Support For Fibro RGBWW controller
mrmatt68
Post by mrmatt68 »
I noticed there is a plugin for home bridge for fibaro HC2 but I did not see a plugin for the RGBWW controller itself and i was wondering if that was something you were planning to add? Or is it already possible to add via that plugin not actually having the HC2 system? here is a video i watched that peeked my interest..... https://youtu.be/w2HAEoorBcg I realize they must have a fibaro HC2 system but thought it may be possible to control the RGBWW controller directly via a plugin.
Matt
Colorado4Wheeler
Re: Support For Fibro RGBWW controller
Post by Colorado4Wheeler »
I moved this into the HKB forum since it seems to be more of a HKB question than a Device Extensions question.
I haven't specifically added support for the Fibaro RGBWW to HKB, but the plugin does generically support changing colors on some devices. Right now the methods to change colors varies greatly from plugin to plugin so they have to be supported independently. If there is enough demand for this one then I'm not opposed to supporting a plugin that supports this device, which is to say that someone will need to interface to this device type first and then I can update HKB to support it.
As for Device Extensions, it is planned to have a 'wrapper' to accomplish similar tasks and I'm not sure if that would get you there or not but it is on the roadmap - however it would still be a requirement that you can do everything you want to do in Indigo prior to either DE or HKB working with it.
mrmatt68
Post by mrmatt68 »
Yes I can add the individual lights the HKB and then control each one independently but cannot control it like in the video through the home app or like in the Indigo server which also has the color popup that allow a color to be selected and changes immediately. I am not sure what you mean be interface to this device. I can send log or configuration files if needed. I have not specifically installed any kind of plugin for the controller in indigo or HKB and that is one question i was trying to figure out. I like the preconfigured scenes in this controller but could change to a more user friendly controller if there is something easier to change colors through the homekit app. I can set scenes to different colors and that works but really makes a mess on the interface. The screen in the video looked really handy and simple but i expect it's very complicated to program.
Colorado4Wheeler
Just to clarify, does Indigo fully support changing colors on those bulbs? If so then I can likely add support; I hadn't added support up to this point because everyone was using a Lutron or Hue and I had no base to test with.
mrmatt68
Post by mrmatt68 »
Yes Indigo creates 4 entries(under the devices tab) for the colors and 1 entry as the main and within indigo when i select the main switch or led there is a color swatch that i can open and choose a color and the lights change to that color. not on the iphone app though. I guess something is possible through a control page but i do not understand that yet and with HBK I hope i don't have to. I will take a few screenshots when i get home.
Colorado4Wheeler
HomeKit should show the ability to change colors if the Indigo device supports it. This doesn't mean that it works, but the palette should be there on the device in HomeKit. Is it? If it is then since I don't know how Indigo translates colors versus how I've done it with Hue lights then we could probably coordinate doing some device dumps and logs to see if it will easily pass through and then you would be golden.
mrmatt68
Post by mrmatt68 »
So far it only comes over as a dimmer but i did not bring all 5 devices over to HKB. I only added the Main dimmer if you will. basically I can set a color with the 4 sliders and then the 5th slider dims that color. So Maybe this isn't fully supported. I can send device dumps and logs if you can give me a basic description of the process.
Matt
Colorado4Wheeler
Lets start with a screenshot of the device itself, maybe that will help me understand the options we have since you mentioned there were multiple tabs (and thus multiple devices).
mrmatt68
Post by mrmatt68 »
Here is a couple shots with the settings dialog open....
Screen Shot 2018-07-13 at 4.15.16 PM.png (371.9 KiB) Viewed 6170 times
Screen Shot 2018-07-13 at 4.09.58 PM.png (433.77 KiB) Viewed 6170 times
Screen Shot 2018-07-13 at 4.10.36 PM.png (355.41 KiB) Viewed 6170 times
Colorado4Wheeler
Ok, now I'll need a dump of that main device so I can see its capabilities. Plugins Menu -> HomeKit Bridge -> Advanced Plugin Actions -> Select your server -> Simulate HomeKit For Server Item -> Select your device -> click Execute Action button beneath it. This will output to your log, just simply reply here with the code to /code data.
