Hi C4W.
Just thought I'd use this to convert a Unix timestamp to a visual date, purely for something I'm debugging in one of my own plugins - when I noticed that's not one of the options?
(Unless, there's a %code for the full timestamp but I can't find one?)
Peter
Convert timestampt to date/time?
- Colorado4Wheeler
Re: Convert timestampt to date/time?
Well, the date format is Python but it's just reading a string, so as long as you specify the format, in Python notation, it should covert.
But that’s the problem, there is no date notation for time.time() that strftime() etc supports?
If I’d used time.strftime(%y %m %d, time.time()) when creating my plugin then I could use your plugin to convert %y %m %d to something else.
But I used time.time() in my plugin, purely for counting seconds elapsed, so I didn’t need to format it in the plugin when I stored it in a state.
Now I want to temporarily (without recoding states) see the h
s value of that timestamp?
time.strftime('%Y-%m-%d %H:%M:%S', time.localtime())Code: Select all
time.strftime("%Y-%m-%d %H:%M:%S", time.gmtime(time.time()))I am in the UK.. delta of 1 hour is due to DST
I know how to do it in code, I just thought it would a) be in the DE plugin already and b) because it isn’t, be a useful suggestion.
Seems not.
Seems not.
- Colorado4Wheeler
It is and I'll look to add that. DE is a mess on my end right now with so many changes so you won't see that change for a while, that's why I was trying to see if there was a way to do it with what DE already does.howartp wrote:I know how to do it in code, I just thought it would a) be in the DE plugin already and b) because it isn’t, be a useful suggestion.
I didn't understand that you were wanting to drop to a shell to do it, I thought it was in Unix format and sitting somewhere in Indigo already, then it's a matter of converting the format.
Hehe, I don't want to drop to a shell, and it is in Unix format sitting in Indigo already...Colorado4Wheeler wrote:It is and I'll look to add that. DE is a mess on my end right now with so many changes so you won't see that change for a while, that's why I was trying to see if there was a way to do it with what DE already does.howartp wrote:I know how to do it in code, I just thought it would a) be in the DE plugin already and b) because it isn’t, be a useful suggestion.
Never mind, I've sorted my plugin issue anyway - it will be good to add to DE when you get to it but no urgency.
