I wonder if you can help. I have two amazon fire 7's, with the same settings on each, each paired as separate devices, each with different pairing keys,, however only one is allowing me to push control pages.
First is working.
Second is not receiving notifications.
I think the problem is no notifications being received by the not working, second fire 7. There are no notifications in the second fire notification tab, whereas the first I can see a list of page requests.
Both have the "Allow control page requests to "at any time".
Neither fire's have notifications blocked in the android settings.
Both can show control pages through normal operation and everything else appears to be working.
Here are the log device details for each:
Working fire
Domotics Pad Mobile Client Dumping details for DeviceID: 161908139
Domotics Pad Mobile Client address :
batteryLevel : 0
buttonGroupCount : 0
configured : True
description :
deviceTypeId : domoPadAndroidClient
displayStateId : isPaired
displayStateImageSel : SensorOn
displayStateValRaw : True
displayStateValUi : Paired
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 1449619012
com.duncanware.domoPadMobileClient : (dict)
SupportsBatteryLevel : true (bool)
address : (string)
deviceRegistrationId : 2tkVXVxhyW1CVxTeUB12 (string)
lastChanged : 2018-08-26 19:14:04
lastSuccessfulComm : 2018-08-26 19:14:04
model : Android Remote Client
name : Domo Cinema 1
ownerProps : com.duncanware.domoPadMobileClient : (dict)
address : (string)
pluginId : com.duncanware.domoPadMobileClient
pluginProps : com.duncanware.domoPadMobileClient : (dict)
address : (string)
protocol : Plugin
remoteDisplay : True
states : States : (dict)
batteryLevel : 0 (integer)
batteryStatus : (string)
isPaired : true (bool)
isPaired.ui : Paired (string)
latitude : (string)
locationFixTime : (string)
longitude : (string)
modelName : (string)
subModel :
supportsAllOff : False
supportsStatusRequest : False
version : None
Domotics Pad Mobile Client Dumping details for DeviceID: 1689403653
batteryLevel : 0
configured : True
description :
enabled : True
errorState :
address : (string)
deviceRegistrationId : zw8YGr171TrYTUsdWkT3 (string)
lastChanged : 2018-08-27 14:57:33
lastSuccessfulComm : 2018-08-27 14:57:33
name : Domo Front row
address : (string)
address : (string)
protocol : Plugin
latitude : (string)
subModel :
version : None
Tried a reboot on both devices.
Debug log shows the following
Deleted app on the second fire, along with the device/schedule - reinstalled app, recreated the device and added a new schedule - verbos logging as follows (and above device dump updated):
Schedule Domo cinema 1
Schedule Domo cinema 2
Domotics Pad Mobile Client DebugControl page display notification sent successfully
Domotics Pad Mobile Client Threaddebug Queuing control page display request notification command for 161908139
Domotics Pad Mobile Client Threaddebug Queuing control page display request notification command for 1689403653
Domotics Pad Mobile Client Threaddebug Plugin Command queue has 2 command(s) waiting
Domotics Pad Mobile Client Threaddebug Control Page Display Notification Send Command: DevicePairID=2tkVXVxhyW1CVxTeUB12; Page=417439771
Domotics Pad Mobile Client Threaddebug Push Notification Payload=pageName=Cinema+Intergrated+control&pageRequested=417439771&devicePairingId=2tkVXVxhyW1CVxTeUB12
Domotics Pad Mobile Client Threaddebug Control page display notification response: [204]
Domotics Pad Mobile Client Threaddebug Plugin Command queue has 1 command(s) waiting
Domotics Pad Mobile Client Threaddebug Control Page Display Notification Send Command: DevicePairID=zw8YGr171TrYTUsdWkT3; Page=417439771
Domotics Pad Mobile Client Threaddebug Push Notification Payload=pageName=Cinema+Intergrated+control&pageRequested=417439771&devicePairingId=zw8YGr171TrYTUsdWkT3
Loving these cheap tablets and thanks for the hard work in allowing their use!
Cheers
Mat
Edited to update of further testing...
