Somfy/RTS control
koburg
Re: Somfy/RTS control
Post by koburg »
this is from the rfplayer log
ZIA44 FRAME: frameType: 0, cluster: 0, dataFlag: 0,
rfLevel: -56dBm, floorNoise: -94dBm, rfQuality: 9
protocol: 9 (RTS), infoType: 3, frequency: 433920Khz
subType: 0 (Shutter), id: 3191872, qualifier: 4 ( My)
koburg
Post by koburg »
tried also with qualifier 4 same error
RFPlayer Debug                  sendCommandAction command 'My rts ID 3191872 qualifier 0' to RF USB
   RFPlayer Debug                  json decode failure:
ZIA--
error request number=0
Syntax error: My rts ID 3191872 qualifier 0
koburg wrote:tried also with qualifier 4 same error
ZIA--
Wait. Are you trying to do that with the "send text command" action? Don't do that. There's a specific device action for the "My" command.
Screen Shot 2018-08-16 at 11.37.51 AM.png (531.76 KiB) Viewed 4795 times
koburg
Post by koburg »
yes I did that but it is sending an off command
not MY command so the blind just go all the way down
koburg wrote:yes I did that but it is sending an off command
The correct command is either "on rts ID 3191872 qualifier 4" or "off rts ID 3191872 qualifier 4". It's not clear from the docs. The "qualifier 4" is what triggers the "my" action.
Please try both of those, with logging on, and post here.
Return to “RFPlayer”
