RFPlayer Frequency Gotchas
The EU version of the dongle supports two frequency bands: 433.420 or 433.920MHz and 868.350 or 868.950MHz.
The 868Mhz band isn't allowed in the US, so that version does 433.420 or 433.920MHz and 310 or 315MHz. The 310/315MHz band is referred to as the "High Band" in the RFPlayer documentation, even though it isn't. ;)
My Oregon Scientific devices use 433.920MHz. My Visonic device uses 315MHz. Unfortunately, X10 RF uses 310MHz. So you can't listen for X10 transmissions (like from a PalmPad) if you use Visonic. Or vice versa.
There are probably other conflicts that I haven't run into. If you have, please post them here so others are warned.
Re: RFPlayer Frequency Gotchas
Another note: The dongle will always Transmit on the correct frequency, even if it's currently set to listen on the other one. For example, if the High band is set to 315MHz (US) to work with Visonic sensors, you can still send X10 RF commands on 310MHz.
Return to “RFPlayer”
