Bad return code: Unauthorized
t-star
Post by t-star »
Anyone else seeing these messages. Turned debug messages on.
Thoughts?
MyQ Starting MyQ
MyQ Error getDevices: Bad return code: Unauthorized (216)
MyQ Checking for updates...
MyQ No updates are available
Oct 31, 2017, 4:47:16 PM
MyQ Debug logLevel = 10
MyQ Debug myqLogin successfull
MyQ Debug updateFrequency = 0.0
MyQ Debug statusFrequency = 600.0
Oct 31, 2017, 4:47:40 PM
Re: getting error: getDevices: Bad return code: Unauthorized
No idea. I don't get that one even if I use a bad username or opener brand.
Did this work before? Do you have the latest plugin?
t-star
Post by t-star »
was working fine. I think that I have the latest. It says I have version 7.1.8.
Just noticed it one day in the logs.
Tried to delete the plugin and reinstall it. didn't help.
What's your poll interval? Maybe it was polling too much and your account got blacklisted. Does the MyQ website and/or App still work?
t-star
Post by t-star »
set to 10. (default).
Website and app work fine. What do i need to do to totally remove it is i can start over?
t-star wrote:set to 10. (default).
Well, you could disable the plugin, then delete the preferences file, then re-enable it. You'll need to do the config again. I kinda doubt it'll help. It really looks like your login has been blacklisted somehow.
I'll check and see if there's any update to the library I use to talk to the MyQ servers. I didn't write the underlying comm code.
t-star
Post by t-star »
the debugging info (first post) shows that the login was successful. So not sure what is going on.
t-star wrote:the debugging info (first post) shows that the login was successful. So not sure what is going on.
I don't get it either. It's returning a success code on the login, then unauthorized on the devices. Makes no sense to me.
t-star
Post by t-star »
i re-installed it. no luck.
i will leave it disabled for a while. I also changed the poll to every 2 hours.
dliccardo
Post by dliccardo »
I also starting getting the exact same error with version 7.1.8:
My opener is working normally through the MyQ iOS app.
I'm happy to try beta's, send back lots, etc. if its helpful...
Darren
Anyone having this issue, please report here what brand you have selected in the config panel.
And let me know what happens if you pick a different brand.
I have a Liftmaster system with two openers, and am unable to replicate this error. There was a problem with the MyQ servers a couple days ago, but that seems to have been corrected.
dliccardo
Post by dliccardo »
I have a Liftmaster system. When I change configuration to Craftsman, I get a login failure:
MyQ Error myqLogin failure, Bad return code: The username or password you entered is incorrect. Try again. (203)
When I change to Chamberlain, I get the same 216 failure.
Thanks for your attention!
Darren
t-star
Post by t-star »
i have chamberlain selected.
t-star wrote:i have chamberlain selected.
Any change if you try Liftmaster or Craftsman?
ZachBenz
Post by ZachBenz »
Same exact problem here. I have Liftmaster selected as the brand; haven't changed any settings in months, and everything was working fine until sometime recently.
Locked
Return to “MyQ”
