" to off
2018-10-11 08:46:47.102	EPS - Powermiser	Turning off device 002 - Notification Sensor
2018-10-11 08:46:47.108	Z-Wave	updated "002 - Notification Sensor" to off
2018-10-11 08:46:47.110	EPS - Powermiser	Turning off device 002 - Notification Sensor
2018-10-11 08:46:47.116	Z-Wave	updated "002 - Notification Sensor" to off
2018-10-11 08:46:47.118	EPS - Powermiser	Turning off device 002 - Notification Sensor
2018-10-11 08:46:47.124	Z-Wave	updated "002 - Notification Sensor" to off
2018-10-11 08:46:47.126	EPS - Powermiser	Turning off device 002 - Notification Sensor
2018-10-11 08:46:47.128	Z-Wave	updated "002 - Notification Sensor" to off
2018-10-11 08:46:48.145	EPS - Powermiser	Turning off device 002 - Notification Sensor
2018-10-11 08:46:48.152	Z-Wave	updated "002 - Notification Sensor" to off
Screenshot 2018-10-13 08.10.46.png (132.66 KiB) Viewed 6568 times
I thought I selected the wrong device in the device settings, however as you can see the 002 - Notification Sensor is not selected.
Screenshot 2018-10-13 08.28.35.png (135.53 KiB) Viewed 6568 times
Disabling the plugin and re-enabling it does not fix the problem. It just starts trying to turn off the Sensor.
   Enabling plugin "EPS - Powermiser 2.2.1"
   Starting plugin "EPS - Powermiser 2.2.1" (pid 54735)
Any Ideas?
Edmond
Colorado4Wheeler
I'm not sure why it would do that, I've never had a loop like that. I'm wondering if there is NOTHING selected there and it is defaulting to that sensor because it's the first device. Try selecting a switch or something on the list to see if that fixes it. Maybe the Class Room Fan Light?
dnomode
Post by dnomode »
I changed the motion sensor name so its the last item on the list and it still goes after the sensor. I also tried to rename to something completely different with no spaces and it still has the same problem. Any other ideas?
Oct 13, 2018, 10:30:07 AM
   Starting plugin "EPS - Powermiser 2.2.1" (pid 75069)
   EPS - Powermiser                Turning off device Z-002 - Notification Sensor
   Z-Wave                          updated "Z-002 - Notification Sensor" to off
Screenshot 2018-10-13 10.32.14.png (134.94 KiB) Viewed 6555 times
   EPS - Powermiser                Turning off device 002-NotificationSensor
   Z-Wave                          updated "002-NotificationSensor" to off
   EPS - Powermiser                Turning off device MotionSensor
   Z-Wave                          updated "MotionSensor" to off
Colorado4Wheeler
Are you sure it isn't one of the other Powermiser devices you have? It looks like you have at least 5 of them. I don't think it is the release because I have a dozen of these running without this issue.
dnomode
Post by dnomode »
I checked all of the power miser devices and each one has something selected other then the motion sensor. I start deleting one at a time and I'll let you know what I find.
dnomode
Post by dnomode »
So, I deleted one device at a time. Once I deleted the last device the looping stopped. I have recreated the devices and so far no looping.
dnomode
Post by dnomode »
It started again. Not sure if these errors helps:
   EPS - Powermiser Error          Error in plugin execution ServerRemovedElem:
  File "plugin.py", line 302, in variableDeleted
RuntimeError: maximum recursion depth exceeded
  File "plugin.py", line 302, in variableDeleted  File "plugin.py", line 302, in variableDeleted
   EPS - Powermiser                Turning off device 002-MotionSensor
   Z-Wave                          updated "002-MotionSensor" to off
   fingscan                        FING initializing
   uniFiAP                         ..starting threads for 2 APs 4 sec apart (MSG-log and db-DICT)
   START                           launching APtail  192.168.2.10
   START                           launching APdict  192.168.2.10
Any Ides?
Edmond
Colorado4Wheeler
It looks like you are doing something odd somewhere. That method is only called if a variable is deleted and if a variable is constantly being deleted and added and deleted then that would explain the odd behavior. The code quite literally does nothing in the plugin, so the fact that we get infinite recursions on that line 302 means that Indigo is calling up the method - which only would happen if a variable got deleted.
It's also curious that it started up on its own after initially being fine. This is pointing to some other action or schedule or trigger that is actually causing this entire problem. I would right click on that motion sensor, find all dependencies and see if you can find a schedule or trigger that might be firing.
Note that we are never seeing an ON command, so we aren't turning something off as a result of a Powermiser device, it is a reaction from Powermiser because something else is happening in Indigo and it is reporting it. It's odd that it is reporting it because those messages should be debug messages, what log level for Powermiser do you have set? Part of what PM is doing is listening for ALL traffic in your home automation and running routines to determine if that traffic impacts a PM device, so that motion sensor going on and off all the time (or if you have some action or trigger that turns it off constantly) would register with PM as an event to examine and according to the logs you posted it's not doing anything with it, just registering the changes.
If I were to guess I would say you have some routine that is creating and removing variables regularly and another that is turning off your motion sensor.
dnomode
Post by dnomode »
I recently moved, so this is a new system that I'm working on and everything is still pretty simple. I don't have many triggers and variables yet. I checked the dependencies and the motion has none.
Screenshot 2018-10-14 07.41.13.png (90.81 KiB) Viewed 6499 times
I also notices that pushing the Send Status Request button extends the time by 5 minutes.
   Z-Wave Error                    send "002-MotionSensor" status request failed
   EPS - Powermiser                Conditions passed on 'ClassRoomClosetAutoOff'
   EPS - Powermiser                Extending 002-MotionSensor time on by 5 minutes
   EPS - Powermiser                002-MotionSensor will turn off automatically at 2018-10-14 08:11:47
   EPS - Powermiser                Conditions passed on 'KidsRoomClosetAutoOff'
   EPS - Powermiser                Conditions passed on 'MasterBathClosetAutoOff'
   EPS - Powermiser                	002-MotionSensor maximum repeats reached, cancelling auto off
I also deleted the motion sensor from my system and it looks like Powermiser thinks its a referencing device:
 Reloading plugin "EPS - Powermiser 2.2.1"
   Stopping plugin "EPS - Powermiser 2.2.1" (pid 76753)
   Stopped plugin "EPS - Powermiser 2.2.1"
   Starting plugin "EPS - Powermiser 2.2.1" (pid 78994)
   EPS - Powermiser Error          Device 'ClassRoomClosetAutoOff' is referencing device ID 76115794 but that device is no longer an Indigo device.  Please change the device reference or remove 'ClassRoomClosetAutoOff' to prevent this error
   EPS - Powermiser Error          Device 'KidsRoomClosetAutoOff' is referencing device ID 76115794 but that device is no longer an Indigo device.  Please change the device reference or remove 'KidsRoomClosetAutoOff' to prevent this error
   EPS - Powermiser Error          Device 'MasterBathClosetAutoOff' is referencing device ID 76115794 but that device is no longer an Indigo device.  Please change the device reference or remove 'MasterBathClosetAutoOff' to prevent this error
   EPS - Powermiser Error          Exception in plugin.onAfter_runConcurrentThread line 129: 'key id 76115794 not found in database'
							 CODE: self.logger.info("Turning off device %s" % indigo.devices[int(devId)].name)
I have logging set to Info
You have any other ideas I should try?
