Jun 24, 2018, 12:11:24 PM
LIFX Checking for updates...
LIFX Error Error in plugin execution MenuAction:
File "plugin.py", line 130, in checkForUpdates
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/LIFX.indigoPlugin/Contents/Server Plugin/ghpu.py", line 88, in checkForUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/LIFX.indigoPlugin/Contents/Server Plugin/ghpu.py", line 175, in _prepareForUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/LIFX.indigoPlugin/Contents/Server Plugin/ghpu.py", line 97, in getUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/LIFX.indigoPlugin/Contents/Server Plugin/ghpu.py", line 117, in getLatestRelease
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/LIFX.indigoPlugin/Contents/Server Plugin/ghpu.py", line 145, in _GET
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1053, in request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1093, in _send_request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1049, in endheaders
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 893, in _send_output
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 855, in send
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1274, in connect
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 352, in wrap_socket
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 579, in __init__
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 808, in do_handshake
SSLError: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)Code: Select all
Jun 24, 2018, 12:10:54 PM
LIFX Error StandardError detected communicating with LIFX lamp. Line '267' has error='list index out of range'