mrmatt68
Post by mrmatt68 »
	##### DEVICE DATA DUMP #####
	address : 23
	batteryLevel : None
	blueLevel : 69.14991736
	brightness : 0
	buttonGroupCount : 0
	configured : True
	defaultBrightness : 10
	description :
	deviceTypeId : zwColorDimmerType
	displayStateValRaw : 0
	displayStateValUi : 0
	enabled : True
	energyAccumBaseTime : 2015-03-25 11:29:59
	energyAccumTimeDelta : 104216856
	energyAccumTotal : 272.04
	energyCurLevel : 0.0
	errorState :
	folderId : 0
	     com.flyingdiver.indigoplugin.lifxbridge : (dict)
	          fakeMAC : 00:16:0f:06:17:f0 (string)
	          published : True (string)
	     com.perceptiveautomation.indigoplugin.zwave : (dict)
	          SupportsBatteryLevel : false (bool)
	          SupportsEnergyMeter : true (bool)
	          SupportsEnergyMeterCurPower : true (bool)
	          SupportsEnergyMeterReset : true (bool)
	          SupportsOnState : false (bool)
	          SupportsSensorValue : false (bool)
	          SupportsStatusRequest : true (bool)
	          address : 23 (integer)
	          indigoObjVersion : 6 (integer)
	          modelNameAndFirmware : RGBW Controller (FGRGBWM), firmware 25.25 (string)
	          propsPushTickler : 5 (string)
	          tempAlwaysFalse : false (bool)
	          userConfigVal009 : 1 (integer)
	          userConfigVal010 : 10 (integer)
	          userConfigVal012 : 255 (integer)
	          userConfigVal013 : 10 (integer)
	          userConfigVal016 : false (bool)
	          userPollAfterActivity : true (bool)
	          userPollInterval : 0 (integer)
	          userPollingEnabled : true (bool)
	          userWakeInterval : 60 (integer)
	          version : 25.25 (string)
	          zwAppVersMajor : 25 (integer)
	          zwAppVersMinor : 25 (integer)
	          zwAssociationsMap : (dict)
	               g1 : (list)
	                    Item : 1 (integer)
	               g2 : (list)
	                    Item : 1 (integer)
	               g3 : (list)
	                    Item : 1 (integer)
	               g4 : (list)
	                    Item : 1 (integer)
	               g5 : (list)
	                    Item : 1 (integer)
	          zwAssociationsMapStr : 1:[1] 2:[1] 3:[1] 4:[1] 5:[1] (string)
	          zwClassCmdBase : 38 (integer)
	          zwClassCmdMap : (dict)
	               c112 : 1 (integer)
	               c114 : 1 (integer)
	               c133 : 1 (integer)
	               c134 : 1 (integer)
	               c32 : 1 (integer)
	               c38 : 1 (integer)
	               c39 : 1 (integer)
	               c49 : 2 (integer)
	               c50 : 2 (integer)
	               c51 : 1 (integer)
	               c96 : 3 (integer)
	          zwClassCmdMapStr : 20v1 60v3 26v1 86v1 27v1 72v1 70v1 31v2 32v2 33v1 85v1 (string)
	          zwClassIds : (list)
	               Item : 4 (integer)
	               Item : 17 (integer)
	               Item : 1 (integer)
	          zwClassInstanceCountMap : (dict)
	          zwClassInstanceCountMapStr : - none - (string)
	          zwClassName : Dimmable Power Switch (string)
	          zwConfigVals : (dict)
	               p10 : 10 (integer)
	               p12 : 255 (integer)
	               p13 : 10 (integer)
	               p16 : 0 (integer)
	               p8 : 0 (integer)
	               p9 : 1 (integer)
	          zwConfigValsStr : 8:0 9:1 10:10 12:255 13:10 16:0 (string)
	          zwDevSubIndex : 0 (integer)
	          zwEncryptionStatusStr :  (string)
	          zwEndpointClassMap : (dict)
	               e1 : (list)
	                    Item : 38 (integer)
	               e2 : (list)
	                    Item : 38 (integer)
	               e3 : (list)
	                    Item : 38 (integer)
	               e4 : (list)
	                    Item : 38 (integer)
	               e5 : (list)
	                    Item : 38 (integer)
	          zwEndpointClassMapStr : 1:[26], 2:[26], 3:[26], 4:[26], 5:[26] (string)
	          zwEndpointDevTypeMap : (dict)
