Did not “touch” the plugin hence it has an old date. But the version sounds correct.
Next 3 days: setting up IKEA furniture in Frankfurt.
kw123 wrote:Did not “touch” the plugin hence it has an old date. But the version sounds correct.
Enjoy!
Hi Karl
The linked version doesn’t seem to add max/min/last update to ads1x15 sensor.
?correct download - hard to tell with version....
Enjoy your assembly...
Glenn
Glenn
1/3 done.. left to go:
- Screen Shot 2018-08-28 at 9.50.14 AM.png (1.43 MiB) Viewed 3637 times
kw123 wrote:1/3 done.. left to go:
who ever invented the electric screw driver should get the peace Nobel price. 30 years ago I did everything manually.. now with electric screw driver .. no blisters, can still use my arms
Have tracked down the issue - was using the ADS1x15 -4 channel device; changed to the one channel for the moment and max/min/last sensor Update there.GlennNZ wrote:Thanks Karlkw123 wrote:test version w min/Max, lastchanged sensor for ADC 1115
https://www.dropbox.com/s/a7s6bc3rd6lc7 ... n.zip?dl=1
Is the download link correct? - links to version 7.85.220 version last modified 3rd June?
Glenn
Glenn
Glenn
The formatting etc only works for one channel per device.
The idea is that you have 4 indigo devices one for each pin
Ok. Thanks.kw123 wrote:Glenn
Small issue is that some of the today/yesterday max/min uses unchanged Input_0 and some seem to use status (which has had calculation performed). I would prefer max/min of status calculated result.
See below:
(Result varies from 126 to 134 via status and 750 or so as raw result)
eg. INPUT0_MaxToday - using the raw result with rest using the status calculated result
Would prefer Max/min of status result
But happy traveling...
Glenn
It tries to use the status field
Will fall back to input-0
If there are units or non numbers ie space in the status field it will take the input field.
Glenn
posted a formal release on plugin store and GitHub with support for min/max today/yesterday for analog sensors
also added some more logic for determining the decimal points. It will use the status display, strip all non numbers and use that format
eg "value = 10.34 [mV] " will be 10.34 in the min/max states
The temporary version was build on an older version- my screw up.
The new version 7.91. 230 should be in sync
Thanks Karl,kw123 wrote:Glenn
Running now all looks good.
Glenn
On another note:
How do I reset these incorrect 192.168.1.181 multiple entries that have appeared?
Pi-11 is correct
0 and 1 appear incorrect- and should be empty I believe...
As I am getting this occasional message
Glenn
Pi-11 is correct
RPI# 0 check , too many empty messages in a row: 2Glenn
Have never tried the system w/o RPI-0. Need to check.
have you tried "Enable this rPi:" ==> off
That "should" do it.
Thanks - selected rpi 1.kw123 wrote:Have never tried the system w/o RPI-0. Need to check.
Confirm.
Enabled - off.
Unfortunately tells me:
IP address already in use.
But then does delete from list - so seems to be all good.
Glenn
