Any suggestions?
The log file shows the following:
Z-Wave Indigo Device "Front Door Lock" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 8
Model: Door Lock (BE369/468/469)
Model ID: 63415044
Manufacturer: Schlage
Manufacturer ID: 003B
Protocol Version: 3.42
Application Version: 113.22
Model Definition Version: 0
Library Type: 6
Class Name: Keypad Door Lock
Class Hierarchy: 04 : 40 : 03
Command Class Base: 62
Command Versions: 20v1 80v1 62v1 63v1 85v1 86v1 22v1 70v1 71v1 72v1 98v1 7Av1 5Dv1
Encryption Status: Enabled for Commands 20 80 62 63 85 70 71 5D
Features: routing, battery, beaming, security, frequentWaking
Neighbors: - none -
Associations: - none -
Config Values: - none -
Jan 05, 2018 at 13:00:43
Z-Wave Lock Manager Debug logging enabled
Reloading plugin "Z-Wave Lock Manager 1.0.46"
Stopping plugin "Z-Wave Lock Manager 1.0.46" (pid 363)
Z-Wave Lock Manager Debug Stop processing trigger Front Door Bolt Error
Z-Wave Lock Manager Debug Stop processing trigger Front Door Locked by Indigo
Z-Wave Lock Manager Debug Stop processing trigger Front Door Locked by Keypad
Z-Wave Lock Manager Debug Stop processing trigger Front Door Locked Manually
Z-Wave Lock Manager Debug Stop processing trigger Front Door UnLocked by Indigo
Z-Wave Lock Manager Debug Stop processing trigger Front Door UnLocked by Keypad
Z-Wave Lock Manager Debug Stop processing trigger Front Door UnLocked Manually
Z-Wave Lock Manager Debug shutdown called
Stopped plugin "Z-Wave Lock Manager 1.0.46"
Starting plugin "Z-Wave Lock Manager 1.0.46" (pid 18402)
Started plugin "Z-Wave Lock Manager 1.0.46"
Z-Wave Lock Manager Debug startup called
Z-Wave Lock Manager Debug Start processing trigger Front Door Bolt Error
Z-Wave Lock Manager Debug Start processing trigger Front Door Locked by Indigo
Z-Wave Lock Manager Debug Start processing trigger Front Door Locked by Keypad
Z-Wave Lock Manager Debug Start processing trigger Front Door Locked Manually
Z-Wave Lock Manager Debug Start processing trigger Front Door UnLocked by Indigo
Z-Wave Lock Manager Debug Start processing trigger Front Door UnLocked by Keypad
Z-Wave Lock Manager Debug Start processing trigger Front Door UnLocked Manually
Jan 05, 2018 at 13:07:57
Z-Wave sent "Front Door Lock" unlock
Jan 05, 2018 at 13:08:14
Z-Wave sent "Front Door Lock" status request
Trigger Update Front Door Lock Battery
Z-Wave Lock Manager Debug Node ID 8 (Hex
Z-Wave Lock Manager Debug Door: 01 0D 00 04 00 08 07 62 03 00 00 02 FE FE FF
Z-Wave Lock Manager Debug Node: 8
Z-Wave Lock Manager Debug Type: 0
Z-Wave Lock Manager Debug User: 0
Z-Wave Lock Manager Status: Door is unlocked [Node: 8]
Z-Wave Lock Manager Debug Updating state: lockState
Z-Wave Lock Manager Latch open, Bolt unlocked, Door open [Node: 8]
Z-Wave Lock Manager Debug Updating state: handleState
Z-Wave received "008 - Front Door Lock" status update battery level 97%
Jan 05, 2018 at 13:09:19
Z-Wave sent "Front Door Lock" lock
Jan 05, 2018 at 13:09:51
Z-Wave received "Front Door Lock" status update lock state not known (presuming unlocked)
Z-Wave Lock Manager Debug Door: 01 0D 00 04 00 08 07 62 03 FE 00 00 FE FE FF
Z-Wave Lock Manager Debug Type: 254
Z-Wave Lock Manager Status: Door lock state unknown [Node: 8]
Z-Wave Lock Manager Latch open, Bolt locked, Door open [Node: 8]
Jan 05, 2018 at 13:14:10
Z-Wave received "Front Door Lock" status update is locked
Z-Wave Lock Manager Debug Door: 01 0D 00 04 00 08 07 62 03 FF 00 00 FE FE FF
Z-Wave Lock Manager Debug Type: 255
Z-Wave Lock Manager Status: Door is locked [Node: 8]
Z-Wave received "Motion Sensor Entry" status update is off