	               e1 : (list)
	                    Item : 17 (integer)
	                    Item : 1 (integer)
	               e2 : (list)
	                    Item : 17 (integer)
	                    Item : 1 (integer)
	               e3 : (list)
	                    Item : 17 (integer)
	                    Item : 1 (integer)
	               e4 : (list)
	                    Item : 17 (integer)
	                    Item : 1 (integer)
	               e5 : (list)
	                    Item : 17 (integer)
	                    Item : 1 (integer)
	          zwEndpointDevTypeMapStr : 1:(11 : 01), 2:(11 : 01), 3:(11 : 01), 4:(11 : 01), 5:(11 : 01) (string)
	          zwFeatureListStr : routing, beaming, energyMeter (string)
	          zwLibType : 3 (integer)
	          zwManufactureId : 271 (integer)
	          zwManufactureName : Fibaro System (string)
	          zwMeterSubTypeFlags : 5 (integer)
	          zwMeterSupportsReset : true (bool)
	          zwMeterType : 1 (integer)
	          zwModelDefnVers : 4 (integer)
	          zwModelId : 151003136 (integer)
	          zwModelName : RGBW Controller (FGRGBWM) (string)
	          zwNodeNeighbors : (list)
	               Item : 1 (integer)
	               Item : 10 (integer)
	               Item : 12 (integer)
	               Item : 13 (integer)
	               Item : 14 (integer)
	               Item : 15 (integer)
	               Item : 18 (integer)
	               Item : 19 (integer)
	               Item : 20 (integer)
	               Item : 22 (integer)
	          zwNodeNeighborsStr : 1, 10, 12, 13, 14, 15, 18, 19, 20, 22 (string)
	          zwProtoVersMajor : 3 (integer)
	          zwProtoVersMinor : 52 (integer)
	          zwShowDumpDevToLog : false (bool)
	          zwShowMainUI : true (bool)
	          zwShowManualModifyConfigParmUI : false (bool)
	          zwShowPollingUI : true (bool)
	          zwShowSubmitModelInfoUI : false (bool)
	          zwShowWakeIntervalUI : false (bool)
	          zwWakeInterval : 0 (integer)
	greenLevel : 100.0
	lastChanged : 2018-07-13 16:37:35
	lastSuccessfulComm : 2018-07-13 16:37:35
	ledStates : []
	model : RGBW Controller (FGRGBWM)
	name : Living Room LEDS
	onBrightensToDefaultToggle : False
	onBrightensToLast : True
	onState : False
	ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
	          g1 : (list)
	               Item : 1 (integer)
	          g2 : (list)
	               Item : 1 (integer)
	          g3 : (list)
	               Item : 1 (integer)
	          g4 : (list)
	               Item : 1 (integer)
	          g5 : (list)
	               Item : 1 (integer)
	          c112 : 1 (integer)
	          c114 : 1 (integer)
	          c133 : 1 (integer)
	          c134 : 1 (integer)
	          c32 : 1 (integer)
	          c38 : 1 (integer)
	          c39 : 1 (integer)
	          c49 : 2 (integer)
	          c50 : 2 (integer)
	          c51 : 1 (integer)
	          c96 : 3 (integer)
	     zwClassIds : (list)
	          Item : 4 (integer)
	          Item : 17 (integer)
	          Item : 1 (integer)
	          p10 : 10 (integer)
	          p12 : 255 (integer)
	          p13 : 10 (integer)
	          p16 : 0 (integer)
	          p8 : 0 (integer)
	          p9 : 1 (integer)
	          e1 : (list)
	               Item : 38 (integer)
	          e2 : (list)
	               Item : 38 (integer)
	          e3 : (list)
	               Item : 38 (integer)
	          e4 : (list)
	               Item : 38 (integer)
	          e5 : (list)
	               Item : 38 (integer)
	          e1 : (list)
	               Item : 17 (integer)
	               Item : 1 (integer)
	          e2 : (list)
	               Item : 17 (integer)
	               Item : 1 (integer)
	          e3 : (list)
	               Item : 17 (integer)
	               Item : 1 (integer)
	          e4 : (list)
	               Item : 17 (integer)
	               Item : 1 (integer)
	          e5 : (list)
