Mac Commander Plugin (Legacy Ver 1.1.0)
ckeyes888
Re: Mac Commander Plugin (Legacy Ver 1.1.0)
Post by ckeyes888 »
Here's a sample script that I save as an app on the remote machine.
tell application "Google Chrome" to set URL of active tab of window 1 to "http://192.168.1.80:8176/controlpage?name=Calendar&useJS=True"
I was able to get this script to work between my two 10.12 machines.
set remMachine to "eppc://TV:[email protected]"
tell application "Finder" of machine remMachine
	open file "Macintosh HD:Applications:iTunes"
end tell
I assume that means the script should work eventually to the remote 10.6 machine.
The remote machine is only running one app, Google, so I never thought much of upgrading it's OS but now it seems like something to try.
Carl
Colorado4Wheeler
Post by Colorado4Wheeler »
I suppose it's possible that there was some security changes between 10.6 and 10.12 that would prevent it from being run remotely but I don't know of any off the top of my head. If it works 10.12 to 10.12 then that tells you a lot and that upgrading will probably solve your problem.
ckeyes888
Post by ckeyes888 »
Got an newer mini on order running 10.12. I’ll post back how it goes.
Carl
jltnol
Post by jltnol »
I don't see the plugin anymore in the Plugin Store. I'm guessing this uses AppleScript so won't work in the near future? Is that correct?
Colorado4Wheeler
You mean this plugin on the Plugin Store?
Even if there is AppleScript it is encapsulated inside of Python calls so it's not part of the phasing out of AppleScript in Indigo.
jltnol
Post by jltnol »
Sorry
I Typed Too Fast.
Was looking fo "E" PS Mac Commander... not just "M"ac commander...
