Kwikset 910 Error
Kwikset 910 Error
Installed the latest version .41, but getting this error when unlocking:
Z-Wave Lock Manager Error Error in plugin execution ReceivedBroadcast:
File "plugin.py", line 301, in zwaveCommandReceived
File "plugin.py", line 552, in triggerEvent
KeyError: (845063353,)
Any suggestions?
Thank you in advance.
JP
Any suggestions?
JP
Re: Kwikset 910 Error
Have you created dummy devices for your locks?
If by dummy device you are referring to "new device called ZWave Lock Manager > Door Lock", then yes.
Is that what you meant?
JP
JP
Yep.
I'll have a look.
I'll have a look.
Thank you!
I've just posted v1.0.43
Nothing in it should have fixed your problem above, but there again your problem above shouldn't be happening...
Can you retry it in .43 and reply back with log if still a problem?
Peter
Peter
Peter - loaded the version but still getting the error when unlocking. As you can see below locking has no issues.howartp wrote:I've just posted v1.0.43
Peter
Z-Wave received "Garage Entry Lock" status update locked by user 001 (via keypad)
Z-Wave Lock Manager Status: User 1 locked door [Node: 126]
Z-Wave received "Garage Entry Lock" status update unlocked by user 001 (via keypad)
Z-Wave Lock Manager Status: User 1 unlocked door [Node: 126]
File "plugin.py", line 306, in zwaveCommandReceived
File "plugin.py", line 593, in triggerEvent
Hope this helps to narrow the issue.
JP
Peter,
By the way, the same error is also happening with the Yale locks:
Z-Wave received "Side Gate-Back" status update locked (manually)
Z-Wave Lock Manager Status: Door locked manually (one-touch button) [Node: 128]
Z-Wave received "Side Gate-Back" status update unlocked (via keypad)
Z-Wave Lock Manager Status: User 0 unlocked door [Node: 128]
JP
JP
Just to provide a bit more info, in case it helps. Using the Z-Wave Watcher, got the following:
Z-Wave Watcher Debug Raw command sent (Node 126): 01 11 00 13 7E 0A 98 80 65 78 4C 2D DF 18 ED 15 25 DA 2D (True)
Z-Wave received "Garage Entry Lock" status update locked (manually)
Z-Wave Watcher Debug Raw command received (Node 126): 01 08 00 04 00 7E 02 98 40 57
Z-Wave Watcher Debug Raw command received (Node 126): 01 0A 00 04 00 7E 04 71 05 15 01 FF
Z-Wave Watcher Debug Raw command received (Node 126): 01 1E 00 04 00 7E 18 98 81 4C 5F 69 BA B3 E3 2D 7D 63 07 7E 65 28 65 0A 10 43 27 C2 FF 13 3D 05
Z-Wave Lock Manager Status: Door locked manually [Node: 126]
Z-Wave received "Half Bath Light" status update is on
Z-Wave Watcher Debug Raw command sent (Node 126): 01 11 00 13 7E 0A 98 80 65 78 4C 2D DF 18 ED 15 25 DC 2B (True)
Z-Wave Watcher Debug Raw command received (Node 126): 01 0A 00 04 00 7E 04 71 05 13 01 FF
Z-Wave Watcher Debug Raw command received (Node 126): 01 1E 00 04 00 7E 18 98 81 B0 B1 D8 63 7E 77 34 2B E8 D0 39 A6 EE 65 7C 48 48 EE 5B 6F 42 33 CD
JP
JP
Sorry roquej; I thought I'd caught up on all my threads last week!
I'll try look at this tomorrow.
What device or trigger has ID of '845063353'?
Device ID "845063353' belongs to a Yale Real Living B1L lock.
JP
JP
In the trigger definition, is the trigger based on the Yale lock device, or on my dummy device?
Peter
Peter
your dummy device
JP
JP
Peter,
Just to see how if it would help, I deleted all the dummy devices and associated triggers. Also removed the plugin and reinstalled the new .45 version. After recreating the dummy devices and a few triggers, the error seem to go away.
Not sure if it was the new version or just clearing something with the previous devices, but everything seems to work now!
Thank you for looking into the issue. Really appreciate the awesome plugin.
JP
JP
