I just found you Hue plugin and just couldn't resist ti add a Hue bridge to my system.
First of all, thanks a lot for your work.
The cause for me to go the Hue route were the new Ikea Trädfri LED drivers that are so low price. The Hue bridge found them immediately and I could dimm alle the LED lamps I have at once.
Then I added the bridge to indigo. So far so easy. What I couldn't do was to add one of the lamps to indigo.
I added a Hue lights device but none of the "model" entries showed any device. I tried them all. So either I am doing wrong or the Hue plugin doesn't support all Hue devices.
The only thing I can do is create a room for each lamp and then I can add them as a device group. This seems to me like a workarround.
Am I doing something wrong ?
In the Hue app the Ikea drivers are listed as dimmable lamps. When I press the "i" Button I get
Model:
SW: 1.2.245
Room: Roomname
Here is a snippet from the debug log, if you need info.
Hue Lights Debug Sending command to hub: http://192.168.1.199/api/6KaxnNoA3MMLRzQgjBb-vABXjZYbj5SAS2oz34EG/lights
Hue Lights Debug Got response {u'1': {u'swversion': u'1.2.245', u'name': u'Vitrine', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'00:0b:57:ff:fe:9e:9a:76-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Dimmable light', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'TRADFRI transformer 30W'}, u'2': {u'swversion': u'1.2.245', u'name': u'Sideboard', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'00:0b:57:ff:fe:a3:8a:b9-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Dimmable light', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'none'}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'TRADFRI transformer 30W'}}
Hue Lights Debug Loaded lights list - {u'1': {u'swversion': u'1.2.245', u'name': u'Vitrine', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'00:0b:57:ff:fe:9e:9a:76-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Dimmable light', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'TRADFRI transformer 30W'}, u'2': {u'swversion': u'1.2.245', u'name': u'Sideboard', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'00:0b:57:ff:fe:a3:8a:b9-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Dimmable light', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'none'}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'TRADFRI transformer 30W'}}
Hue Lights Debug Starting parseAllHueLightsData.
Hue Lights Debug parseAllHueLightsData: There are 2 lights on the Hue bridge and 2 Indigo devices controlling Hue devices.
Hue Lights Debug Starting updateGroupsList.
Hue Lights Debug Sending command to hub: http://192.168.1.199/api/6KaxnNoA3MMLRzQgjBb-vABXjZYbj5SAS2oz34EG/groups
Hue Lights Debug Got response {u'1': {u'name': u'Esszimmer', u'lights': [u'1'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'type': u'Room', u'class': u'Dining'}, u'2': {u'name': u'Sideboard', u'lights': [u'2'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 254, u'alert': u'none'}, u'recycle': False, u'type': u'Room', u'class': u'Living room'}}
Hue Lights Debug Loaded groups list - {u'1': {u'name': u'Esszimmer', u'lights': [u'1'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'type': u'Room', u'class': u'Dining'}, u'2': {u'name': u'Sideboard', u'lights': [u'2'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'bri': 254, u'alert': u'none'}, u'recycle': False, u'type': u'Room', u'class': u'Living room'}}
Hue Lights Debug Starting parseAllHueGroupsData.
Hue Lights Debug Starting parseOneHueGroupData.
Hue Lights Debug updateDeviceState: Updating device Vitrine state: alertMode. Old value = . New value = none
Hue Lights Debug updateDeviceState: Updating device Vitrine state: alertMode. Old value = none. New value =
Wilhelm