	               Item : 17 (integer)
	               Item : 1 (integer)
	          Item : 1 (integer)
	          Item : 10 (integer)
	          Item : 12 (integer)
	          Item : 13 (integer)
	          Item : 14 (integer)
	          Item : 15 (integer)
	          Item : 18 (integer)
	          Item : 19 (integer)
	          Item : 20 (integer)
	          Item : 22 (integer)
	pluginId : com.perceptiveautomation.indigoplugin.zwave
	pluginProps : com.eps.indigoplugin.homekit-bridge : (dict)
	protocol : ZWave
	redLevel : 13.15371394
	remoteDisplay : True
	states : States : (dict)
	     accumEnergyTimeDelta : 104216856 (integer)
	     accumEnergyTimeDelta.ui : 104216856 seconds (string)
	     accumEnergyTotal : 272.04 (real)
	     accumEnergyTotal.ui : 272.04 kWh (string)
	     blueLevel : 69.14991736 (real)
	     blueLevel.ui : 69 (string)
	     brightnessLevel : 0 (integer)
	     curEnergyLevel : 0 (real)
	     curEnergyLevel.ui : 0.0 W (string)
	     greenLevel : 100.00000000 (real)
	     greenLevel.ui : 100 (string)
	     redLevel : 13.15371394 (real)
	     redLevel.ui : 13 (string)
	     whiteLevel : 100.00000000 (real)
	     whiteLevel.ui : 100 (string)
	subModel : Composite
	supportsAllOff : False
	supportsColor : True
	supportsRGB : True
	supportsRGBandWhiteSimultaneously : True
	supportsStatusRequest : True
	supportsWhite : True
	version : 25.25
	whiteLevel : 100.0
	whiteLevel2 : None
	whiteTemperature : None
	##### DEVICE SIMULATION DATA #####
	Service :
		alias : Living Room LEDS
		model : Composite
		subModel :
		indigoType : indigo.DimmerDevice
		pluginType : indigo.DimmerDevice.com.perceptiveautomation.indigoplugin.zwave.zwColorDimmerType
		type : Lightbulb
		desc : Lightbulb
		objId : 252057584
		serverId : 1795781458
		invertOnState : False
		convertFahrenheit : False
		required : (List)
			On : False
		optional : (List)
			Hue
			Saturation
			ColorTemperature
			Name
			Brightness : 0
		native : True
		requiresPlugin : (List)
		actions : (List)
			Action : (HomeKitAction)
				Characteristic : On
				When : equal
				Value : False (bool)
				Value2 : 0 (bool)
				Command : device.turnOff
				Arguments : [252057584]
				monitors : {252057584: 'attr_onState'}
				Characteristic : On
				When : equal
				Value : True (bool)
				Value2 : 0 (bool)
				Command : device.turnOn
				Characteristic : Brightness
				When : between
				Value : 0 (int)
				Value2 : 100 (int)
				Command : dimmer.setBrightness
				Arguments : [252057584, '=value=']
				monitors : {252057584: 'attr_brightness'}
		loadOptional : False
		characterDict : (Dict)
			On : False
			Brightness : 0
Londonmark
Post by Londonmark »
+1 on hoping for support for this... and let me know if there’s anything I can do to help. Obviously must be tough to find time given all the hard work on the Tado plugin...
Colorado4Wheeler
[MODERATOR NOTE] I've moved all the Tado discussions to the Tado thread.
Colorado4Wheeler
This is going to be much more difficult than I had imagined! I spent some time on this and converting from Apple's HSV/HLV system to RGB,W,T is challenging. The conversion libraries built into Python totally mess it up, going to have to try to write an algorithm for this I think. It was pretty easy on the Hue because they are similar enough to get away with it (but it hasn't been perfect either) but from straight RGB,W,T... yikes.
Doing this has been on roadmap since day 1 and integrating the Hue was my first step towards to the end goal because I have a lot of Hue devices, but I would like to do away with the Hue specific aspect of HKB and make that more generic for this application as well as others (plus the Hue is mostly right but not spot on).
Colorado4Wheeler
Ok, closing in on a 1.0.2 beta that supports color changing across any Indigo device that supports color. It's been quite a challenge to get working! I'll let you know when you can try it out.
Return to “HomeKit Bridge”
